12-04-2011, 02:05 PM | #4326 |
Re: What did you do to your truck today?
I pulled a 305 v8 from my 55 chevy parts truck and made the decision to rebuild it as a hi perf engine w/700 r4, and put it in my 62. Now I need to figure out if I should sell the 305 v6 w/muncie 3 spd from my gmc. Any ideas on how much it's worth? runs good but leaks a little from the pan & tranny is good. Or if anyone local is interested pm me
1962 GMC 1/2 ton stepside longbed, 305 V6, Muncie 3spd HD tranny, stock rear end, rolling resto! |
12-04-2011, 05:18 PM | #4327 | |
12-04-2011, 05:23 PM | #4328 |
Moved all our stuff down to Bakersfield from Vacaville.
New shop: The cab is on the side of our new house ready for the new shop! I can't wait to get back into the resto!!!
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com |
12-04-2011, 10:02 PM | #4329 |
Meshed the caprice and 64 core support together. Mounted the radiator, AC condenser and the oil and trans cooler. Hung the sheet metal on it to see what was rubbing and/or in a bind. So far so good.. Everything is tacked in place. Now, time to take it all apart and start boxing the frame back in and making it more permanent..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
12-05-2011, 03:11 AM | #4330 |
Car & Truck Projects Google Community. https://plus.google.com/communities/...80679980403145 Youtube channel. http://www.youtube.com/channel/UC2HB...view_as=public 1964 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=419525 |
12-07-2011, 02:49 AM | #4331 |
After 6 weeks of cleaning, tuning and replacing parts I was able to to a 150 drive today.
I love driving it!!!!!!! |
12-07-2011, 06:45 AM | #4332 |
set up dual high and low pitch horns with a relay
12-07-2011, 11:44 AM | #4333 |
Banged my head on the wall over a blown intake gasket...arg
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-07-2011, 12:21 PM | #4334 |
1965 Chevy C10, 2005 4.8L/4l60
My LS swap started with that, then found a cracked head, figured the LS was the way to go.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-08-2011, 11:09 AM | #4335 |
Took a couple days vacation to make a long weekend to clean up the shop from the '69 rebuild and getting that "Burb back in to work on front suspension. Also going to mock up console/shifter idea and start to lay out some of the wiring. I have 3 harness to merge,- the EFI harness, the chassis harnes and the Phantom Key harness. Thank God they are all Painless Wiring parts. will post some pics later of some of the fab that is going on. Have a great weekend everyone!
12-08-2011, 04:27 PM | #4336 | |
Senior Enthusiast
You must not be alone in your annoyance with gear drives. Back in the 70’s-80’s it seemed like everyone had one. Where I live now I think I’ve heard maybe one or two others in the last 10 years so they have apparently fallen out of favor. |
12-08-2011, 05:30 PM | #4337 | |
12-09-2011, 09:09 PM | #4338 |
Painted my bed today......
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
12-09-2011, 09:28 PM | #4339 |
Nice shine!!!
12-09-2011, 09:30 PM | #4340 | |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
12-09-2011, 10:01 PM | #4341 |
198plus,
Fantastic job!!!! And Black too, those panels have to be lazer straight to pull off a gloss black paint job. I know yo have lots of man hours in those 2 bed panels. Again Great job!!!! |
12-09-2011, 10:10 PM | #4342 |
That's funny right there! They know everything right??
12-09-2011, 10:10 PM | #4343 |
12-09-2011, 11:18 PM | #4344 |
Finished the installation of a van tilt in my 64. I'm lazy and took the easy way out. I drilled a 3/8" hole in the center of dash where the column mounts, dropped in a 3/8" - 24 X 3/4" bolt backed it up with a 3/8" - 24 jamb nut which happens to be 1/4" thick, I then cut a piece of 1/4" rubber to install between the column and the dash. I pushed the column as close to the dash as I could and drilled a 3/8" locating hole in the top of my column to fit my centering bolt. Using the factory column mount holds plenty of pressure to keep the steering column tight in the truck.
12-09-2011, 11:29 PM | #4345 | |
Nice job, I like that column......What year van did it come out of ???
12-09-2011, 11:29 PM | #4346 |
Senior Enthusiast
I had a co-manager ask me the same thing back in the 1980's. Another enthusiast and I were discussing gear drives when the manager came in and condescendingly asked "is that the thing that makes it sound like your transmission is going out"? I responded - "only to the uneducated"!
12-09-2011, 11:32 PM | #4347 |
Senior Enthusiast
12-10-2011, 12:02 AM | #4348 | |
Thanks, they did turn out lazer straight. Quote:
Thanks.......I can't wait either, it want be long. We filled all the seams but the hood.
12-10-2011, 12:14 AM | #4349 |
Added 4 Way Flashers to my 64. Since I installed a 70's Van Tilt and the column had the provision for Emergency Flashers I wanted to make them work. I cut the flasher connector out of a 72 Nova in the wrecking yard. One side of the connector gets power from a constant HOT off the fuse block. The other lead runs to the "K" terminal (a brown wire) on the factory GM column connector. I read that you should use a 15 Amp fuse so I ran #14 wire. For my constant HOT I picked it off the Spot Light terminal of my fuse block and poped in a 15 Amp fuse. You don't have a "Spot Light" terminal on your fuse box? No problem, neither did I. In the wrecking yard locate a 60-66 truck fuse block, remove the Heater/B.U. Lamp fuse, take out the 1/4" head screw holding the fuse block in place and the screw in the Spot Light fuse location. Remove the fuses from the Brake LP & BU LP locations. From the back side of the fuse block - using a small flat blade screw driver release the tangs that hold the fuse clip in place and push out the front of the fuse block. The fuse clip I show in the middle of the first 2 pictures is the wrong clip it's for reference only. That clip is form the Panel LTS fuse and is the wrong one. You must use the clip from either the Brake LP or BU LPS fuse.
12-10-2011, 12:21 AM | #4350 |
I bought the column off eBay so I'm not 100% sure what year it is but I think the seller said it was a from a 71 van. I was the only bidder at $99.00 plus $19 shipping. I don't think I did too bad on the price of the column.
