![]() Join Date: Jul 2012
Re: What did you do to your truck today!
Installed exhaust manifolds. Thanks for all the info guys! I got them installed last night. Decided to go without gaskets and see what the results are. Both surfaces are clean and straight so I think it should be ok. Let her run for about 30 minutes last night and didn't notice/find any leaks.
Thanks again for everyone's advice!!!
__________________ Rob '72 Chevy C-10 - 350-5.7/TH350/PS/PB/AC Build Thread - http://67-72chevytrucks.com/vboard/s...87#post5503187 Semper Fi and Gig'em Aggies! |
Got the bed mounted and the bedsides cut. Raised the bed 1 1/2" so the bottom of the step is even with the cab, instead of hanging lower. Not sure if now lowering the rear to the same ride height with less air in the bag will be a worse ride out back.
#3 | |||||
I've got grease on my mind.
Called the speed shop again and the new part numbers did not come yet, they said they would call me right back, that was three days ago. I would like to try them out but thought about going to stock manifolds and having them coated. Soaked and pulled apart my Pass side ram horn and it turns out to be 1-7/8" and the Driver's is 2", sooo that's on hold until I can try to pick up another manifold at Monroe next weekend. |
67cheby
![]() Join Date: Sep 2008
looking great !
i stared very intensly at my 1972 step side.. wishing i could get out this funk and want this motor but.. no luck....
statring very intensly at my 1972 stepside with the 454 in it.. wishing i had some motivation to get under it and yant motor out to re bearing it...
#8 | |
C/10 junkie
![]() Or maybe this will help...Before and after.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
RAT1968 '68 Cab/'71 Parts
Yeah,. Me, too.
What you really need jc70, is a couple of Buds to come around Vallejo (where I'm thinking it's probably pretty much cooler than the 100.8 degrees here today), climb under with some wrenches and do some bench racing while we pull that puppy. You have the 454 that need bearings. I have leaks. Then again, I just found out my brother has stage IV throat cancer. Puts a lot of stuff in perspective. Put the call out for some wrenches. If it's during the end of next week, I'm only about three and a half hours from you. Bet there's some other folks that that are close enough and would like to get dirty and then get to go home. ![]()
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 09-28-2012 at 05:35 PM. |
Very very clean! Are those Sanderson shorties?
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
That motor looks sweet, Shawn.
C/10 junkie
Thanks guys. No those are Ch ina headers off of eBay. So far they have held up quite well and I am happy with them.
#13 | |
![]() Join Date: Mar 2012
Those headers clear the frame and motor mounts ok? Im looking for a cheap shorty header solution. Can you please private message me a link to the seller?
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#14 | |
C/10 junkie
#15 |
thanks guys it did help now hoping i can do this motor justice like urs. thanks
#16 |
C/10 junkie
Anytime, that's one of the beauty's of this forum....motivation!!
#17 |
#18 | |
C/10 junkie
#19 |
Old member
I drove it for awhile today then took the hood loose again to mess with the gaps. I just couldn't get them any better than these pictures. I installed rebuilt hinges and did a few adjustments when I installed them. Then again today to try and get the drivers side better but it just ant going to happen I guess. I took it loose a bunch and did what I thought would even it up. It either wouldn't shut are it would hit the fenders.
I know these trucks weren't the best body lines for straightness so I'll live with it. The back of the hood sits down now like it should though! ![]() ![]() ![]() ![]() ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#20 |
Looks to me if the hole front was shifted over you could get your gaps even.
Posted via Mobile Device |
#21 | |
Old member
![]() Quote:
#22 |
Yes IMO the front is out of square and needs to be shifted to the drives side so each side of the hood can get the same gaps.
I would guess if you loosed all the front bolts you could shift the front over to fix that. Posted via Mobile Device |
#23 |
Old member
Thanks I may start on that tomorrow.
#24 |
Went to my shop and dropped my 70 stepper of the life & gave her a bath and a small detail job and took her and my wifie to a local cruise night. Lots of great rides here in Camarillo old town. Cheers, Pat
#25 |
Well took my truck for a run yesterday but the big block was a bit cold and I almost stalled it so sidestepped the clutch a bit and turned at the same time while shooting out a tooth from the side spider gears right thu the rear cover so brought it home and gutted the rear diff. Now I need some info guy's in the know. I have a crappy 73 and up gov. lock posi unit, could put new spiders in but is it worth it, heard they are the "worst" GM diff. Will an Eaton or Auburn posi unit swap in place in the same diff housing (12 bolt). Here are a few pic's. Too much power and tire combo.Haha.
![]() ![]() ![]() ![]() ![]() So anyone in the know on the swap. |
