Old 11-17-2016, 11:02 AM   #426
Wide Open
Re: Let's Build A 1 Ton Crew Cab 4x4
Nasty - The front rotor you are using is from a SRW or DRW Dodge?
I'm pretty sure from your pictures the hat is too deep to use on my front axle
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 11-17-2016, 11:52 AM   #427
NastyBuzzard
NastyBuzzard's Avatar
SRW as far as I know.
Yes I can guarantee it is, you would have to find a rotor same OD as the dodge or similar but as deep as the stock one.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 11-17-2016, 08:45 PM   #428
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I like the brake upgrades. On their site, they have no pic or description of the kit. Was it really $1253.95? If that's right, what all did it come with? Loaded calipers, mounting brackets, and rotors?
http://www.torqaxle.com/products/bra...-brake-kit.php
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-17-2016, 08:54 PM   #429
NastyBuzzard
What they list is that $1300 kit that I can only assume comes with the brackets, rotors, calipers, pretty much everything it would take. However, I called them and told them I already had all the brake parts and just needed the brackets. They just sold me the brackets for about $225 shipped. They agreed they should maybe start advertising them.
Old 11-17-2016, 09:31 PM   #430
jott_06
Camaro Club
jott_06's Avatar
I got on here to see if you figured out your rear rotors because I just watched them do a disc brake upgrade on Dirt Everyday and they put the rotor on the back side of the hub and pressed the studs through the rotor and hub. Looks like the dually rotor worked for you though
jott_06 is offline   Reply With Quote
Old 11-17-2016, 09:34 PM   #431
NastyBuzzard
Yes it did! You can do those other brakes cheap but they suck. Most don't have parking brake but if you use certain calipers you can have parking brake that you manually have to adjust and it sucks. What I'm doing should be worlds better.
Old 11-19-2016, 09:52 AM   #432
y5mgisi
Second Chance Program
y5mgisi's Avatar
Glad the dually rotor worked out!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 11-21-2016, 08:32 AM   #433
NastyBuzzard
I got one hub drilled and new studs installed!
I also got the PS kingpin out. It was not as easy as the DS. I had to beat my tool with a mini sledge both hands full force a few times before it budged the tiniest bit! But once it did move the fight was over! This one is scarred a bit more than the DS as well.
I mounted the rim on the rear to see if the original studs would be adequate. (I was told they would be.) They aren't, I wonder if I will need to drill them out and use the same studs I did for the front or if a longer stud exists for the 14BFF already that doesn't require drilling.
I also saw this truck on facebook. I had heavily considered these wheels for my truck but was unsure. Well, they don't look half bad on a square!! Requires 8x6.5 to 8x170 2" adapter/spacer but still.
I started putting the new Ujoints in my half shafts. What a pain in the ass. Also started cleaning up my knuckles. I need to get all seals/bearings and what not on order.
Old 11-21-2016, 11:08 AM   #434
83GMCK2500
Looks like some good progress. What size is the allen to remove those kingpins?
Some of the 2011+ wheels are being made in the classic 8x6.5 pattern in the aftermarket. I've seen them on another forum but never got the name of the company, I think the guy said he found them on ebay.
Do you have a picture of your rear hub & studs handy? I might be able to poke around the parts catalog and see if a longer factory stud exists.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 11-21-2016, 12:04 PM   #435
NastyBuzzard
7/8 allen wrench for the kingpin. The one I bought was $35 shipped from MCmaster carr but it really did make it pretty easy to remove the king pins.
Here is the pic, those are the stock rear studs. Normally they have to go through the drum then the hub now they go through the hub then the rotor so that has to be considered with knurl and what not.. I need about 1/2" or so more of threads at the least.
Old 11-22-2016, 01:40 AM   #436
83GMCK2500
Still have 9/16" studs, right?
Eyeballing your tape your's look to be ~3" long. That is stud: 3988358 (GM P/N)
There exists, stud: STUD, RR WHL (SERRATED) (9/16-18X3.59 LGTH); P/N: 355815 Dually application, and they sound like the length you're looking for. There is a guy on ebay selling 4 packs for $4.55, looks like cheapest option.
Devin
New Daily, the '96
Old 11-22-2016, 08:07 AM   #437
NastyBuzzard
Yes still 9/16, I would never step down a size and 5/8 seems way too big. I thought about going metric but I really like the 9/16 thread.
I will look into it for sure! That's nice and cheap compared to the ones I run up front now.
Old 11-28-2016, 09:01 AM   #438
NastyBuzzard
I got the new UJoints in the front shafts. It took me way too long even with using a press.
I picked up some DRW studs bc I needed longer studs for the rear. Man they would be perfect to use up front on the 60 if they were threaded all the way... I was hoping they could work as to not have to drill out the dana 60 hubs but looks like no other real option besides the 610-303 studs. Oh well it was a thought!
Also, I have spent a lot of mula on the front end, all new bearings, seals, ujoints so I wanted to pop the cover and make sure I didn't have pitted gears or the teeth be thinned out or anything. Looks good to me though!
So what studs or whatever I need to get for the king pin stuff? I have heard a few recommendations to swap over to studs. I am not a D60 expert.
Old 11-28-2016, 02:57 PM   #439
Flatpat
Flatpat's Avatar
I put High Country wheels on one of mine. Looked pretty good need 8x6.5 to 8x180 I used 1.5" all the way around but on a 4x4 I'd probably go 2.5" in the rear.
imag
I may have a problem.. 1976 K20 Crew, 1978 K30 Crew, 1981 K30 Crew, 1985 C30 Crew, 1987 C30 Dually Crew, 1988 R3500 Crew, 1990 R2500 Crew, 1991 V3500 Crew, 1991 V3500 Dually Crew.
Flatpat is offline   Reply With Quote
Old 11-28-2016, 03:07 PM   #440
NastyBuzzard
Those look amazing!! & Damn I am jealous of your yard! Those new model wheels fit the crew cab just fine. I really like my dodge 17s but I would love to step it up to 20" wheels or so but nothing too fancy. However, all $ right now has to go into getting it driveable.
Old 11-28-2016, 03:27 PM   #441
obijuan
studs are nice to have for the ubolt plate instead of bolts because you get full thread engagement into the housing. for the knuckles, i wouldnt use anything but studs.
obijuan is offline   Reply With Quote
Old 11-30-2016, 07:29 AM   #442
mcmlxix
Collector of Projects
mcmlxix's Avatar
wheel stud list from Dorman with all the specs
list
https://static.dormanproducts.com/do...Attributes.pdf
pictures and part numbers
http://www.billavista.com/tech/pdf_i...%20Catalog.pdf
Rich
1972 K5 Blazer CST Click HERE
Old 11-30-2016, 07:33 AM   #443
NastyBuzzard
Very good info thank you.
Old 11-30-2016, 07:46 AM   #444
mcmlxix
mcmlxix's Avatar
Yeah. I made the mistake of reading the Pirate4x4 site and upgrading to 5/8 wheel studs in front.. OVERKILL for me and the level of abuse the Blazer will see. If I redo the front hubs I'll get some metric 14mm studs to match the late model rear end....
Rich
Old 11-30-2016, 07:48 AM   #445
NastyBuzzard
Yeah I saw that and I agree 5/8 studs are insane overkill but I understand the mistakes of reading Pirate4x4 lol. All those beefy upgrades look tempting but I am not doing what most of them do to their vehicles.
Any reason you can see why we couldn't use the 610-194.1 wheel stud (drw 14bolt stud) instead of the 610-303 studs? The 194.1s wouldn't require drilling.
Old 12-05-2016, 08:26 AM   #446
NastyBuzzard
I had a bolt break off in the PS knuckle. I tried to drill it and use an easy out but long story short I screwed up and drilled at an angle and it may be screwed up. Anyone have a spare PS knuckle I can buy? This blows.
I spent all day Saturday though finally wiring up a breaker box inside the shop as well as running wire for my lights, finally!! Those LEDs have been mounted for a year now and never been cut off. No more string lights, finally I can walk in and flip a switch for lights. I am working on doing outlets now.
From this.
To this.
Old 12-05-2016, 11:06 AM   #447
83GMCK2500
That knuckle may yet be saveable. Not sure where your skills begin/end but I'd bet a competent person/shop could weld a nut to that broken piece and get it out, or set it up in a mill and get it out. Would probably have to put a stud in that hole, but I don't think that's an issue. If not, maybe hit up the big offroad forums like Pirate and find someone who upgraded to Dedenbear/Reid knuckles and has the stockers for sale.
NICE lighting. Always makes such a difference, being able to see what you're working on.
Devin
New Daily, the '96
Old 12-05-2016, 11:27 AM   #448
obijuan
I've got dodge and Chevrolet knuckles for sale as pairs if you decide to replace em
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
Old 12-05-2016, 02:13 PM   #449
NastyBuzzard
I think the lighting makes a world of difference! Now if I can get some more outlets! So tired of all the drop cords.
I think it is salvageable too. I am going to try and weld and pull it out. We have a mill at work too I can try but we will have to see. I was just hoping to find another knuckle quick and cheap but no dice.
Old 12-06-2016, 01:03 AM   #450
mcmlxix
mcmlxix's Avatar
I heli-coiled one of the holes on one of my knuckles... but the bolt came out ok...
Maybe just upgrade to some Reid Racing knuckles... only $600 for a pair....
Rich
