Old 01-15-2011, 12:44 AM   #451
qu1cks1lver56
qu1cks1lver56's Avatar
Re: 3r!c84 build
here's my tach, crappy cell pic but you get the idea
qu1cks1lver56 is offline   Reply With Quote
Old 01-15-2011, 10:41 AM   #452
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
Looks good. Test the tach first to see if it works before going threw the trouble of putting it in
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-15-2011, 10:54 AM   #453
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
Nothing realy new with the truck. Been on the back Burner. Need to fix tranny leak. And mess with the tach swap more. And bring my rear wheels and tires to work and fix the leak. Here my dd blacked out. Just been messing with this.. Also my system from the truck is comming out an going into the car when I get more money to buy a deck..
-00 Saturn 5spd
1/4:13:90
Old 01-15-2011, 02:07 PM   #454
qu1cks1lver56
Re: 3r!c84 build
yeah, i powered it up and it reset to zero, 1st good sign lol. I'll probably run a wire from my coil to the tach today to see if it works right today.
Old 01-18-2011, 12:06 AM   #455
nbpro
Re: 3r!c84 build
tranny leak on da truck ????
nbpro is offline   Reply With Quote
Old 01-18-2011, 12:15 AM   #456
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
yup. in two places. in the plug on the top drivers side for the converter lock up leaks out. and the pan gasket has a small leak.
im not running my converter lock up. so the plug is un pluged. but its leaking from there. im going to try to sylicon it up maybe that will work? any ideas
-00 Saturn 5spd
1/4:13:90
Old 01-18-2011, 07:59 AM   #457
nbpro
Re: 3r!c84 build
are pan bolts torqued correctly too tight will warp the pan/gasket, and cause leaking issues.
Make sure that were the bolts go through the pan that the surface is flat and not dished. Also make sure that the pan rails are flat as well
I don't care for cork/cork composite/rubber pan gaskets. I do prefer the Accopac or Farpak gaskets. They don't leak if properly installed (dry or a LIGHT coat of trans assembly gel on them) and the pan bolts are torqued correctly (usually about 95 in/lbs).
Old 01-18-2011, 11:40 AM   #458
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
yea they all are tourqed to like 12-15 ftps and it still leaks. i got rubber gasket. with a thin coat of rvt on both sizes. im going to try to sand down the contact area of the chrome pan. and try it again. but dont feel like doing it right now haha
-00 Saturn 5spd
1/4:13:90
Old 01-18-2011, 12:03 PM   #459
spudz
spudz's Avatar
Re: 3r!c84 build
rtv will help squish the gasket out the sides.... I would use it dry.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-18-2011, 03:27 PM   #460
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
few new pics. good wallpaper pics..
-00 Saturn 5spd
1/4:13:90
Old 01-18-2011, 05:28 PM   #461
Pop's C-10
Pop's C-10's Avatar
Re: 3r!c84 build
That bumper is flawless....
Pop's C-10 is offline   Reply With Quote
Old 01-18-2011, 09:03 PM   #462
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
yea..... i try not too hit little kids or mail boxes
-00 Saturn 5spd
1/4:13:90
Old 01-21-2011, 11:14 AM   #463
nbpro
Re: 3r!c84 build
you sure it's the pan gasket. you positive it's the pan gasket? The O ring on the dipstick tube can leak and fluid will run down onto the pan and then drip off. It's a pretty common thing for the O ring to get old, brittle and cracked and start to leak.
I read some where RTV and trans fluid don't do well together, Check the RTV that you used to make sure that it
is compatible with transmission fluid. it used to be stated that NO
sealant at all was to be used on the transmission pan gasket but I don't
know if this is still correct.
Also the silicone allows the the gasket to be "slippery" enough to move when over torqued.
Old 01-21-2011, 07:45 PM   #464
Pop's C-10
Pop's C-10's Avatar
Re: 3r!c84 build
yea,,tha kiddies will leave scuffs..lol
Old 01-21-2011, 08:21 PM   #465
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
That's why the back bumper is all messed up
-00 Saturn 5spd
1/4:13:90
Old 01-24-2011, 02:36 PM   #466
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
took the truck to work. got it up on the lift. changed the oil. full syn oil now. 10w30. got the tire fixed it was full of fix a flat. (what a mess) put bead sealer on the bead it sealed up good. the wheel bearing is a little loose. not a big deal prob just needs to be adjusted. think its time for a new battery too. tested it. its only at 485cc amps. its a 750cc rated batt. its been hard to start after running and shut off.
-00 Saturn 5spd
1/4:13:90
Old 01-24-2011, 04:35 PM   #467
qu1cks1lver56
Re: 3r!c84 build
where is lox. at in relation to pensacola? i'd love to see this truck in person if you weren't too far away from me.
Old 01-24-2011, 04:40 PM   #468
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
loxahatchee is part of westpalm beach fl.
-00 Saturn 5spd
1/4:13:90
Old 01-24-2011, 09:16 PM   #469
qu1cks1lver56
Re: 3r!c84 build
and thats way down south isnt it?
Old 01-24-2011, 09:53 PM   #470
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
yea its pretty far from you lol im going to the spring daytona car show at the speed way. you should go.
-00 Saturn 5spd
1/4:13:90
Old 01-24-2011, 09:54 PM   #471
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
paint job im getting (one day)
-00 Saturn 5spd
1/4:13:90
Old 01-24-2011, 10:26 PM   #472
87 chevy silverado
Re: 3r!c84 build
nice looks a lil like the gators
87 chevy silverado is offline   Reply With Quote
Old 01-24-2011, 10:48 PM   #473
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
lol funny thing is im not into football..
i just love orange/sliver. and i need the blue in the middle to go with the inside of the truck
-00 Saturn 5spd
1/4:13:90
Old 01-24-2011, 11:16 PM   #474
qu1cks1lver56
Re: 3r!c84 build
I'd love to go, when is it?
Old 01-24-2011, 11:31 PM   #475
3r!c84
Badass
3r!c84's Avatar
Re: 3r!c84 build
march 25-27
http://daytonabeachcarshows.com/inde...&id=6&Itemid=6
-00 Saturn 5spd
1/4:13:90
