#4701 |
Post Whore
![]() Join Date: Aug 2014
Re: Restoring Rusty
Gentlemen I've been sitting here agonizing over my chronic exhaust leaks and I think I see the problem, take a look at this picture, don't it look like the Hooker header ports don't match the location of the ports on the L31 Vortec cylinder head?
this is the passenger side head, can you see the black square outlines and how they are all shifted over to the right about 3/16ths of an inch, all four ports are like that, as if the header was bolted up a bit too much forward and not on center of the exhaust ports am I crazy or do you see it? Last edited by Gregski; 09-27-2016 at 12:37 AM. |
#4702 |
Post Whore
Re: Restoring Rusty
the driver side is offset too but in this case it seems like this header sits about 1/8th of an inch too far back and needs to slide forward a bit for the holes to align
I don't think I can fix this by welding the bolt holes up and then re drilling them in their proper locations as it's a poor design and the holes will hit the pipes |
#4703 | |
Re: Restoring Rusty
Romans 10:9 - The Truth |
#4704 |
Moderator
![]() Join Date: Oct 2008
Re: Restoring Rusty
I think I'd widen the contact area with a MIG or TIG or even my Oxy Mapp torch then file or grind or mill for flat contact.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#4705 |
Post Whore
Re: Restoring Rusty
#4706 |
Post Whore
Re: Restoring Rusty
Been driving the truck to work every day this week! It runs great, The Greg is so happy!
Monday - drove it in Tuesday - drove it in Wednesday - drove it in Thursday - drove it in Friday - drove it in guys keep at it and you'll get your projects on the road if they aren't already it is such a great feeling, the sqeaks the noises the smells, ha ha Last edited by Gregski; 09-30-2016 at 07:48 PM. |
#4707 |
Post Whore
Re: Restoring Rusty
did I mention the wife will be out of town this weekend and I have already scheduled the next Dyno Test for Tuesday October 4th the year of our Lord 2016 so I am making a list of touch ups WE need to make to make Rusty Roller Ready
1. Fix Exhaust Leak (AGAIN) 2. Replace Magnaflow mufflers with just large resonators 3. Shorten #5 spark plug wire 4. Fix/calibrate one of the AFR Oxygen Sensors 5. Eliminate transmission noise by draining a bit of fluid 6. Finish hooking up license plate light 7. Maybe try a 1" carb spacer 8. something I forget 9. misc. 10. etc. Last edited by Gregski; 09-29-2016 at 11:50 PM. |
#4708 |
Re: Restoring Rusty
I'm excited to see the dyno results. There are none near me and being without a trailer to take my truck kind of leaves me hung out to dry.
#4709 |
Re: Restoring Rusty
Not enough bark with the Magnaflows?
#4710 |
Post Whore
Re: Restoring Rusty
#4711 |
Re: Restoring Rusty
Then you might as well rig up the spark plug flame throwers while you're at it. I would suggest relocating the exhaust exits though. No fun when you realize that the burning smell is in fact...you.
#4712 |
Post Whore
Re: Restoring Rusty
#4713 |
Post Whore
Re: Restoring Rusty
here we go, first the straight edge and eyecrometer test
#4714 |
Post Whore
Re: Restoring Rusty - Hooker Headers
then the build up and the grindage
#4715 |
Post Whore
Re: Restoring Rusty
and now the sides
#4716 |
Post Whore
Re: Restoring Rusty
and the other side, sorry some pics were taken with the header upside down
#4717 |
Post Whore
Re: Restoring Rusty
then I decided to cut up the flange into three separate pieces, this is an old Hot Rodder trick passed on from generation to generation by the spinning angle grinder
so first we mark the flange with a Sharpie with surgical precision, ha ha |
#4718 |
Post Whore
Re: Restoring Rusty
a final look at the finished product - the passenger side Hooker header be modified
#4719 |
Post Whore
Re: Restoring Rusty
then I got bored of all the grinding and decided to get rid of the Old Man Magnaflow mufflers - they just had no bite and you know Rusty needs a proper Soundtrack
laying around we had our 9 inch resonators, a bit too small but it would be criminal not to give them a go mandatory stare and compare old vs new(ish) |
#4720 |
Post Whore
Re: Restoring Rusty
I give you Exhaust 6.0
Welded by the light of the moon, (no seriously I welded this up in the dark, from spare tubes, not bad at all if I do say so myself) |
#4721 |
Post Whore
Re: Restoring Rusty
so this...
#4722 |
Post Whore
Re: Restoring Rusty
... better fix this
#4723 |
Re: Restoring Rusty
Which gaskets are you going to use with 6.0?
Exhaust not 6.0L ![]() Posted via Mobile Device |
#4724 | |
Post Whore
Re: Restoring Rusty
I hope to git these round port aluminum Mr. Casket ones Part # 7402G (G is for custom made for Greg I think) which I already owned once, but like a fool returned |
#4725 |
Re: Restoring Rusty
Yeah I saw those and wondered if you were going to use them or those never have to retorque ones.
