Old 08-23-2010, 09:53 PM   #426
sourkraut
sourkraut's Avatar
Re: "The way it is" 67'swb
it is the proportioning valve. the front and rear brake lines coming out of the master cylinder go into it. the front lines go free flow directly to the front calibers. the rear port will go to the rear brake cylinders but i can adjust the brake biast or amount of braking power the rear wheels will have. normally on these trucks with the stock proportioning valve the rear wheels will lock up before the front, this will prevent that from happening once i get it adjusted.
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 08-24-2010, 07:53 AM   #427
OLDIRON69
Basically controls the amount of braking to front and rear wheels. Normally a percentage like 70/30. Some folks will even run one per wheel (mostly road race stuff though)
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 08-24-2010, 08:23 PM   #428
Redneck72
Redneck72's Avatar
Thanks guys that makes a lot of sense and something else to add to my file of things I will have to look into doing when my time comes...
Redneck72 is offline   Reply With Quote
Old 08-24-2010, 09:42 PM   #429
Hubscrub
Cruzin
Hubscrub's Avatar
that thing is looking nice i really like the color and the wheels
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 08-26-2010, 10:23 PM   #430
sourkraut
sourkraut's Avatar
thanks, hub iam trying!
well been working on the brakelines here and there. you can see my thougths of the jegs powdercoated brakeline! good thing it was $35! i found some of the nicopp line and it is the best thing since sliced bread! bents easy, flares easy and the absolutely coolest thing is it polishes up to a super neat finish! i have been clearing the pieces once i bend and polish. got the rear done and the mc to prop valve pcs done. also powdercoated several parts, master cylinder brakcets brake pedal brackets and throttle lines.
can some one tell me if the brake pedal push rod bracket mounts with the flat side towards the mc or the rounded end? it can be mounted either way and could not remember which way it went so i mounted it with the flat side towards the mc so it was a wider area on the rubber boot. i think that once i have a full pedal it should not touch?? any help would be great.
Old 08-27-2010, 07:55 AM   #431
mcbassin
Still Learning
mcbassin's Avatar
Your brake lines look great! what was the story on the Jegs brake line? Too hard? Thanks for sharing the pics!
mcbassin is offline   Reply With Quote
Old 08-27-2010, 09:22 AM   #432
my67chevytruck
Under Construction
my67chevytruck's Avatar
looks Awesome John. very nice work!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-27-2010, 09:55 AM   #433
67cheby
67cheby
67cheby's Avatar
nice work
67cheby is offline   Reply With Quote
Old 08-27-2010, 03:32 PM   #434
sourkraut
sourkraut's Avatar
thanks guys, i appreciate the comments!
mike, i had gotten the powder coated kit. all around it was a pain! if you cleaned of the coated like they said it would end up to small for the vise/dye to grab. if you left it on and sinched the crap out of it it would walk a little and then flare was horrible! i could not get a good flare period! i even started a thread and used every suggestion and the only good one i came up with that worked for me was the smokin' NICOPP!! it is awesome!
Old 09-08-2010, 11:43 AM   #435
Redneck72
Redneck72's Avatar
Hey Bro,
Been a while since we had an update was wondering how things are going?
Paul
Old 09-21-2010, 05:02 PM   #436
1LoC10
Insert Title Here
1LoC10's Avatar
looks awesome....great job
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 09-30-2010, 10:41 PM   #437
sourkraut
sourkraut's Avatar
Originally Posted by Redneck72 View Post
Hey Bro,
Paul
i know, i have been super busy! i have gotten a little bit done and will have to get some pics of what i have done.
thank you, not making as much progress as i would like though.
Old 10-18-2010, 08:25 PM   #438
sourkraut
sourkraut's Avatar
well be super busy and not to much time for the truck i have gotten somethings done though. i have it that i can drive it under its own power which is super sweet, no more pushing around! that was one goal was to try and get it so i can move it around. the brake lines all done and very pleased how they turned out. the best part was they bleed themselves! i had opened the bleeders farthest from the mc to help get the fluid moving and it ran freely all over! tightened them up and checked the pedal for feel and believe it or not full pedal! the brakes feel great and work great so far. the clutch set up works great and feels really good also. next was the rebuilding the steering column and every thing turned out great!
the one pic is of a streering column foam?? not sure if i ordered or it got tossed in my order but d not remember were one would go any help would be great.
finally my mind has been running with two toning the top. off white or possibly a shade or two off of the main color. i was thinking i could fix/sand my seam sealer cuase it is really buggin me and would like to fix it. figure this would be the easist way to fix it but dont know whether to go suttle or completely noticable color/white. any input is very welcomed, hard to see in pic but you get the idea.
Old 10-18-2010, 08:30 PM   #439
Hubscrub
Cruzin
Hubscrub's Avatar
love the black engine sometimes i wish i would have done that......
Proverbs 3:5,6
Old 10-18-2010, 08:35 PM   #440
msgross
msgross's Avatar
I'd wait on the top until you get the bed on, then you can get a better picture...
Brown might not even be bad...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-18-2010, 08:40 PM   #441
sourkraut
sourkraut's Avatar
thanks, hub
mike, i know i had thought of all colors. you know how i am and dont think i would forgive myself if i dont fix that sealer.
Old 10-18-2010, 09:35 PM   #442
msgross
msgross's Avatar
told ya so...
i've been busy with granite countertops, painting and changing hardware in the kitchen...
did pick up a set of Raptor wheels for my daily driver though...
The Garage:
Old 10-18-2010, 09:48 PM   #443
sourkraut
sourkraut's Avatar
thanks, pal!!
ugh kitchen remolding! i bet you small stature came in handy with a granite top!
do you have a pic of your wheels, never heard of them?
Old 10-19-2010, 07:00 AM   #444
msgross
msgross's Avatar
well, you know what my DD is... the wheels are from the ford raptor truck
The Garage:
Old 10-19-2010, 08:38 AM   #445
sourkraut
sourkraut's Avatar
ok, I like those trucks. I did not realize that they were called raptors. cool wheels I like em and you got some nice rubber on them.
Old 10-25-2010, 07:16 PM   #446
sourkraut
sourkraut's Avatar
well, i have been looking for a ford 8n/2n/9n for years! here at a family reunion over the 4th of july i found out my cousin had 1939 9n for her farm. i told her if ever interested in selling let me know. well here she is selling her farm and called me and asked if i was still interested and as you can see i was. i got a heck of a deal! got the tractor and a 5' bush hog also. all she needs is a tune up and obviously a new tube in the flat tire. the tire that is flat is dry roughted but i think with a tube i should be able to get some more use out of it, seeing how just one rear tire is $320ea! if not i will be shopping craigslist for a used one.
Old 10-25-2010, 09:22 PM   #447
msgross
msgross's Avatar
nice... I see your next resto!
break out the gray paint!
The Garage:
Old 10-26-2010, 07:06 AM   #448
splehigh
splehigh's Avatar
Nice! Those are good tractors! My Dad has a 9N for plowing snow and the garden. Its always been dependable.
splehigh is offline   Reply With Quote
Old 10-26-2010, 02:17 PM   #449
sourkraut
sourkraut's Avatar
no resto for a long time! trust me, i already have visions but this will be for work! i am planning on replanting the largest horse pasture and then the two small ones. it will be nice to be able to cut grass in a 5' swath and not have to worry about what i hit! i hope to find some impliments for it but know they are getting hard to find and pricey.
Old 10-26-2010, 07:55 PM   #450
msgross
msgross's Avatar
I'd start with a three point mounted rear blade, easy snow removal...
The Garage:
