Closed Thread
Old 09-19-2016, 07:10 PM   #4376
In The Ten Ring
Re: What did you do to your truck today? Chapter II
Opened my package of 4-row radiator brackets from a forum member. I also spoke with the media blaster, he has my (original) fender cleaned up and epoxy primed. I should be able to get it on Friday(?).
In The Ten Ring is offline
Old 09-19-2016, 07:25 PM   #4377
custom10nut
custom10nut's Avatar
Originally Posted by 66clow View Post
Decided to do a rattle can fauxtina as I do the body work on my truck. Just don't like plain primer. I'll sport this till I get the funds to tear it down for a complete refinish. About a quarter of the way done. Should have less than $80 in paint once completed. I sprayed and scuffed with red scotch Brite pads.
Before body work
After
That looks great! I'm looking at doing the same thing. I would really like to find a paint close to my original Medium Oive. If I do, it's a slam dunk.
custom10nut is offline
Old 09-19-2016, 08:41 PM   #4378
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Finally got the under dash Blazer only lights I bought from Roger Koop installed and I used LED bulbs. I also have an LED bulb in my dome light. They were plug and play when I figured out where to plug into. Piece of cake if you have the factory dome light switch on the door jamb. I took the pic inside the garage with the overhead door down and I think it will be brighter in the cab when its dark outside.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 09-19-2016, 09:29 PM   #4379
everettelane
everettelane's Avatar
Originally Posted by BugzC10 View Post
Post a sound clip. Same here on the FlowMasters....Those Magna's look like the will be loud. Which FM where you running?
I like the 40 series flowmaster mufflers i will make a recording tomorrow, if i can figure out how to upload it lol!!
everettelane is offline
Old 09-20-2016, 10:59 AM   #4380
elektrik
Foolish Mortal
elektrik's Avatar
bought a 3-point harness for #FIREBALL..gonna install next week...and in a couple of weeks i'm ordering a nice tailgate replacement for the truck (It's only been 20 years since it had a tailgate, lol!)
elektrik is offline
Old 09-20-2016, 09:07 PM   #4381
everettelane
Here's the sound clip BugzC10
Old 09-20-2016, 09:10 PM   #4382
In The Ten Ring
Just inquired about other radiator options is all.
Old 09-20-2016, 10:45 PM   #4383
Jrainman
Jrainman's Avatar
Media blast frame then put it in epoxy then Paint
Jrainman is offline
Old 09-21-2016, 07:47 AM   #4384
BugzC10
BugzC10's Avatar
Thanks Everette, unfortunately I don't have the ability it open a zip file on an iPad. Could a member convert and repost?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 09-21-2016, 10:48 PM   #4385
1969c10joe
i drove my truck took it out of town and FLOORED IT very entertaining forgot how much fun it is gonna do it tomorrow too.
1969c10joe is offline
Old 09-22-2016, 12:05 AM   #4386
In The Ten Ring
Ordered an aluminum radiator from KKS Motorsports. I'm not a fan of aluminum radiators but it was much cheaper than having mine recored and hopefully it fits better than the copper/brass one from RockAuto.
Old 09-22-2016, 12:11 AM   #4387
In The Ten Ring
You have an attractive interior. The white should get less hot in the sun and plaid is the color of the '70's. I rather wish my truck came with plaid and I may redo the seat in plaid.
Old 09-22-2016, 07:40 AM   #4388
BugzC10
BugzC10's Avatar
Please share the part numbers and source for the LED bulbs...
BugzC10 is offline
Old 09-22-2016, 04:28 PM   #4389
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Been chasing a slow, persistent, and extremely elusive coolant leak with no luck. Even had the shop pressurize the system and give a look-see. Nothing. I don't drive it often anymore but the coolant level continues to slowly drop. Need to find the leak before I change coolant (overdue, btw).
Found evidence of seepage where the heater hose hits the radiator. Replaced the heater hose, installed new clamps, and snugged all other clamps. Then did something I swore I would never do, out of sheer desperation. Poured in some stop-leak.
Time will tell if it's "fixed". Keeping my fingers crossed -- getting tired of adding Prestone and watching it slowly disappear.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline
Old 09-22-2016, 04:29 PM   #4390
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Sorry for the double post, dunno what happened.
- Mike -
RIP El Jay
Stocker is offline
Old 09-23-2016, 09:01 PM   #4391
Towbiz
Thumbs up Re: What did you do to your truck today? Chapter II
I scored a complete buddy seat last week & a nice tach dash today . A little wrenching over the winter & cruising next summer
Towbiz is offline
Old 09-23-2016, 09:51 PM   #4392
Already Gone
Got my electronic flashers along with the LED front signal light bulbs installed so now I have LED's in the tail lights, side marker lights and front signal lights. Next up, brighter headlight relay set up.
Old 09-24-2016, 08:10 PM   #4393
66clow
66clow's Avatar
Did some block sanding and created some more rattle can fauxtina. Left dents in gate since it is too beat up. Will eventually need a new one.
66clow is offline
Old 09-24-2016, 10:50 PM   #4394
everettelane
Fabricated some mounts and mounted my air ride compressors and tank today.
Old 09-24-2016, 11:38 PM   #4395
allchevy58
allchevy58's Avatar
My wife painted the inside of the fenders a couple of weeks ago while I was at work. Started cleaning trim and putting it back on.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline
Old 09-25-2016, 12:04 AM   #4396
crazyjeenyus
crazyjeenyus's Avatar
Lugged the '70 c-10 350/TH400 donor truck home. I only need a few parts, then I'll be getting rid of it.
'67 c10
'65 c10
crazyjeenyus is offline
Old 09-25-2016, 12:26 AM   #4397
OregonNed
OregonNed's Avatar
Polished up shiny parts under the hood
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 09-25-2016, 02:54 AM   #4398
Jose's 69
Decided to lower back of my 69 C20 1.5 more inches with some drop blocks. U bolts were rusted in place. Still have one half of one to get out.
Jose's 69 is offline
Old 09-25-2016, 04:50 AM   #4399
TrkEnvy
Seam sealer.. Stuff is a pain in the .. And now I wait a week to paint it.
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E
I call it Bruce Banner..
TrkEnvy is offline
Old 09-25-2016, 11:38 AM   #4400
Boog
laying low
Boog's Avatar
I rolled the 69 out of the shop for the first time in twenty years under it's own power. Yeah, twenty years. Time does get away doesn't it? I've not been in any hurry. One can forget what these trucks feel like while sitting for so many years. One reason to get it off the jackstands and pull it out was to get a different perspective of how it presently sits and check out the mechanicals. Run it around the yard a bit. Long running projects can tend to get stale. It felt good to be behind the wheel of it again. The truck looks 3/4 scale compared to the Yukon.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Closed Thread
