05-02-2014, 09:31 PM | #426 |
Re: 1957 Chevy truck re-rebuild
The door panels look real nice.
Kim |
05-02-2014, 10:42 PM | #427 |
I like your core support and bumper mounts. Nothing has been said about them.
05-03-2014, 12:12 AM | #428 |
Now that things are coming along in the paint department I'm getting a little more excited.
The stainless work was something new to me and was quite a learning process. Once I started to figure it out I could see it was gonna be exactly what I was looking for to get the black interior to "pop" so to speak. butchp mentioned the core support and the front bumper mounts. Both of those were done before I got the truck, they worked well so it was something I didn't have to mess with. I know there are different ways to connect the Camaro sub-frame on these trucks. Who ever did this swap back in the "80's did a nice job. I know when I first got a look at this truck it took me a while to figure the swap, it was the first time I had dealt with such a thing. A while back I posted some pics where I did clean up the end where the frames connect. I wanted to taper the Camaro frame to meet the truck frame. I was looking for a near seamless union of the two. Now that the paint is finished I'm happy with the blend of the two frames. For what ever reason the digital camera doesn't like taking pictures of just black, it always seems to pull in other reflective colors and it turns out grainy. I think at this point anyone who looks underneath might just accept that the frame is one piece with the blend. Thanks again for all your support, now that things are happening pretty quickly I'm gonna be posting more pics, hope you all enjoy.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
05-03-2014, 10:57 AM | #429 |
That's a real nice looking transition.
Kim |
05-03-2014, 06:33 PM | #430 |
The door panels look great. Well done!
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
05-03-2014, 08:25 PM | #431 |
A320 Pilot/USAF Retired
The frame looks fantastic!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
05-03-2014, 09:37 PM | #432 |
ChuckDriver, Nev68, Kim57 Thanks all, I can honestly say.... Damn, now this is starting to get exciting.
As I mentioned before, it was a constant up hill climb, but now it's starting to go forward on it's own momentum. Sure it had it's moments over the last couple years, but now it's happening. More pics coming tomorrow. Jim
05-04-2014, 11:28 AM | #433 |
05-04-2014, 01:47 PM | #434 | |
I've got more pictures so I'll get right to them. The flat floor was an issue with me since I wanted the B&M shifter to be at a comfortable height. I had to create a stand, or hump to raise the shifter. I started by cutting a large piece of material and only gluing the top to hold the material in place. One the top was secure I sprayed glue to one side at a time. I did use the heat gun to speed up the adhesive then pulled the material down over the side. I have already put the material on the cup holder......holder. With the material attached I had to see how it all looked together. The final piece of stainless I made was the flat that surrounded the shifter and cup holder. It was a little nerve racking while I made it. I think sometimes it's not so much the difficulty of fabricating something that is the nerve racking part. For me ,sometimes it's the final look and is it necessary to take time to create what I'm working for. Basically, is it worth the time to make. In this case the top stainless piece was well worth the effort, it really completes the look. The cup holders are being sent off to be chromed. I considered painting them silver to match the silver that will be on the outside of the truck but the chrome will give a much better "pop", much the way that the polished stainless does.
05-04-2014, 06:38 PM | #435 |
Jim the console and shifter box came out nice.
I need to come up with something for a cup holder. for mine Rich |
05-04-2014, 06:41 PM | #436 |
console looks good
couldn't make polished ss cup holders on the torchmate?
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-04-2014, 07:19 PM | #437 |
Baldeagle SR, cup holders, 30 years ago, never gave it a thought, today, gotta have cup holders. My how our priorities change. Lol.
_Ogre, yes I could have..... The top ring would be no problem. I didn't have any tube close to the right size, around 3 1/4 " . I was determined at the moment to make these so I used 3" exhaust pipe and graphed in a small section to get it to the diameter I was looking for. I did think at the time that I'd be happy with paint, but at this point I know I wouldn't be completely happy with paint. I called Pauls Chrome as advertised on Classic car show, gonna give them a try. I know it'll probably be expensive but at this point, I'm not stopping now. Jim
05-10-2014, 12:00 AM | #438 |
Now that I think I've got the interior vinyl work figured out I'm going back to priming and paint.
I've been spraying the satin black but now it's time to go to gloss black. Basically everything pertaining to underneath and suspension is going to be stain black, most everything above that is going to be gloss black. The first items I'm going to use gloss black is the inside of the front wheel well panels. Problem is, I want the bottom side of the panels to be satin black, so I will spray the satin black first. I've welded all the unneeded holes and removed most of the bumps and wrinkles. Then filled and block sanded and got the sprayed with a coat of epoxy primer. Now the bottom sides are stain black. I didn't overly focus on getting the backsides free of bumps and wrinkles, I mainly cleaned up the bad and obvious ones here. I allowed them to dry for a couple of days then carefully taped off the back sides. Especially being sure to cover over the bolt holes. Then thoroughly covered the backside. Then the front got a coat of epoxy primer. If you never sprayed base coat, clear coat be prepared for the flat finish of the base coat. It will be just a fast drying color base. Shortly after comes the clear coat. More to follow....
05-10-2014, 12:06 AM | #439 |
Those came out real nice.
Kim |
05-10-2014, 12:22 AM | #440 |
05-10-2014, 11:28 AM | #441 |
Love how you tied the console to the doors with the trim piece. Hope my body paint looks as good as your frame!!! Keep the photos coming. dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
05-10-2014, 06:15 PM | #442 |
Ok, you asked for more photos.....
The whole idea with the inner panels is I like how they ,have so much flat area and I also like the bead design that is pressed into them. With this next picture I realized how the silver and the chrome of the engine will reflect if the panels are gloss, as glossy black as they can be, so that was my goal. Smooth what I could and get the best finish I could. Although the panels looked good in clear, I had to go to the next step. I believe now a days it's called cut and buff. Back in my time it has color sand. Either way, I had to get rid of most all of the imperfections in the finish. It starts with 1500 then 2000 grit paper. Wet sand till the surface is clear of all the bright spots you see here. And here. Til the are looks like this. I use a clear coat heavy duty compound with a 3M foam pad til all the fine scratches are gone. Then a different fresh foam pad and glaze buffing compound. Nothing better than seeing a crisp clear reflection looking back at you when done. This should give me the reflective finish I'm looking for under the hood.
05-10-2014, 07:33 PM | #443 |
Those are beautiful.
Kim |
05-11-2014, 01:13 AM | #444 |
They will be a lot easier to clean too.
Rich my build http://67-72chevytrucks.com/vboard/s...d.php?t=576185 |
05-11-2014, 11:39 PM | #445 |
those looks excellent, nice work.
05-12-2014, 10:05 PM | #446 |
Slick!!
05-12-2014, 11:15 PM | #447 |
Wow, that is nice, should reflect just like you want.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
05-12-2014, 11:47 PM | #448 |
Thanks all. I wanted the utmost reflection from these panels so the extra work was planned and was worth it. The panels were also a test spray for this particular paint.
I've seen many different paints do many different things. For example, I've seen some that stay smooth and clear once dried. I've seen some that once dry they haze over. Some that spray nice and flat then once dry, seem to orange peel after drying. This base coat clear coat system sprayed nice and flat and had good clarity. Next day it was ok, but lost some of it's clarity. My next concern was were I've sanded and buffed paints in the past, then have the finish loose some of it's clarity a couple of days after the sanding and buffing. Although this paint lost some of it's clarity after painting, it looked fantastic after sanding and buffing, even after a couple of days. The next test was leaving the panels in the sun for a couple of days and the panels still held their clarity. It looks like I'll be sticking with this brand with the rest of the truck painting. What brand? I'm almost embarrassed to say..... Summit Racing. I know it's either Kirker or Sherwin Williams but it seems to fill my needs very well. I believe it's probably the same as Eastwood is selling, the difference is.... Summit sells more colors in quart size. For instance I will hardly need a pint of red, Eastwood only has Gallon size of red. Other wise, the painting of odds and ends keeps on going on.......... Thanks for checking in, Jim
05-13-2014, 12:18 AM | #449 |
jIM I HAD THE SAME PROBLEM WITH MY CLEAR COAT. I FOUND THAT napaS CLEAR WORKED BESt FOR ME It stayed shiner than the Kinkers that I used, I still have to sand and buff most of my truck. Rich Bald Eagle SR
05-13-2014, 09:52 AM | #450 |
The parts are looking real nice.
Kim |
