Old 12-26-2012, 10:41 AM   #426
made2drag
made2drag's Avatar
Re: 86 squarebody made2drag
Originally Posted by BRUISER View Post
I haven't changed one in the truck before but don't mind helping if you need a hand. It shouldn't be much different than a transmission service except engine oil dripping on your face instead of tranny fluid.
thanks for the offer....i want to get in the garage and check everything out...right now im putting together kids toys for my 2 kids
made2drag is offline   Reply With Quote
Old 12-26-2012, 11:17 AM   #427
made2drag
made2drag's Avatar
pm sent
Old 12-26-2012, 11:48 AM   #428
made2drag
made2drag's Avatar
Originally Posted by 54Caddy View Post
the one piece fel pro oil pan gasket will take place of the two seperate halves from factory and it will be all one piece. Its very easy man with all the other work you have done on this truck it should be a walk in the park.
Tools Needed will be a 3/8 ratchet, a couple extensions, a swivel adapter, and both shallow and deep 7/16 and 1/2 sockets and a 9/16 to drop the starter. when i do mine i get to all bolts from underthe oil pan area except the very front 2 on each side, have to get those from the front. Once its off clean the surface area and install the four corner clips that come with the oil pan gasket, put lite silicon on the corners of gasket that will contact the bearing caps, Install gasket then pan, those clips will hold it all up. Then install all the side bolts on both sides of oil pan with new bolts included in kit.
Also when i do this job depending on what year block you have i replace the rear main seal on the 2 piece style ones. Very easy just requires a 5/8 socket and torque wrench. Let me know if you need more help man. oh and merry xmas
Heres a link to gasket you will need, if yours is the early style block
One piece oil pan gasket from Fel-Pro
i cant seem to find a 1 piece for my 86 4.3....just this one
http://www.summitracing.com/parts/fe...et?prefilter=1
Old 12-26-2012, 12:33 PM   #429
made2drag
made2drag's Avatar
ordered my oil pan.
still looking for a 1 piece felpro for a 4.3
Old 12-26-2012, 01:25 PM   #430
made2drag
made2drag's Avatar
i just jacked my truck way up and now its looking like a piece of cake! it looked a whole lot harder a couple days ago when i only had it jacked up enough to change the oil.
thanks guys for helping me realize this
Old 12-26-2012, 01:28 PM   #431
made2drag
made2drag's Avatar
since i have the 4.3 i think its even easier to get these off. look how short and small these pans are.
http://www.summitracing.com/parts/rn...8/media/images
Old 12-26-2012, 02:32 PM   #432
made2drag
made2drag's Avatar
thanks bruiser!
Old 12-26-2012, 07:42 PM   #433
68Timber
I know the pieces fit
68Timber's Avatar
Originally Posted by made2drag View Post
thanks bruiser!
No problem! Anytime you need a hand with something just holler, I'd like to see your trucks in person anyway.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-26-2012, 08:14 PM   #434
made2drag
made2drag's Avatar
sounds good!
Old 12-26-2012, 11:03 PM   #435
54Caddy
GM Addicted
54Caddy's Avatar
I wasn't aware that you had a v6. Well rip that out now and add the extra 2 cylinders. Just kidding. Ill try and find a one piece gasket for that.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 12-27-2012, 09:50 AM   #436
made2drag
made2drag's Avatar
i had to go to orielly last night and asked about the one peice....they had it. felpro one piece rubber=29 bucks. now waiting on ups to bring the oil pan. i have all the bolts off on the drivers side and will get the rest off today in between family stuff and my doc appointment. arent doc appointments always on a day when its inconvienent?
Old 12-28-2012, 02:43 AM   #437
made2drag
made2drag's Avatar
finally got it on....and i got an added bonus...i saw that silver sticker which lets me know the guy before me was telling me the truth about the crate 4.3......
thanks guys
Old 12-28-2012, 02:45 PM   #438
made2drag
made2drag's Avatar
Old 12-28-2012, 02:48 PM   #439
made2drag
made2drag's Avatar
Old 12-28-2012, 02:49 PM   #440
made2drag
made2drag's Avatar
after a test drive for about 30 mins, i checked several times and no leaks....
Old 12-28-2012, 03:13 PM   #441
mooseknuckles
mooseknuckles's Avatar
thats good news..
mooseknuckles is offline   Reply With Quote
Old 12-28-2012, 03:38 PM   #442
luifer76
luifer76's Avatar
those one piece gaskets work pretty good i use them on all my trucks and never have problems.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 12-28-2012, 04:51 PM   #443
54Caddy
GM Addicted
54Caddy's Avatar
Told you it was easy man. Now one small charge for the advice. Come bag my truck hahaha
..Mac’s Garage..
IG:MacsGarage
Old 12-28-2012, 08:10 PM   #444
made2drag
made2drag's Avatar
easy? ....not easy for me...you're the man if you can do these in 2 hours!
id much rather bag your truck than do another oil pan! lol
thanks again 54caddy your instructions were dead on!
Old 12-29-2012, 09:30 AM   #445
watahyahknow
watahyahknow's Avatar
naaah its eazy and speed comes after you get used to wrench on stuff , a lot of people are afraid to do thing like work on wiring but if you keep youre head on and go slow with help of a scematic or shopmanual it isnt realy that hard
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 12-29-2012, 10:06 AM   #446
bloodybigblock
bloodybigblock's Avatar
glad u got it fixed man, bout time ;-)
bloodybigblock is offline   Reply With Quote
Old 12-31-2012, 01:44 PM   #447
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Truck turned out pretty good keep up the good work.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-01-2013, 07:38 PM   #448
made2drag
made2drag's Avatar
thanks
Old 01-01-2013, 09:09 PM   #449
bikeman59
Very nice work.
Project: 1980 Chevy SWB
DD: 1999 Chevy Tahoe, lifted on 33"s
Toy: 1996 HD FLSTC, custom by me
bikeman59 is offline   Reply With Quote
Old 01-01-2013, 09:51 PM   #450
made2drag
made2drag's Avatar
Originally Posted by bikeman59 View Post
Very nice work.
thanks man
