Old 03-18-2016, 08:59 PM   #426
Advanced Design
Advanced Design's Avatar
Re: Blake's 67 GMC stepside build
That was pretty trick on the gauge cluster. Looks good.
Advanced Design is offline   Reply With Quote
Old 03-19-2016, 09:14 AM   #427
reaper71
reaper71's Avatar
Oregon 67 , JGood , Kees and Doug thank you very much Guy's This has been a ton of work and is super hard to balance out 2-3 vehicles at a time and keep everyone happy!
Mark...
reaper71 is offline   Reply With Quote
Old 03-19-2016, 09:19 AM   #428
reaper71
reaper71's Avatar
As far as the cluster goes we wanted the advantage of having GPS for the speedo (no cables/wires) to run to the transmission.
also having the option to totally customize the gauges themselves, at night the numbers will be blue and are LED. as are the indicators.
Mark...
Old 03-20-2016, 10:00 AM   #429
Rod Run
Rod Run's Avatar
I've got a set of Speed Hut gages for my build too. I also went with a GPS speedometer, but I ordered the larger sized ones.
I have a stock cluster that I am modifying, but mine only had two gages in it.
Yours came out well.
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-22-2016, 09:41 AM   #430
reaper71
reaper71's Avatar
Thank You!
So you are using the quad gauges I'm guessing?
if so I used a set of them in the (John's LS 49 dodge build) They are really nice Gauges,easy to wire, very accurate and easy to program to sending units.
And I have also bought A set for my (Orangepeel Build) So Far I have bought for customers or my own projects A total of 5 sets!!
Need to be a dealer
Mark...
Old 03-25-2016, 12:19 PM   #431
Rod Run
Rod Run's Avatar
Originally Posted by reaper71 View Post
Thank You!
Need to be a dealer
Mark...
I'm not using the quad set-up. I'm modifying my stock cluster so I will be able to fit all 6 separate gages. I always like to take the more difficult route
Old 03-26-2016, 09:36 AM   #432
reaper71
reaper71's Avatar
Ok Gotcha!
Yeah me too
Mark..
Old 03-28-2016, 09:59 AM   #433
reaper71
reaper71's Avatar
Pic #1. The column painted the new interior color.
Pic #2. The A/C vents painted.
Pic #3. The transponder for the GPS was painted as well. the new Dash pad was installed (Dark shale)
Pic #4. The view of the inside with some more progress, column,controls and A/C unit in place.
Mark...
Old 03-29-2016, 06:31 PM   #434
yj4000
yj4000's Avatar
Lookin' good!!
Ryan.
yj4000 is offline   Reply With Quote
Old 03-30-2016, 09:44 AM   #435
reaper71
reaper71's Avatar
Thank's YJ!!
Old 04-01-2016, 09:41 AM   #436
reaper71
reaper71's Avatar
Pic #1.I assembled the bed to get it prepped for the bed liner.
Pic #2. This was after numerous Hrs of taping and masking followed by light sanding.
Pic #3. This was just after shooting the coating. I used tint your Hippo liner It comes clear and you use single stage paint to tint it the color you desire.
Pic #4. After letting it dry over night and unmasking this was the final product. It came out super nice!!
Mark...
Old 04-01-2016, 06:32 PM   #437
jim-bob
...subscribing!! (I was reading a post referring someone to a thread showing where all the mounting hardware (rubber donuts; big washers; etc,etc..) goes when putting the cab and bed back on the frame, I think LOL..well I undoubtably got lost BUT I sure have enjoyed reading this one!!! Thanks
jim-bob is offline   Reply With Quote
Old 04-01-2016, 07:43 PM   #438
reaper71
reaper71's Avatar
Thanks for checking out the build...
Mark...
Old 04-03-2016, 12:17 AM   #439
swamp rat
swamp rat's Avatar
Nice, would like to see different pic's of that liner eventually, maybe outside?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-03-2016, 08:39 AM   #440
Advanced Design
The color contrast between interior and exterior looks very good. Bed liner that can be tinted is a good idea and new to me. http://www.tcpglobal.com/DOM-BCYH_5....g#.VwErffpHarU
Looking good Mark!
Old 04-03-2016, 09:43 AM   #441
reaper71
reaper71's Avatar
Will do mike as soon as I can get it outside I'll try and get something.
Mark...
Old 04-03-2016, 09:48 AM   #442
reaper71
reaper71's Avatar
I was a bit skeptical when I was told it would match perfect, but was Very Pleased with the turn out!!!
With you using the same paint code of your vehicle (single stage) it's really impressive how it worked. And opens up doors for options on spraying the bottom of a cab or body without having to go over it with body color paint!
Mark...
Old 04-14-2016, 09:43 AM   #443
reaper71
reaper71's Avatar
Pic #1. small update, finished up the exhaust.
Pic #2. 2nd view.
Pic #3. All painted and installed for final time.
Next was the gas tank,fuel pump/filter and lines. followed by the brake lines.
Mark...
Old 04-14-2016, 11:18 AM   #444
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
you are reaping it dude Might have to update you to reaper67
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 04-14-2016, 06:38 PM   #445
Advanced Design
Nice work! Is that the speedway kit? It looks like you butt welded some S's together? Tig?
Old 04-15-2016, 09:31 AM   #446
reaper71
reaper71's Avatar
Thanks Oregon! The 71 stands for my Birthday
Yes Doug it is a Speedway kit and Yes it was all Tig welded.
The S's are actually 2 of the "u" bends then cut in half rotated then welded.
Mark...
Old 04-15-2016, 09:56 AM   #447
reaper71
reaper71's Avatar
Pic #1. The bed being set in place.
Pic #2. Finally looking like a truck again!
Pic #3. Another view..
Pic #4. And another....
Pic #5. Last one!
Mark...
Old 04-15-2016, 10:05 AM   #448
reaper71
reaper71's Avatar
And another update I acquired a 36 Chevy project...
Plans are 5.3 and A triangulated 4 bar.
Not a bad car needs some TLC and freshened up.
Mark...
Old 04-15-2016, 10:31 AM   #449
oldman3
oldman3's Avatar
38 son...Dad
oldman3 is offline   Reply With Quote
Old 04-15-2016, 11:09 AM   #450
Oregon 1967 GMC
Thanks Oregon! The 71 stands for my Birthday Mark...
And '71 is a very good year mister reap! Ah to be young again. Keep up the good work, looking awesome.
Hey man
