Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 05-12-2011, 03:06 PM   #451
Daveboyd
Daveboyd's Avatar
Re: Boyd Welding-67-72 Rear Mount Aluminum Tank
Originally Posted by Custom 68 View Post
Humm, will the new pump be an "upgrade" or now standard. I am about ready to install mine and assume the standard one will be enough I would have gotten this one but it wasnt available at the time. Seems like we talked about any options.
That is good to always be improving.
The new pump will be an upgrade option it will not be standard. This pump Just came to market earlier this year so it has not been available long.
Dave Boyd
View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks
Boyd Welding Main Site : http://www.boydwelding.com/
Boyd Online Shop: https://fueltankparts.com/
E: Sales@boydwelding.com
Daveboyd is offline   Reply With Quote
Old 05-31-2011, 06:38 PM   #452
209jose71
how much does those run for i have 1971 gmc stock 350 carb i wanted to move it to the under the bed and what does it come with thanks
209jose71 is offline   Reply With Quote
Old 06-04-2011, 11:36 AM   #453
scott72
scott72's Avatar
Has anyone put one of these on a lwb with coil springs? Just wondering, think this is going to be my next project, and I want to make it flush with my wood bed. Can't decide on your product or cpp. Thanks.
scott72 is offline   Reply With Quote
Old 06-05-2011, 09:11 PM   #454
Last_Paladin
Originally Posted by Daveboyd View Post
We now have the Aeromotive Stealth in tank pump availible for all EFI Systems. it looks like a 30% increase in fuel flow. and uses the same wiring and socks as the Walbro.
How much for two of them, are they a bolt in for your tanks that have the Walbro set up previously?
Last_Paladin is offline   Reply With Quote
Old 06-05-2011, 11:31 PM   #455
mcbassin
Still Learning
mcbassin's Avatar
Dave,
Do you have any pictures of the latest tank design with the angle notch in the rear? I saw one at a car show this weekend and I wondered if it one of yours. Any pictures from members that have it installed on their truck? thanks
mcbassin is offline   Reply With Quote
Old 06-06-2011, 08:30 AM   #456
silver7
silver7's Avatar
I'm about to order my SS fuel lines from Inline Tube. Any pics out there of how guys plumbed their tanks? Any help would be most appreciated!
Shawn
1971 C10 4x4
silver7 is offline   Reply With Quote
Old 06-06-2011, 03:54 PM   #457
Daveboyd
Daveboyd's Avatar
pm sent
Dave Boyd
Old 06-06-2011, 08:17 PM   #458
68C10HotRod
68C10HotRod's Avatar
Does anyone with a side fill tank have to notch the frame for clearance? Here's a few pictures of what I'm referencing. I'm also considering removing the rear brace to slide the tank inside the frame rails & shim it so the fill tube is above the top of the frame. Question: Can I swap the current rollover safety valve & return line locations? Reason: The rollover is directly under a bed floor brace & looks like it will hit it if raised up.
Top view of the tank inside the frame - mock up (for mcbassin)
From the rear:
From the side:
Bryan
'52 Bel Air 2dr HT - in pieces
'68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin
"And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery)
68C10HotRod is offline   Reply With Quote
Old 06-07-2011, 09:20 PM   #459
mcbassin
Still Learning
mcbassin's Avatar
Thanks. The tank I saw last weekend had an angle notch at the rear. It looks like your tank is square at the rear. Is this the latest model?
Old 06-07-2011, 10:09 PM   #460
68C10HotRod
The top side of this tank DOES have an angle on it for the rear cross member. It fits in there pretty snug but does have about 1/2" clearance on all sides. I got it last year in a group buy. I'm just disappointed it can't be installed without modifying the frame now. Even if I raise the tank to clear the hose, the location of the rollover valve OR a return line elbow will come in contact with the bed cross member.
Just for the record, my truck is LWB 2WD.
Bryan
Old 06-23-2011, 02:23 PM   #461
Daveboyd
Daveboyd's Avatar
Sorry. I just saw this. Let me know if you need us to do anything.
Dave Boyd
Old 06-24-2011, 12:03 PM   #462
68C10HotRod
I was debating whether to have someone local cut the neck off & make it taller so it stands above the frame. How much should something like that cost?
A UPS quote to send the tank back for work looks like about $70 one way. So even if you did the work & sent it back for free, it will cost that at minimum.
LMK your thoughts on this & whether this would be easy to do.
Bryan
Old 07-01-2011, 08:19 AM   #463
eagleuh1
eagleuh1's Avatar
Any group buys coming up soon? Looking for a EFI tank with everything but the pump. Got a good pump.Thanks. Jim
eagleuh1 is offline   Reply With Quote
Old 07-18-2011, 08:12 PM   #464
creepdogg
Second that, I am looking for a center bed fill non EFI tank.
creepdogg is offline   Reply With Quote
Old 07-28-2011, 10:31 PM   #465
TX6T7
TX6T7's Avatar
these tanks are sweet, adding it to the build list
1967 Chevy swb stepside-work in progress
2005 GTO-daily driver
2001 F250-weekend car crusher
1956 Chevy Pickup-sold
TX6T7 is offline   Reply With Quote
Old 08-01-2011, 12:54 AM   #466
68Maniac
68Maniac's Avatar
Third that....also needing a EFI tank with everthing but the pump.
1968 k30 swb (project)
8.1l vortec,60/14bolt, 13" lift
1967 chevy swb custom cab. (sons)
2008 honda crf450r
2006 honda crf250r
1973 honda xr75
68Maniac is offline   Reply With Quote
Old 08-11-2011, 09:32 PM   #467
1970 CST STEP
Need non EFI tank! GROUP BUY, GROUP BUY!!!!!!!!!!!!!!!!!!!!!!
1967 SWB (small window) original
1970 4x4 STEP
1970 CST SWB FLEET
1972 SWB FLEET ORIGINAL
1970 CST STEP is offline   Reply With Quote
Old 08-12-2011, 08:28 PM   #468
Daveboyd
Daveboyd's Avatar
Ok you guys twisted my arm... I will get the details together on this years final group buy.
everyone chime in and let me know how many tanks to expect and what type, EFI or NON EFI so we can start preparing production and getting the supplies on their way.
i am going to go back through this forum and take a look at all of the prices we have offered. I will try to break the record lowest price.
Dave Boyd
Old 08-12-2011, 08:48 PM   #469
creepdogg
WOOT!!
Count me in for a Non EFI, center fill
Old 08-12-2011, 11:41 PM   #470
2wd73blazer
I need a efi.
2wd73blazer is offline   Reply With Quote
Old 08-13-2011, 12:01 AM   #471
stoich
I'm down for an EFI tank for long bed fleetside with wood bed. I read most of this thread (might have missed it), but was anything figured out with the fill location to be centered in one of the wide planks?
72 Fleetside longbed...97 Z-28 full electronic powertrain (LT1 350/4L60E) powertrain tuned by Bryan Herter (366 RWHP/348TQ). Wood bed with rear leaf spring suspension.
stoich is offline   Reply With Quote
Old 08-13-2011, 12:32 AM   #472
texastrendz
Need a EFI version
texastrendz is offline   Reply With Quote
Old 08-13-2011, 03:30 PM   #473
automagic67
I need an EFI tank too.
automagic67 is offline   Reply With Quote
Old 08-15-2011, 08:44 AM   #474
shearjs
shearjs's Avatar
Sweet! I need an EFI tank also. Thanks!
shearjs is offline   Reply With Quote
Old 08-16-2011, 08:16 PM   #475
Daveboyd
Daveboyd's Avatar
looking good. I am working with vendors to ensure that sending units, in-tank pumps are available and will be delivered on time.
BTW I have decided on the price and dates for this group buy
Date: beginning of Sept i will announce the exact date once all suppliers can commit to meet our delivery dates
Price: i'm not going to say yet but i will tell you that it is the lowest price absolutely possible considering the quality of our tanks.
Dave Boyd
67-72 truck, aluminum tank, boydwelding.com, fuel tank, tank relocation
