08-25-2016, 10:41 AM | #4551 | |
Post Whore
Re: Restoring Rusty
08-25-2016, 06:01 PM | #4552 |
Re: Restoring Rusty
That is insane....so you can go out of your way to buy AC Delco parts, pay a higher price, and still end up with some cheap part? Or I guess you could go to a dealership and buy there....after you stop in the bank for a personal loan...
08-25-2016, 07:19 PM | #4553 |
Post Whore
Re: Restoring Rusty
LOL, yup buyer beware we all heard that before
08-25-2016, 07:23 PM | #4554 |
Post Whore
Re: Restoring Rusty
allow me to provide you with some steering updates as progress has been made
The Greg attempted a DIY Alignment mostly just to adjust the Toe in properly step one was to inflate all the tires to 35 PSI and I only had to go to THREE gas stations to git it done, I have lost all faith in humanity, most pumps were broken or pieces were stolen, disgusting yes dummy over here useta have two air compressors but sold them both Last edited by Gregski; 08-25-2016 at 07:34 PM. |
08-25-2016, 07:25 PM | #4555 |
Post Whore
Re: Restoring Rusty
The DIY Alignment Tools of the Trade
Rocket science this is not! two sets of jack stands some string (cause string can't be crooket, well sure but you git the idea) and a measuring implement |
08-25-2016, 07:30 PM | #4556 |
Post Whore
Re: Restoring Rusty
so we start at the back, I like to set my jack stands a bit passed the end of the car, then we run the string the length of the car
the goal is to have a straight line based on the rims of the rear wheel, so I start at the back of the wheel and I measure 1" inch from the edge of the rim to the string then I measure exactly 1" from the front edge of the rear wheel to the string, that gives me a straight line to the front wheels there's a name for this but it escapes me now string may appear to be off in the pics because of the bad angle of the camera |
08-25-2016, 07:33 PM | #4557 |
Post Whore
Re: Restoring Rusty
I tried to set the steering wheel straight but that proved futile as the wheel was centered with the power steering box on and it did not put the Pitman arm at the 12 o'clock position
08-25-2016, 07:40 PM | #4558 |
Post Whore
Re: Restoring Rusty
so I went with the Pitman arm being vertical in the 12:00 o'clock position, another way of looking at it is it was parallel with the steering column, broom stick as I call it
well this put my front wheels all wonkey, check it out the driver side was way toed out and the passenger side too toed in they stuck out way more than what they appear in the pics, actually they were so out of adjustment that they were hitting the string on both sides and had to be turned in a few turns just to be in the ball park but this I thought could explain that turnability difference to the left vs to the right... lets have at it |
08-25-2016, 07:50 PM | #4559 |
Post Whore
Re: Restoring Rusty
ok fellas, efficient this process is not, but it is not meant to be, it is done on the cheap and gits you in the ball park
so after taking some measurements with my eyecrometer and having loosened the tie rod sleeves I had to lift the truck to make some adjustments I took my time and it took FIVE ups and downs to git it dialed in, but I did that on purpose so that I could understand what is going on, checking my 1" rear rim string settings in between each adjustment, P.I.A. but learned something so First Adjustment was one turn in on the driver side and one turn out on the passenger side then Second Adjustment was one turn in on the driver side and one turn out on the passenger side rinse, lather, repeat I think after the Third Adjustment the driver side gave me a 1/8th toe in, PERFECT it took two more adjustments on the passenger side as I think I went passed the sweet spot, but a few half turns in got me to a 1/8th toe in on that side too - also PERFECT |
08-25-2016, 07:53 PM | #4560 |
Re: Restoring Rusty
Keep in mind that the front and rear track width are not necessarily the SAME. This will give you a false toe reading.
When adjusting toe, make sure you know which way to turn it. It's easy to add toe IN when you meant toe OUT. The adjusters may not need to be turned the same direction left to right. When adjusting toe, make sure you keep centering the steering wheel, or have some lackey in there holding it still for you. Adjusting toe sometimes moves the wheel.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
08-25-2016, 07:54 PM | #4561 |
Post Whore
Re: Restoring Rusty
so here are some pics of my manual steering box Pitman arm turned all the way one way than the other way, it's hard to see where it ends up when turned to the passenger side (its about 1/2 inch passed the inside of the frame rail) but you git the idea, should be equal distant side to side
08-25-2016, 07:56 PM | #4562 |
Post Whore
Re: Restoring Rusty
True, I think my rear is slightly off, no surprise for a 44 year old truck, plus I had the rear off to lower it, I will git it adjusted when I do the entire alignment later on, it's not life threatening at the moment
08-25-2016, 07:57 PM | #4563 |
Post Whore
Re: Restoring Rusty
~ TDT - Test Drive Time ~
08-25-2016, 09:03 PM | #4564 |
Second Chance Program
Re: Restoring Rusty
Good luck!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
08-25-2016, 10:29 PM | #4565 |
Post Whore
Re: Restoring Rusty
Victory, Victory!!!
well I think we have achieved Even-A-Bility, seems like now finally the truck has the same turning radius both ways, it even passed the 57' foot donut parking lot test, yes both ways I will drive it to work for a week or so and report back to you all how it feels, though the true test will come when we go on our last camping trip of the year for Labor Day weekend, 90 miles away, I gots to tell you all climbing up and down to 4,000 feet of elevation on those twisty turney roads up in them El Dorado Forest hills will surely separate the men from the power steering crowd, and pump you up - ha ha |
08-26-2016, 02:05 AM | #4566 | |
Re: Restoring Rusty
08-27-2016, 01:04 AM | #4567 |
Post Whore
Re: Restoring Rusty
Guess What?
My brand new oil pressure gauge broke again!!! Yup the replacement Summit gauge that they just sent me like 2 weeks ago stopped working yesterday and now reads 00 like the first one did. I think I am sending it back with both sending units and asking for a refund. 2 week life expectancy is not worth the $35 bucks each I spent on them |
08-27-2016, 02:57 AM | #4568 | |
Re: Restoring Rusty
08-28-2016, 03:47 PM | #4569 |
Post Whore
Re: Restoring Rusty
08-28-2016, 03:52 PM | #4570 |
Post Whore
Re: Restoring Rusty - Digital Fuel Gauge
so I hope to install the Summit digital fuel gauge today
as with any Universal fuel gauge it is designed to fit different makes and models, that's what the two blue and orange loops of wires are for, they are essentially jumpers which you cut accordingly for what ever vehicle you have in our case we are instructed to snip the Blue wire only for GM purposes kinda feels like defusing a suitcase bomb in an old Bruce Willis Die Hard 80's movie |
08-28-2016, 03:58 PM | #4571 |
Post Whore
Re: Restoring Rusty
I must have trust issues because I decided to pull out the old brown fuel gauge to sending unit wire, something about not having too much faith in a 42 year old piece of copper, ha ha
here I am divorcing it from the tailight wiring harness, it was wrapped up in old electrical tape and ran by the hot exhaust, well not any more... |
08-28-2016, 03:59 PM | #4572 |
Post Whore
Re: Restoring Rusty
also the new fuel gauge has a yellow wire for the sending unit so we will splice /crimp a yellow wire for the home run all the way from the sending unit to the gauge, we will NOT be using the bulk head connector that's just another potential area to have a failed connection
note how it took me 2 years but I finally separated my bulk head connector to two sides, the left side (closest to engine) is for engine run wires only, (starter, alternator, ignition, choke, etc) the right side with mostly green wires is for all the lights (headlights, tailights, turn signals, etc.) and windshield motor then all my diagnostic wiring enters the firewall by the distributor using the old mechanical oil sender tubing hole it aint perfect yet, but it is getting much better |
08-28-2016, 11:45 PM | #4573 |
Post Whore
Re: Restoring Rusty
so here is how all the four digital gauges look in the back all wired up, I joined all the red wires into one common positive lead with a quick disconnect bullet connector and did the same for all black wires for a common ground
I ran out of shrink tubing so I just wrapped them in electrical tape |
08-28-2016, 11:47 PM | #4574 |
Post Whore
Re: Restoring Rusty
and here's the cluster with all the OEM gauges evacuated
I like how the new digital gauges fit without having to cut up the back bluster housing |
08-28-2016, 11:50 PM | #4575 |
Post Whore
Re: Restoring Rusty
well the Good News is the new digital fuel gauge works
the Bad News is now the Water Temp gauge don't work whaa haa haa ha ha love 'em ol' trucks! |
