#426 |
Re: 49 ls1
Love your truck and your fast work! I can see your son "needing" a 4.8 or a 5.3 in his truck. They really are great engines.
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
#427 |
![]() Join Date: Jul 2012
Re: 49 ls1
Great build! Really enjoy the creativity and solutions to issues. Plus nice pictures.
Thank you for sharing. |
#428 |
![]() Join Date: Apr 2010
Re: 49 ls1
Thank you all.
If anyone is interested, I just started an S10 frame swap thread. I'm not finished with it by a long shot, but I thought we could get all that information on a one stop thread. I'm including drawings and dimensions on everything, as well as how to pics. Here's a link. http://67-72chevytrucks.com/vboard/s...=1#post6724000
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
#429 |
Re: 49 ls1
sarge, coming along great. I'll be looking into those calipers. I'll be needing some soon. Visor looks killer, they always add that extra touch to these trucks.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#430 |
Re: 49 ls1
Thanks 99. I got the calipers from Summit, they are $55 each I think, but you need about $40 of adaptors and hoses to make them work. PM me if you want a parts list.
#431 |
Re: 49 ls1
Did you make the visor permanent? I'm toying with using the one I have, but haven't decided how to mount it yet or to make it detachable or permanent.
1949 GMC PU http://67-72chevytrucks.com/vboard/s...d.php?t=608120 1966 C10 http://67-72chevytrucks.com/vboard/s...06#post6601806 1966 C10 SB Custom Cab, Fleetside, BBW. 1968 Chevelle SS 396 1937 Chevrolet Coupe |
#432 |
Re: 49 ls1
Billys68SS; the visor is not permanent. I am using stainless 1/4" button-head allen bolts and lock washers through the pillar. I will seal them when it goes on for the last time.
Here's a teaser pic... did some work on the pass front fender last night. Thought I'd see how it'll look when it's done.
#433 |
![]() Join Date: Mar 2011
Re: 49 ls1
Sweet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#434 |
Re: 49 ls1
Loving your truck, keep it up. I mean down....
#435 | |
Re: 49 ls1
#436 |
Re: 49 ls1
True professional!
#437 | |
Re: 49 ls1
those guys have solved a lot of questions!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#438 |
Re: 49 ls1
Misc parts needed are the harness, PCM, tacc module that is mounted near the brake booster and the gas pedal, and the connecting jumper harness.
#439 |
Re: 49 ls1
Thanks guy's Ill jump over to the "LS Swap" section
#440 |
Re: 49 ls1
Yup, what AKnovaman said... If the trans is 4x4, don't waste your time trying to convert it to 2WD... not cost effective When you are ready to do your harness work, and have your PCM programmed, jump over to LT1swap.com, Brandon has a VERY nice writeup, and is probably the most knowledgeable person I know on the subject.
#441 | |
Re: 49 ls1
“I would rather live my life as if there is a GOD and die to find out there isn't, than live my life as if there isn't and die to find out there is.” |
#442 |
Re: 49 ls1
This should help for those wanting to convert a factory harness to standalone config.
https://spreadsheets.google.com/spre...KSkg2Z3c&hl=en |
#443 |
Re: 49 ls1
Oh wow that's great info THANKYOU!!
#444 |
Re: 49 ls1
Sarge,is this a cover to access your brake master?Are you just going to screw it down for access?
And one more...What is the door latches you welded in,and what did you do to align them properly in your door when welding them in? |
#445 |
Re: 49 ls1
Charliesheen; Yes, the access cover is for the under floor dual reservoir. I'm not screwing it down though. The 1/4" rod I welded on the underside locks it in place nicely. Door latches are bear claws. I adjusted the doors so that the wind lines and gaps were where I wanted them. Then carefully marked the "door side" of the bear claw and cut/welded them in. The striker side is adjustable, that way final tweaks can be made.
Not much photo evidence of progress on this one this week. Working on a customer truck. I'll start a thread on it when it's a little further along.
#446 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: 49 ls1
Great work buddy, absolutely amazing.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#447 | |
Re: 49 ls1
#448 |
Re: 49 ls1
That may not be till this winter! LoL
#449 |
Re: 49 ls1
Any hints or candidates for the door lock and power window equipment? A mishmash of fab and components?What have you gone with on past projects that you have found decent?( OK-I know Christmas is coming,haha,excuse the child like impatience).
#450 |
Re: 49 ls1
No worries. I intend to use a "universal flat glass window riser set". Since I have Bear Claw latches, I'm going to swap them out for power bear claws.
