#426 |
Re: My suburban's Twisted Little Sister
Interesting configuration on the back floor section.
Can't wait to see it all together, like the direction, Im just having a hard time fully understanding the whole enchilada. Dig those beaded panels. Totally envious. |
#427 | |
We had short day today but we did make some gas tank straps and mounting brackets. Then since we will be moving on to the firewall soon we dug out the bare block and transmission case to use for mock up
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#428 | |
![]() Join Date: Aug 2013
#429 |
This is where it really starts to get interesting
V12 power ![]()
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#430 |
So cool I forgot your using a jag V12
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#431 | |
Our first attempt at installing the motor ran into a few obstacles. The oil pan hit the motor mounts, the cam cover hit the firewall and the transmission hit the tunnel. So out comes the cut off wheels.
#432 |
Mmm, nice. Looks like some massaging is goin to be in order. I don't think it's going to run right in that position. Lol.
#433 |
We started cutting just a little from the firewall above the transmission. We soon realized we needed more more space. Then we cut a larger opening up to the wire gutter.
#434 |
Thats more like it.
Motor/trans in, level. Build truck around it. I like it. |
#435 |
Sounds familiar: motor, trans, cut body to fit. That looks so cool sitting there.
#436 |
![]() Join Date: Jul 2012
I always love the newbie question of...Can I fit xxxxx engine in such and such vehicle....and from now on I can answer....sure you can if you can do this....and send them here.
Such cool and skillfully determined fab work 65! |
#437 |
thats cool ..is the motor sitting on the rack and pinon
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#438 | |||||
To make the motor mounts we started by making bracket to bolt to the block. Next we bolted stock chevy motor mounts to the bracket. Then we bolted them to the block
#439 |
Nice work dale
#440 |
Lots of progress... I've been really busy (and stressed
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram ![]() |
#441 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Awesome build. I know all about getting a monster motor to fit. Lot of tunnel work.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#442 |
Here you go Dale
They're 8" wide and 14" long, stamped from 1.4mm (from memory), ones a bit rusty but will clean up fine, done on the original Abbey Panels tooling. And below in their natural habitat
Getting old sucks.............but it sure beats the alternative |
#443 | |||
Thanks Nik
![]() Quote:
Yesterday we got the motor mount frame brackets welded in. Next time the motor comes out we'll box them in. Today we removed the passenger side of the firewall to get ready to install a new one.
#444 |
When we cut out the firewall we found more rust that we had to remove. Then when we cut that out we found an apartment complex for rodents above the kick panel vents. And since we had lots of access we cut off the bottom of the kick panel. We finished today tacking in a patch panel on the front of the vent box.
#445 |
Nice job Dale. Stupid mice. Whats the story with the yellow '68? quad cab?
#446 |
Looks good dale, I was wondering as well about the yellow truck
#447 | ||
Today we got the patch panel welded
#448 |
Looking good stay at it
#449 |
Thanks Pirate
Friday we replaced the section that we cut out of the kick panel. Today we started by patching one of the holes for the heater intake.Then we made panels for the toe board and firewall and got them tacked in place
#450 |
Like quite a few builds on here, you continue to be my touchstone of sanity.
I am on week two of a seven week classroom training course in haematological anti-coagulation and find myself looking in on threads with much envy. I guess this will pass and I will be able to pay my mortgage and buy bits for my engine and do my truck further. Thank you as always for posting up and sharing. There.......... I feel better.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
