Old 09-21-2016, 03:29 AM   #4676
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
KOOGLIE MOOGLIE
just when I thought we were out of the woods the darn new dual hard fuel line fittings don't fit, they are way too small, the holes in the float bowls appear to be huge like 7/8ths and these fittings are like 5/8ths
it ain't easy fellers, it aint easy
Gregski is offline   Reply With Quote
Old 09-21-2016, 06:56 AM   #4677
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
Originally Posted by Gregski View Post
Thanks for the part number. have you used them on the L31 Vortec heads specifically, I believe they are a different animal, and maybe more important have you used them with the Hooker Comp headers, I think the headers are the issue here
Yes, they fit the L31 heads perfectly. I have not used them with the Hooker headers though.
Jake Wade is offline   Reply With Quote
Old 09-21-2016, 07:21 AM   #4678
peabobble
Re: Restoring Rusty
Might be missing the adapter gizmo. [ATTACH]1572964
peabobble is offline   Reply With Quote
Old 09-21-2016, 09:00 AM   #4679
Will206
Re: Restoring Rusty
Yea, you need a 7/8-20 adapter to I think 3/8. I don't know if it's inverted flare or NPT though.
I just went though this because I converted everything to black anodized AN fittings, and I literally just took a second freelance Webdev job to afford this stuff.
Also, I decided to go with the Quickfuel Slayer 750 on my 383, it seems to work great so far.
Will206 is offline   Reply With Quote
Old 09-21-2016, 09:41 AM   #4680
Hewfil1
Hewfil1's Avatar
Re: Restoring Rusty
Gregski, is it a 4160 or a 4150? You mentioned 4160, then later 4150. I'd like to know as I might decide to go with this rather than the $400 Edelbrock I was looking at. As I also have a 1974 GMC with 350ci V8.
Hewfil1 is offline   Reply With Quote
Old 09-21-2016, 09:51 AM   #4681
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I bought it as a Classsic Holley 4160 Part# 0-80457SA 600 CFM but I converted it to a 4150 using their kit.
If I had to do it all over again I would have bought the 4150 model Part# 0-80783C also a Classic Holley.
both have vacuum secondaries
both have electric chokes
but the 80783 already comes with the center hung float bowls with the dual inlet, the only thing it lacks is the sight glass in the fuel bowls, and it is made of heavy Zinc instead of light Aluminum, but still a better carb
if price is a deciding factor look for these on eBay sold by Holley Performance as referbished you can get them for under $300 and they are done by the Holley guys / factory (dang it I just gave away my secret)
here's a pic of the better 80783 4150 style carb
Old 09-21-2016, 09:55 AM   #4682
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Yup they call it an INVERTED FLARE FITTING
Inverted Flare Fitting 3/8" Tube; Fuel Bowl Thread 7/8-20 (A) x Inlet Thread 5/8-18 (B)
PART# 26-26
Suggested Retail: $12.04
Your Price:$10.84
I swear I am gonna have to get a job at Walmart as a greeter just to afford this stuff, as Holley nickel and dimes you to death for every single little piece, ha ha
Old 09-21-2016, 10:16 AM   #4683
Hewfil1
Hewfil1's Avatar
Re: Restoring Rusty
Would you be willing to send me the entire parts list in a PM? Or in the thread. Or just go with the 4150 over the kit? My choice right now is between this and the Edelbrock 14063 (noNEGR)
Old 09-24-2016, 10:57 AM   #4684
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
PM sent
Old 09-24-2016, 11:38 AM   #4685
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
*** Added a TABLE OF CONTENTS to the very first post with the Thread Numbers. ***
Old 09-25-2016, 09:45 AM   #4686
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
just another reason to convert from the 4160 style carb to the 4150, this transfer tube that connects the fuel bowls is a PIA when changing jets or power valves and the rubber gaskets rip and tear
Old 09-25-2016, 10:39 AM   #4687
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
carb parts
Holley Quickchange Vacuum Secondary Housing Cover
Cover-Diaphragm Housing 1 x 4 bbl
Part# 20-59
Old 09-25-2016, 10:42 AM   #4688
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
more carb parts
Holley Secondary Diaphragm Spring Kit
Part# 20-13
Old 09-25-2016, 10:54 AM   #4689
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so my carb came with a spec sheet, which was wrong by the way, it said it came with the Purple vacuum secondary spring, well it didn't it had the plain one
moral of the story gentlemen, please check what you have installed don't trust no written word, ha ha
Introducing the starting line up (from left to right, lightest to heaviest)
Snow White, Short Yeller, Tall Yeller, Purple Rain, Plain Jane, Too Tall Brown, and Back in Black
Old 09-25-2016, 11:03 AM   #4690
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so we remove the appendage and remove the cap / lid
first we gotta remove the electric choke housing and slide that out of the way, PIA, the Greg does not like dependencies and prefers a nice isolated stand alone modular setup, in other words why does the electric choke have to block/hang off the vacuum pod
Old 09-25-2016, 11:07 AM   #4691
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
mandatory stare and compare
Old 09-25-2016, 11:09 AM   #4692
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
now we thought we were too cool for school and that we could git er done on the carb on the truck, but turns out that rubber plunger/diaphraghm is so pesky that we decided to remove the entire vacuum pod and put the new lid on it on the work bench
Old 09-25-2016, 11:12 AM   #4693
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and here it be in all its glory back on the carb back on the truck
be super careful with that microscopic clip washer that holds the push rod on the cam lever thingie it is practically invisible to the human eye, lol
and my God this is the best single investment you can make to your Holley carb, it takes a 20 minute job (replacing springs) and cuts it down to 2 minutes (that includes chugging a beer) ha ha
Old 09-25-2016, 01:02 PM   #4694
Wide Open
Re: Restoring Rusty
Nice work.
Wide Open is offline   Reply With Quote
Old 09-25-2016, 02:00 PM   #4695
Hewfil1
Hewfil1's Avatar
Re: Restoring Rusty
Can't wait to see how she's running with the new parts.
Old 09-25-2016, 02:07 PM   #4696
Hewfil1
Hewfil1's Avatar
Re: Restoring Rusty
Hell yeah! Keep up the good work man.
Old 09-26-2016, 09:41 AM   #4697
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Oh My God, after weeks and weeks of tuning SHE is a BEAST bro, runs strong, always did, but now strong and smooth.
Just yesterday a new larger .035" accelerator pump nozzle aka "squirter" fixed the delayed Vroo Vroooooooooooom when you floor it in neutral, now it is nice and smooth throughout the RPM range
A lighter tall yellow secondaries spring fixed the hesitation upon acceleration when in gear (the carb came with a plain spring), now that's smooth.
She wants to run bro, I get that feeling she's like a Filly that can smell the fresh cut grass on the race track and just wants to run!!! So Cool
Driving Rusty to work every day this week just to shake out any sillyness.
I just need to fix the exhaust leak [AGAIN] and she'll be ready for another Dyno Test straight after Pay Day next week, ha ha
Old 09-26-2016, 10:15 AM   #4698
Hewfil1
Hewfil1's Avatar
Re: Restoring Rusty
Pure sex, like a square should be. Just got the rebuild for my Carter ordered last night.
Old 09-26-2016, 06:06 PM   #4699
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by KQQL IT View Post
Looks like a gasket problem, not a header problem.
Round port gaskets may have corrected that leak.
I so should have listened and kept my round port gaskets and used those instead
Old 09-26-2016, 06:07 PM   #4700
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so there was no more ticking sound but the truck sure did sound funny with headers and a Flowmaster on one side and an exhaust manifold and a Turbo muffler on the other, there sure is a difference in sound between the two sides that's fer sure, and I won't tell you I may could have liked the sound on the manifold side, since I must justify my header expenditure, ha ha
so back to the parts house I went looking for some crusher gaskets, only to come away with these beauties that set me back $35 bones
how in the world they is reusable I'll never know
so did I put them on? Um no!
wait what?
I wanted to put them on, but those Felpro manifold gaskets were stuck to the enjin block and I didn't feel like scraping brand new gaskits off, then and there, so I said what the hewk lets give them a go with these them headers, and guess what they worked beautifully, SNMFT - Still No More Frustrating Ticking
so overall it was a good day, I fixed my truck, and my countrymen beat North Ireland in an Euro Cup 2016 match, what? you don't pretend to be a soccer fan every 4 years weather you need to or not?
replying to my own thread, wishing I would have kept those metal round port gaskets
