Old 07-04-2020, 09:04 PM   #4526
MARTINSR
MARTINSR's Avatar
Re: What did you do with your truck today, Part 3
I actually got something done on my truck! WHOOOO HOOOO! It was a screw up mistake that I had done but it's corrected, been bugging the crap out of me.
The door now fits!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 07-04-2020, 11:04 PM   #4527
1project2many
OEM front bar installation continues. Cleaned up the last bracket and installed the bar into the clamps using modified '67 Camaro rear bar bushings. The OE end links are junk so I straightened a set of 94 Wrangler links. Today I took some time to modify aftermarket shock studs so they would fit into the bar. Tomorrow I need to come up with a bushing so the top link can attach to the frame properly.
As a side note the front bar from a 94 ish YJ Wrangler could be a good match for our trucks. If this small OE bar doesn't work out I'm looking at switching to the Wrangler part.
1project2many is offline   Reply With Quote
Old 07-06-2020, 11:16 PM   #4528
mick53
I don't know if this counts but I got my new lathe set up. I have been working the last few weeks on building shelves and moving stuff to storage. I also have raised the elevation on my scrap pile. I have been working on parts for over 2 years and am very close to starting on the girl. I have never run a lathe but that never stopped me before.
mick53 is offline   Reply With Quote
Old 07-06-2020, 11:26 PM   #4529
MiraclePieCo
MiraclePieCo's Avatar
Thanks. I'm going to have to improvise some bars myself.
Today I hooked up a vacuum line to my OEM windshield wiper motor. I was really reluctant to drill a hole in my firewall on which I spent so much time filling holes. The studs go back-and-forth nicely, but we'll see how the 70-year-old motor does with actual blades installed. Still waiting for those via mail order.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 07-06-2020, 11:30 PM   #4530
vintovka
vintovka's Avatar
Very Nice, If its first time may I suggest the book "how to run a lathe" Been using a lathe for decades and still refer to it. Also check level both ways after its been used a couple times you may be surprised,
https://www.amazon.com/How-Run-Lathe.../dp/1614274746
vintovka is offline   Reply With Quote
Old 07-07-2020, 12:22 AM   #4531
nvrdone
so a few weeks ago my fuel gage quit working - it all ways showed full. after running multiple tests I found there was a damaged wire in the harness going to the rear mounted tank. so time to fix it. made a new harness to fix the problem. got it hooked into the dash tonight & run back to the rear end. so more work tomorrow. hopefully will have it finished by this weekend.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 07-07-2020, 08:50 AM   #4532
mick53
Thanks, I have that book and a couple more. I have friends that are machinist and they are willing to help. I used a machinist level to set it. I wont be doing space shuttle stuff. I just get tired of waiting 3 weeks and paying a hundred dollars for a spacer.
Old 07-10-2020, 12:35 AM   #4533
idbeast
I finally got the front bumper all lined up and mounted. I didn't have the front horns at the right angle on the 77 Nova front clip, so it has been interesting!
idbeast is offline   Reply With Quote
Old 07-11-2020, 02:44 AM   #4534
Johns327
Johns327's Avatar
Looks sharp, great color on that truck.
What did you decide on the emblems?
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch.
Johns327 is offline   Reply With Quote
Old 07-11-2020, 05:10 PM   #4535
Russell Ashley
Russell Ashley's Avatar
That's a nice lathe, and that milling machine isn't bad either. I'm feeling a little power tool envy creeping in, LOL.
Russell Ashley is offline   Reply With Quote
Old 07-11-2020, 06:34 PM   #4536
MiraclePieCo
I now have WWW - working windshield wipers.
Old 07-12-2020, 02:12 AM   #4537
idbeast
I decided not to put them on right now, it was a very hard choice.
I would like to thank everyone for your input on the emblems!
Old 07-12-2020, 09:59 AM   #4538
mick53
I'm making a cover plate out of 1/8" 5052 aluminum for my Tremec TKO 600. Primarily this is to solve a housekeeping problem. It's all sealed up but I figure a polished plate will have much better aerodynamics. My etch-a-sketch skills aren't what they used to be.
Old 07-12-2020, 11:13 PM   #4539
MARTINSR
MARTINSR's Avatar
Well after moving 700 miles and flipping my world upside down I am back to my truck in my garage. I got the hood sectioned started (cab is sectioned 2.5 inches and chopped 3.5) just tacked back together, none of the real fine tuning or planish welding or anything like that. This was a year ago, it kicked my butt getting it to this point. Tonight I spent literally a few hours looking at it planning my attack. I am not kidding, I have chopped many cars, some very complex. Did suicide doors before there were kits to do it. I chopped a VW Bug once in one day, from the first cut to primer, no kidding. And this wasn't rat rod stuff, we are talking show car stuff. I only say this, not to brag or say I know everything because that is the point, I DON'T. This hood sectioning is spinning my head! It makes chopping the top look like making a friggin peanut butter and jelly sandwich! Ok, I think I have it to move forward, wish me luck.
Brian
1948 Chevy pickup
Old 07-12-2020, 11:14 PM   #4540
MARTINSR
MARTINSR's Avatar
They can be useful!
Brian
1948 Chevy pickup
Old 07-13-2020, 10:59 PM   #4541
mick53
I worked on my cover plate for a couple of hours. It's really hot here. I just need to polish it now. I also spent my normal couple of hours chasing parts. When I get this done I can paint the tranny and turn the engine back upright.
Old 07-14-2020, 11:39 AM   #4542
57tailgater
Smile Re: What did you do with your truck today, Part 3
Well you will have until you punch it!!!
57tailgater is offline   Reply With Quote
Old 07-14-2020, 05:02 PM   #4543
mick53
Well I guess it's official. Ryan Falconer Racing Engines is packing up my head for shipping. This is for my 292. It's an aluminum cross flow head with 24 valves and 24 ports. It's been quite a journey. I hope this counts as working on the truck. I don't have anyone to tell.
Old 07-14-2020, 07:35 PM   #4544
DransportGarage
DransportGarage's Avatar
It's usually not a good situation when your head gets packed up, but in your case...CONGRATS!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 07-14-2020, 09:04 PM   #4545
MARTINSR
MARTINSR's Avatar
Very cool, YES it counts, you "worked" on it ordering a part, that's working on it!
Brian
1948 Chevy pickup
Old 07-14-2020, 09:07 PM   #4546
MARTINSR
MARTINSR's Avatar
Got home and did a real five minute a day plan job, (well maybe 10) cleaned up and painted these front motormount pieces. The rod you see them hanging on I made Sunday. Welded tabs on the ends and painted it so I could put it up in my side yard and it wouldn't look trashie. I needed somewhere to hang things like this when painted and this worked out well.
This was yesterday, let's see what I can get done today!
Brian
1948 Chevy pickup
Old 07-14-2020, 09:42 PM   #4547
mick53
I finished the cover plate for my transmission. I tapped the unused holes to bolt it in. I'm happy with it and certainly much more aerodynamic.
Old 07-15-2020, 11:07 PM   #4548
my56chevytruck
my56chevytruck's Avatar
Very very nice looking truck. love the color!!
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 07-15-2020, 11:52 PM   #4549
MARTINSR
MARTINSR's Avatar
My "five minute a day plan" today. I got the bracket removed for the spring and screwed into place testing the fit. Looks right on, I will weld that bracket to the hood reinforcement right there a bit higher than it was originally. I will put another fixed nut in the firewall to lower the hinge down. I didn't want to have to modify the inner fender as I had them powder coated. So this looks good, I can sleep tonight. The hood brace is cut off a the bottom for the hood sectioning. I still need to weld it together as this was just a mock up you see.
Brian
1948 Chevy pickup
Old 07-16-2020, 05:08 AM   #4550
MiraclePieCo
I'm not real likely to punch it in the rain anyway. Last time I did that, the tires broke loose on the wet pavement, the back end came around, and I nearly put it in the ditch!
