Closed Thread
Old 11-30-2009, 09:58 AM   #426
menace121978
menace121978's Avatar
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
you guys ROCK!
as for the oil pan, i have to call BRP this morning and MAKE SURE there kit makes it possible to run the stock a/c compressor in the stock location w/o notching the frame for the lines and order the kit. then i can set the motor in and see how far down the oil pan hangs. they say it only hangs down an inch butwe'll see. the BRP mount kit is expensive but i figure after i buy the conversion plates($50) motor mounts($30) and a top mount a/c unit with compressor($300) tranny mount($20) i'm right up there($450 BRP kit) give or take a hundred and i wont have to worry about the tranny crossmember or the bend in the frame with the longer tranny. thoughts??
as for the fan clutch...i'll see about getting a better strap wrench and maybe take the entire pump over to my buddy at the GM dealership and have someone break it loose.
Billy, i'm off tuesday man. i almost called ya this weekend(had the last 4 days off) but being a holiday weekend i didnt want to bother ya out of the blue i'll give you a call this morning.
Gerald, give me your address and i'll just ship'em off to ya!! wont be for awhile that i need them... BTW, GOOD LUCK AT WORK TODAY!!
as for the fire wall! you just HAD to bring it up HUH!? No buddy, i'm dreading the whole body work/ welding deal. i still need to get a welder and fix the floor pan too. maybe i can just ship that out too huh Gerald!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline
Old 11-30-2009, 11:13 PM   #427
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
MONEY SHOT!!!!
You know how big of an itch you are going to have to want to start that thing!?!??!! This is sweet dude, congratulations! I know how anxious you have been to do this.
I like the way you are going on the color. You are right, I was hoping to see more of the red. It is visible, but not what I figured it would be. I guess I forgot that this is not your average small block, where practically EVERYTHING is visible.
You know who you can go to if you have any questions. Should be pretty easy for you to do.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline
Old 12-01-2009, 01:50 AM   #428
menace121978
right on Bob! thank you! when the time comes to start the cooling steam lines and tapping into the block i'll be calling!
btw, this block came with what looks to be oil cooler lines? not sure yet what to do about that. most 5.3 swaps the block is tapped into by the oil filter but this one has lines coming out? i still have more questions then answers as usual!! 1 step at a time though...
"Dennis the Menace"
Old 12-01-2009, 11:57 AM   #429
nlped
nlped's Avatar
I like the color choice. It's gonna look great in there.
Congrats...again!
Now...Tic Toc!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 12-01-2009, 09:18 PM   #430
menace121978
busy day!! flew by way too fast though.... enough talk, on to pics
intakes on with the new returnless fuel rail. left the injectors in the new rail but turned them 180*. they looked way better than the orig. also cleaned the heck out of the intake.
got all the lines hooked back up to the intake and cleaned the pcv.
took the water pump to a little shop down the street and got that awful fan clutch removed. cleaned, primed and painted water pump... beautiful!!
took the goats exhaust manifolds outta the attic to compare and measure. come to find out they will hit the frame stands. just a rough guess with the measuring tape. i'll try them again when everythings in place in the chassis.
took off the heat shields on the stock manifolds and painted them up with bbq flat black. supposed to be good til 1200*! yea right... also installed the coil paks and test fit a set of a/c delco wires.
"Dennis the Menace"
Old 12-01-2009, 09:33 PM   #431
menace121978
installed new a/c delco plugs and wires...
here's a look at the plugs i took out. autolites... ugh! 1 good thing though, it seem who ever had the esky took care of it. the wires were new too. bosch's.
hows she look?
last thing of the day was dip stick...
still to do is borrow Billy's picker and get the oil pan clean and painted, get a pulley puller for the power steering pump so i can clean and paint the bracket black, get a new belt tensioner from Larry at SPP, an intake egr block off plate and the top half is done! tried to get ahold of BRP for their mounts but havent heard from them. soon as i get the mounts i can set this baby in its new home and start working over the tranny.
"Dennis the Menace"
Old 12-01-2009, 11:22 PM   #432
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
WOOT WOOT!!!
That is coming along great. My address was on the envelope I sent you but call me if you need it. You are more than welcome to send those out for me to smooth. I can answer any weekday after 5pm mountain time. Or most of the weekend. But not during the weekdays because I have a new job that is going very well, thank you for asking!
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline
Old 12-01-2009, 11:34 PM   #433
LEEVON
LEEVON's Avatar
GAME ON!!! (Sorry, hadn't checked in for awhile). Nice score on the 6.0L.
If you have trouble with one of those fans again my trick is doubling-up a piece of tie wire and looping it through a small hole in the fan pully then around the water pump neck. Between this and the friction of the belt still it stays put long enough to loosen the nut.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline
Old 12-02-2009, 02:05 AM   #434
SBTork
Garage wrench
SBTork's Avatar
Nice progress! Im really liking the black/aluminum scheme, it works really well.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline
Old 12-02-2009, 10:18 AM   #435
JohnC
JohnC's Avatar
Looks sweet Dennis. Nice work. Can't wait to see it sitting in the frame!
JohnC is offline
Old 12-02-2009, 10:33 AM   #436
68Timber
I know the pieces fit
68Timber's Avatar
Sweet! The detail work is great.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
68Timber is offline
Old 12-02-2009, 11:15 AM   #437
nlped
nlped's Avatar
Looks Awesome!!!
Carter
nlped is offline
Old 12-02-2009, 11:19 AM   #438
menace121978
Originally Posted by Driveway Dreams View Post
WOOT WOOT!!!
right on bro, i still have it then. i'm happy the job is working out man! i'll keep ya posted on when i'm gonna send them out. gotta tighten up the belt a couple notches(miss a few meals!) between now and the 1st.
thanks man! better late than never but i hope i never have to deal with that again.
thanks ALOT guys! just wish ya'll could see it in person. the pics dont really do any of it justice. it is turning out better than expected if i do say so myself! soon as the motor and trans is set in there its all really going to come together nicely. might just have to order my wheels!!
"Dennis the Menace"
Old 12-02-2009, 12:08 PM   #439
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
That looks freakin awesome. Very nice work. Although, I chuckled when I saw the torque converter still bolted to the flex plate. Bet that would be impossible to put back together that way! A guy I work with was putting his trans in at home and didnt have the converter seated all the way, cracked the bellhousing half way to the tailshaft. Bad thing is it is a 4l80 he got from Bowtie Overdrives. Fully built and all. Woops...
--Josh
STOCKISH is offline
Old 12-02-2009, 12:32 PM   #440
menace121978
Yea i gotta get that off there! dreading it though... shoulda never seperated them
too much to move around altogether though...
"Dennis the Menace"
Old 12-03-2009, 01:21 PM   #441
tvblazer78
Low & Fast!
tvblazer78's Avatar
Dennis,
That thing is looking clean, super job!
Trav
tvblazer78 is offline
Old 12-05-2009, 12:20 AM   #442
mcbassin
Still Learning
mcbassin's Avatar
Nice job on the engine detail and congrats on being a member of the 6.0 club! I have enjoyed mine in my Vortec Max 07 since new it will pull the heck out of my heavy bass boat. Good luck and keep the pics coming!
mcbassin is offline
Old 12-05-2009, 12:38 AM   #443
joe231
joe231's Avatar
WOW!!
I have missed a lot....
sorry i will try to do better in the future
Nice work
CHEVY ONLY
joe231 is offline
Old 12-05-2009, 01:13 AM   #444
69face
69face's Avatar
looking real good! keep up the good work dude!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline
Old 12-05-2009, 01:23 AM   #445
Cherub
Cherub's Avatar
I left the hardlines and flared the ends and used a universal tranny cooler from B&M
looking good you will not be dissapointed oh and if you could take extra pics of the brp motor mounts i want to go with those next time.
Cherub is offline
Old 12-05-2009, 11:28 AM   #446
menace121978
thanks guys!! cherub, theres never a shortage of pics here buddy!
speaking of pics... you have any on those oil lines you are talking about? and where did you tap in for the oil pressure reg.??
i still havent heard from BRP!? i'll start trying again on monday.
"Dennis the Menace"
Old 12-05-2009, 02:51 PM   #447
ironroad9c1
Master Hater
Just a note, Not sure if you knew or not, but you are gonna have to remove the convertor from the flex plate and install it in the trans before bolting the transmission back up, when you install the converter back in the trans, turn it a few times as you push in so that it lines up with the Pump tangs, if you go to install the trans and can't get the bellhouseing to mate up with the block w/o forcing it, the converter isn't in enough, DO NOT use the bellhouseing bolts to pull the trans to the block. It will ruin the pump.
ironroad9c1 is offline
Old 12-05-2009, 06:14 PM   #448
JohnC
JohnC's Avatar
He mentioned it a few posts earlier.
JohnC is offline
Old 12-06-2009, 12:46 AM   #449
STOCKISH
STOCKISH's Avatar
Hows it coming Dennis? You know we cant wait too long for more pics.
--Josh
STOCKISH is offline
Old 12-06-2009, 01:05 AM   #450
menace121978
thanks John! i asked around and even had a thread to make sure how and if i had to take that darn tq. converter off and reset it. thanks for the heads up though.
works still trying to kill me! thousands of pounds of crabs cracked and cleaned today and through the weekend. good times... i did get a small promotion as 2nd man in charge in the dept. so my schedule will be pretty much set for the most part no progress to report but i'll be off wednesday and thursday and hopefully get the motor finished, mounts ordered, some of the fuel system parts ordered, and get the tranny cleaned and painted and bolted back together! probably wishful thinking since the weathers supposed to be really bad but we'll see...
"Dennis the Menace"
Closed Thread
