12-02-2024, 05:10 PM | #426 |
Re: Previous owner '68
Sprayed the windings with insulating spray and assembled the alternator.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
12-04-2024, 09:58 PM | #427 |
like NEW
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
12-05-2024, 04:56 PM | #428 |
Thanks Zicc.
I received the valve cover decals today. If I have vinyl decals (mylar, whatever...) and they don't have an application layer over them I use low-tack shelving paper in the clear flavor. It helps keep everything lined up and makes installation easier.
12-05-2024, 04:58 PM | #429 |
And the finished valve covers. I'll probably shoot some clear over these eventually.
12-05-2024, 05:07 PM | #430 |
Very nice
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
12-05-2024, 05:11 PM | #431 |
12-05-2024, 06:55 PM | #432 |
12-07-2024, 06:39 PM | #433 |
So I got a rebuilt torque converter slapped on the transmission. It's the bigger one (13"). Glad my flex plate had both patterns.
12-07-2024, 06:45 PM | #434 |
Then I mounted the transmission to the engine. No pics of this, I was too busy for pics. Once I got them together I checked the clearance on the converter and then bolted everything together.
Finally I lowered them into the frame. The 73 up motor mounts seem to have worked well.
12-07-2024, 06:50 PM | #435 |
The transmission mount worked out after some drilling and adjusting. This was a cheap cross member for a squarebody that I had to modify to fit.
12-07-2024, 06:54 PM | #436 |
Then I put the script valve covers on just to get an idea if I like the direction I'm going.
12-07-2024, 07:18 PM | #437 |
lookin real good....
12-07-2024, 07:47 PM | #438 |
Thanks, I'm glad to have the engine and tranny in the frame, now I can work on fuel lines.
12-10-2024, 06:06 PM | #439 |
Looks very nice
12-11-2024, 10:13 AM | #440 |
12-11-2024, 04:21 PM | #441 |
Its starting to resemble a truck again lol.. Nice work
12-12-2024, 10:14 AM | #442 |
Thanks! I started this about a year ago so I need to get busy!
12-14-2024, 04:30 PM | #443 |
Tried the exhaust manifolds on to see if there were any clearance problems. I think they will be okay. Cheap chinese crap... but better than what I had.
12-14-2024, 04:36 PM | #444 |
Ran the main fuel line in 3/8" size up to the pump. Waiting on some fittings to go up to the carb. I have realized that I would have progressed much faster if I would have had a project plan.
Nah, that sounds too much like work!
12-17-2024, 06:35 PM | #445 |
Attached the fuel and brake lines to the frame while waiting on parts.
Also attached the rear shocks, I had to use ratchet straps to get them on as I don't have much weight on the back yet. I know! Looks like scrub-line issues. Pretty good discussion on rear scrub-line issues. https://www.67-72chevytrucks.com/vbo...d.php?t=711026
Yesterday, 09:53 AM | #446 |
Finally got the correct fittings to run some lines. i started on a gas tank vent system, but will have to wait until bed is installed to finish it.
Yesterday, 10:09 AM | #447 |
Then I went to the engine and started bending up hardline for the carb. I do not like bending 3/8" hardline, I wasted about 3 feet before I was somewhat satisfied with the results. I test fitted the alternator to make sure everything cleared and then put a spring stone protector over the line ( mostly to hide the poor bends!)
I used a banjo style fitting with a filter in it so I wouldn't have any rubber line after the pump.
Yesterday, 10:16 AM | #448 |
While I was kinking up the fuel line I had the oil filler tube in the wobble-pop freezer. It drove in easily after an hour or so.
Yesterday, 10:40 AM | #449 |
I had to come up with a way to get the transmission to shift since the truck was originally a 3-on-the-tree. So I bought a Chinese knock-off transmission mounted shifter from ePay. I had to modify it just a bit to fit but it really wasn't too bad.
Yesterday, 10:49 AM | #450 |
I'm not sure the position is just right but at least if fits without the cab! I may end up getting a taller shift lever, I don't know at this point.
I did have to chamfer the top of the drivers side mounting bar because the down lever was rubbing it. I also had to shorten the passengers side mounting bar by 1.5" to get it to fit. Other than that it was fairly easy.
