05-08-2015, 01:21 AM | #426 |
Re: 71 4X4 Frame off Restoration
I think i'd need some ear plugs to ride in your car! it does sound wicked!
Nice to hear the house is done too!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
05-08-2015, 03:27 PM | #427 |
I agree on the noise Once I get it drivable I will have to look at what to do about the noise. I have my finger crossed getting it running in the next 2 week. I have a nother transmission on the way this time installing 727. only bummer is I have to have drive shaft made to fit.
05-09-2015, 01:56 AM | #428 |
Finally back in my house for the first time in 8 weeks after the flood. Pictures are of the AC pump and brackets that raise it up.
05-09-2015, 08:14 AM | #429 |
That really is the best setup for our trucks. Nice work! Keep the pics coming!
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! |
05-09-2015, 10:39 AM | #430 |
Looks good. After all this work on my trucks crossmember I think I am going this route. Did you get the relocation kit from vintage air with the compressor?
And nothing beats home... Glad your back home!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
05-09-2015, 03:20 PM | #431 |
05-10-2015, 07:19 PM | #432 |
I got some work done today and welded up my headers so they fit. I wish I did what I did on the left side for the right. left side I cut the why pipe loose and rotated it in about 3/8" and was able to grind the piece I cut out and reuse it. Now if I can just find the collectors for the headers I could start the exhaust
05-11-2015, 08:46 PM | #433 |
Nice work!
05-11-2015, 09:03 PM | #434 |
05-12-2015, 10:31 AM | #435 |
Nice job on the headers. Such a shame they had to be cut, but whatchagonnado?
They fit now. Can't wait to see the body all straight and ready to go on chassis. Chris
05-21-2015, 07:49 PM | #436 |
I found my exhaust collectors on Monday while looking for the rear drive shaft yoke and started working on the exhaust this week. I bought an 2.5" exhaust kit from Summit from Magna Flow and it does not fit the headers to the back T-case what so ever. I ordered some tubing and bends from Summit and hopefully the tubing will be here by Friday as I have 4 day week end I can get some work done. Friday afternoon my nephew and I are going to fire up my car finish breaking in the cam and hopefully drive it around the block. then I have the get the front end aligned.
05-21-2015, 08:45 PM | #437 |
Just got confirmation that Summit order will be delivered Friday by end of day.
05-21-2015, 09:00 PM | #438 |
Nice. Just in time.
So between the Sattelite tranny swap and the truck exhaust fab you should have no problem keeping busy this weekend. BTW - do you have a name for your truck build? Posted via Mobile Device |
05-22-2015, 08:02 PM | #439 |
Great fab work. I've never seen a suburban turned into a crew cab truck but it looks like it's coming together nicely. Is there a reason you decided not to go with a diesel power plant or at least a big block? Or is this truck more of a cruiser? Either way it will look sharp when it's done. Do you have a color in mind for when it hits the paint booth?
My names Tye. No Chevy right now |
05-22-2015, 08:04 PM | #440 |
6>8 Plugless........
Nice work on your headers, and congrats on being back in your house!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-23-2015, 04:00 PM | #441 |
No name for the truck Mr. D
Truckguy99 I did pick colors see attached picture. I would like to put a diesel engine in they are a lot of money and hard to find. I went with the 5.3 as the are easy to find fuel mileage better that BBC. Thanks Dieselwrencher |
05-23-2015, 04:10 PM | #442 |
So I finally got the car running. Ran it for 20 minutes like Hughes Engines recommended started checking timing and got to put the tranny in gear all going well then Bryan noticed oil leaking under the car. Shut it down and again the tranny leaking from the bell housing not as bad but its leaking. Went to start the car to move out of the shop and it won't start only getting 6 volts to the dissy for some reason.
The exhaust parts I got from Summit are very nice polished stainless steel I should have built the exhaust system from Summit parts. now I have some work to get done. |
05-26-2015, 08:53 PM | #443 |
Man, sorry to hear about the set backs with the car! I know that is a pita. Hang in there man!
05-27-2015, 01:05 AM | #444 |
I posted picture on Friday of the exhaust system and it went by by. so here it is Again. started installing the Magna Flow exhaust system Friday spent 3 days and almost finished it. it did not fit from the headers to the T-case so I ordered parts from Summit nice part Summit sent me polished stainless steel. the only parts I did not modify is the X pipe and mufflers. all in all it can put nice should sound good. I did order 4 more hangers from Summit only 4 came in the kit. I used 2X6 to support the X pipe and mufflers the n built the rest to fit.
05-27-2015, 01:17 AM | #445 |
Looking good. Did you mig weld the joints on the stainless steel tubing? What kit did you order?
05-27-2015, 02:35 AM | #446 |
Wow Dave, that's looking really good. Your build is finally coming together nicely.
Won't be long now and you'll have the cab back on and you'll be up to your ears in wiring! Posted via Mobile Device |
05-27-2015, 10:13 AM | #447 |
I used stainless steel wire in my mig welder with Argon C02 mix. I still have to grind and clean up the joints witch is a lot of work.
05-27-2015, 10:18 AM | #448 |
I got a call from Sky Yesterday and the body work is done I will be picking up the cab and bed end of the week. Now I need money for paint.
05-27-2015, 12:54 PM | #449 |
cool I have never tried SS wire on a mig. What exhaust kit did you order? Was it a universal kit?
05-27-2015, 01:22 PM | #450 |
The kit was for 1967 to 1972 C10 C20 8' bed was the closest one I could find.
