#451 |
Re: Senior Project Build
The pipe will get hacked further back, before the rearend. I want to reuse as much as the pipe that I have and run it out in front of the tires, but I might just end up trading it to the exhaust shop for a 3 inch x pipe/side exit system. Plus the 3 inch will help my new motor breathe more
#452 | |
are you gunna try to bring it to good-guys in puyallup this july?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
#453 |
That would sure be sweet. I should have it running and driving reliably (mostly) by July.
#454 |
Im trying to figure out what intake bolts to use with my GMPP carb intake, and if the L92 heads require a different set of bolts than the 317 heads. I am trying to place an order from sdparts and want to get it all in under one shipping charge. And then I need to find a balancer puller big enough to fit the balancer on this engine. I borrowed one from my schools auto shop but it was too small. I need to find a GM puller or I heard a Chrysler puller works too. Anyone know about the bolts?
#455 |
Eat My Rust
Have you tried renting a puller from a parts store?
And see what Harbor freight has in the way of pullers. |
#456 |
and cstm68 thanks for the compliment, but I don't know if I have passed you- yet
#457 |
I called Napa and they don't rent anything, I might have to try a bigger store. I like the idea of checking out Harbor Freight, good idea Texan. I need some more C clamps anyways.....
#458 |
Eat My Rust
As far as your bolts, you didn't save any from the motor earlier? Or your saying that the bolts you have don't fit the heads?
#459 |
Ok I need help with my fuel cell. Can anyone share their experiences and/or some instructions on how this thing goes in? Do I really have to take off the bed?
#460 |
The bolts aren't reusable for the heads, they are only good for one torquing, you have to get new ones. I want to know if the L92 heads require a special bolt, different than the 317 or iron heads. And I don't know if I can reuse the stock truck intake bolts for the carb intake
#461 | |
![]() Join Date: Sep 2008
As for the intake, I ended up using some metric allen head bolts. No, the stock ones didn't fit with my Vic Jr. I am not sure about the GMPP intake, but I would assume you are in the same boat.
'68 Chevrolet Short Step
6.0 L + 91mm + TH400 + 9" + 4-Link |
#462 |
So where do I find the bolts? At a dealership parts counter? I have been trying to use Scoggin-Dickey because they are priced fairly, but I don't know of they have the right thing.
#463 |
Eat My Rust
I'd give them both a call and see what's up.
#464 |
I just went to the local Fastenal dealer, and bought them. I don't know what length you need ( I think mine were 50mm).
#465 |
tcoop68
it looks like your having fun.It makes me remember my first of many.You will probley be hooked for life like me. Looks like your doing a pretty good job on her keep it up.
#466 |
72 chevys 4 life
what are the wheel tire specs? those look sweet!
I dont call it being young and dumb....I call it young and havin fun ![]() |
#467 |
Thanks guys. The wheels are 15x6 front with 195/65 tires, rears are 15x10 with 13.5 inch wide MT ET Streets that are 28 inches tall
#468 |
72 chevys 4 life
awesome man i love em
#469 |
![]() Join Date: May 2007
Dude you are the man I wish I had half as much time to post as you!
#470 |
Thanks guys. I will find the backspacing specs eventually, for anyone who wants to know. I have spent the evening wire-wheeling rust in the channel right above the rocker panel. I will probably end up slipping a little *eek* bondo in there just so water can't come into the cab. I know everyone, me included, hates when people just fill stuff with bondo but I don't see another option for me right now. I don't have the facilities to weld anything, and have no budget for body work. Its all going into the motor and driveline
#471 |
Oh and how hard is it to cut holes in the crossmember so I can run exhaust through?
#472 |
Not hard at all with a plasma cutter. We cut a frame in half in seconds when we re-framed a 71 of my buddy's.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
#473 |
Is 3 inches a good size for the holes?
#474 |
You want around 3/8" on all sides for movement. Should be plenty of room if your pipes are 2 1/4" OD.
#475 |
Most go larger, I guess it depends on your exhaust.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
