#4476 |
Re: What did you do to your truck today?
better late than never, but as promised, pics of my front suspension. It is in no way complete,this was the first mock up with tires and bags.
#4477 |
Sorry wrong pic. No airbags installed yet. Basically the rundown, I built my own crossmember and lowered the truck about 4 1/2 inches with stock spindles and control arms. didn't need it to lay out since it will be a driver. Still have to raise engine about 1 1/2 for rack clearance. will box and gussett everything after I fit a cpl more pieces, then make it look pretty, LOL!. Also have all the Painless wiring harnesses laid out,too. Hope to start on the dash and sheet metal work next week. Body going to media blasting while I finish chassis.
Hey guys, all your projects are looking great too! There's alot of talent in this group, just hope mine will stack up. BTW we plan on attending the Midwest All Truck Nats with both projects. Look forward to meeting some of you. |
#4478 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Pulled the back up project out of the back of the shop......started washing it and cleaning it up....might as well start working on that again while the prostreet truck is in the body shop......
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
#4479 |
Looks good!!!
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
#4480 | |
#4481 |
I guess I forgot to attach these.....my bad
#4482 | |
Hammer it out again....
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
#4483 |
Registered Loser
I worked on my truck... sort of. I started to make a replica of my 63 longbed out of Hot Wheels.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#4484 |
Registered Loser
OOOPS! Forgot the pics.
#4485 |
creep that looks sweet....I have around a 1000 hotwheels and I have never seen the burp you have. Are those painted or decals on the hotwheels?
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
#4486 |
got the steering box and steering pump today .and primed and painted the resivor .
#4487 |
Registered Loser
Thanks! I'm assuming you meant "burb" not "burp"? It's a '64 GMC panel with Hersheys logos painted on the sides. I think it was a holiday special.
#4488 |
I grinded some of the usual rusty areas down to bare metal (wire wheel on a grinder, works great) to see how bad they were. No real surprises. I also removed the vertical driprails on the A-pillars since they were rusty anyway. It looks better without them. I don't even know why they were there. Anyway, I gave it two good hours, so that's progress...
#4489 |
Changed my rear diff. oil w valvoline syn blend 80w oil,good thing i did it was pretty dirty!
#4490 |
![]() Join Date: Mar 2011
I removed the air vent panel on the passenger side. Lots and lots of rivets. Now all I need to do is find another one in better shape. Anybody got one that they will part with? I also decided to start repair of my radiator support. I haven't been able to find a used one in any better shape than what I've got for a decent price so I decided to try my hand at repairing the one I've got. It didn't look that bad from the outside but I knew there was rust lurking beneath the mounts like there is on most of these. The rest of the support will be fine, just some surface rust and I'm showing is the worst of the two mounts.
#4491 | |
1962 Chevrolet S/B Fleet side Engine: 283 Transmission: 3 speed manual 2 do list !!!!!! Frame off-2 1/2" front , 4" rear Rebuild engine (or find a 327), 700R4 Trans, relocate gas tank, Bed wood ![]() |
#4492 |
I think the shipping is what would kill it. Now that I've dug in to the old one I'm going to see if I can repair it and practice my fabrication skills. No wait, I don't have any fabrication skills. Well It's something to practice on and the worse thing that can happen is I'll have to find another, but lots of money saved if I can pull it off.
#4493 |
Is there a steel scrap yard near you...usually you`ll find what you need at a decent price..and the right size....done that several times in the past for projects.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#4494 |
Senior Enthusiast
Took it for a ride twice today, just couldn't get enough of the sunshine and unseasonably warm 46 degree temperature.
#4495 |
Same here Mark, 68 degrees outside, same tomorrow....
#4496 |
![]() Join Date: Nov 2010
#4497 |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
We have been pretty warm too. A buddy of mine has been calling it Juneuary.
#4498 |
Finally got all the parts together to do the driver side spotligt on the 63
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#4499 | |
#4500 |
Well had a great work day on the chassis...it's been sitting a while so I didn't want to take any chances....drained the oil poured it back in the top half on each side.....pulled the distributor out and drove the oil pump until it came back up into the pushrods and heads...pulled the plugs ( which was a pain because i had to take the headers off to get at 3 of the plugs,apparently there is going to be a modification of the bolt flange before those go back on )..light spray of WD40 into the cylinders.Polished both value covers and breathers,polished some of the other bits and parts. Rolled it over by hand a bit while the plugs were out and it's all good and ready to go . I hope at some point on the weekend to fire it up and hear it run....
