#426 |
Re: How about some pics of High Performance haulers.
My '68.
384 Stroker Small Block- Best ET: 13.24@103 |
#427 |
Cool truck Hot68gmc. Have you ran it at the track? How fast is it? Tell us more about it.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#428 |
Thanks! So far it's gone 13.24@103 on a pump gas tune and at 5280 ft up. I'm hoping once the suspension is set up for the track and not street it'll dip 12's.. Spins like a motha off the line right now.
It's running a 384 small block, 11.8:1 compression, custom FTI cam, Canfield 217cc/64cc heads, Brodix HV1000 manifold, Quick Fuel 1050 carb, forged bottom end from Eagle/Probe, Hooker headers, 3" manderal bent exhaust system with SpinTech mufflers. Hughes Competition TH350, manual valve body, fwd pattern, Hughes 10" 4100 stall converter. 3/4 ton Dana 60 rear end, 4:10 gears. Front suspension consists of Moog ball joints, tie rod ends, etc. ECE drop springs, drop spindles, 3/4-1/2 ton conversion, disc brakes. The rear has a custom 4-link with Aldan Eagle coil overs. The body is all steel. Complete interior. It's driven on the street to work and back every day and hauls my 3 year old daughter to grandmas house!
#429 |
forgive the double post.. Here's a link to the Garage Built Rides artical that was done on the truck this year. http://www.garagebuiltrides.com/home...ver-drag-truck
#430 |
Great truck, very aggressive looking, any hp numbers and what tires are you running?
#431 |
Tough looking truck HotRodGMC68.
Brandon Street Car Mafia |
#432 |
![]() Join Date: Jul 2009
sweet ride brother!
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ |
#433 |
Thanks for the good words! The tires in the photos are 28x11.5x16 MT ET Streets. I've since gone to a 295x50x16 Hoosier Drag Radial.
#434 |
how does it hook with the drag radial and can you leave on the kit
#435 |
as far as horse power numbers go, it's never been on a dyno.. When we built the engine we estimated it at 490 hp and 508 lb/ft at the crank.
#436 |
I put the drag radials on it right when our racing season ended this year so it hasn't been on the track with them yet. The nitrous kit came off of the truck and went on my wife's camaro. Never got the chance to run it on the button.
#437 |
chevy only
![]() Join Date: Sep 2006
my 66 prostreeter
CHEVY ONLY... Nothin Else ! |
#438 |
^^Sweet^^
Joe __________________________________________ 1975 C10 "Questions are a sign of intelligence indicating a desire to eliminate ignorance" |
#439 |
Dinos63 that is sweet.
#440 |
chevy only
thanks duudes
#441 | |
1972 Custom 1500 Long Step 250 I6, 4spd 1974 F350 cummins/4x4 conversion (hopefully) |
#442 |
I probably don't fit in with these rocket ships but here is my 54. It's got a 489 with Brodix heads and a mighty Demon 850. Continental 3'000stall converter, turbo 400, and a 9" with 4.56 gears. It has about 500 miles on it and I just drive it on the weekends. I did 95% of it in my 2 car garage. I run 31x18.50x15 MT Sportsmans which seem kind of hard. Will probably go to same size Hoosier radials in the future. There are some outstanding trucks on these pages. I have a few more things to do before I'm done but at least it's on the road. Best wishes to all of you out there.
#443 |
Resident of Here
That thing is the sex!
Nice!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck
#444 |
Beautiful truck, just badass... love the color. What shifter you running?
#445 |
Thanks for the kind words. The shifter is from Precision Performance Products in Cerritos California. My model is the Kwik Shift 1. Each one is built by hand one at a time. I went to the shop and picked mine up. He assembled it while I waited. Great shifter. There are other models and attachments available. I added a piece of 5x7 mirror finish stainless to raise the shifter off the floor. Their web site is
precisionperformance.com. Hope this helps. |
#446 |
update:
84 GMCummins 91 CCSB Dually american squarebody association |
#447 | |
Chevy Lover Till The End.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
#448 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#449 |
Not mine but............
Worlds Fastest Pickup Truck! - Fast Freddy's 1966 Pro Mod Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=506582
#450 |
Lot of work to do yet.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
| Bookmarks |
