Old 05-10-2012, 12:19 AM   #451
grayharville
^^who I am^^ what I say>
grayharville's Avatar
Re: "The Ayatollah of Rusty Hole'a 1987 SWB 6.0 4L80E
Looks good! come paint mine next!
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 05-10-2012, 02:15 AM   #452
Devillusion
Devillusion's Avatar
Very nice............should look deadly.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 05-10-2012, 05:13 PM   #453
noonzor
looks killer dude!! im busy with work and housestuff for a bit, ill come by in june!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 05-11-2012, 01:07 AM   #454
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Sprayed the pearl this morning, four coats (light).
Sprayed the clear tonight, 5 coats (wet).
Overall, seems it is laying out okay, a bit of orange peel on the one rear fender...a bit of contamination I think.
A few dust spots but not too bad for painting it in my garage! Will wet sand it out once it is reassembled.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 05-11-2012, 01:10 AM   #455
squaredaway
squaredaway's Avatar
Wow... great job!
1987 Silverado
6.0/4L80E
5/7 Drop, 20x8.5(245/45)/20x10(295/45) Coy C5s
squaredaway is offline   Reply With Quote
Old 05-11-2012, 01:19 AM   #456
grayharville
Would it be okay if I came to canada and drooled on that paint? looks great
East Tx Squares
Old 05-11-2012, 02:49 AM   #457
Gordonr1973
Home Built '87
Thanks guys! I'm dead tired but still jacked up that it is finally painted!
Gordon
Old 05-11-2012, 03:54 AM   #458
y5mgisi
Second Chance Program
y5mgisi's Avatar
Man that looks beautiful!
y5mgisi is offline   Reply With Quote
Old 05-12-2012, 12:13 AM   #459
noonzor
that looks awesome dude!
Old 05-12-2012, 10:52 PM   #460
Gordonr1973
Home Built '87
Thanks guys! Painting was certainly a process in itself!
Here are a few pics of small things I did today, put on wheels, the gas caps and test fit the motor covers...
Gordon
Old 05-12-2012, 11:03 PM   #461
mooseknuckles
mooseknuckles's Avatar
the painted covers look awesome man...gas filler looks good too...where did you get the hose for the brake booster?
mooseknuckles is offline   Reply With Quote
Old 05-12-2012, 11:48 PM   #462
Gordonr1973
Home Built '87
Thanks! I get all that sort of stuff at NAPA. If you have CAA you get a discount on most things.
Gordon
Old 05-13-2012, 12:22 AM   #463
butch86
butch86's Avatar
i was wrong the painted covers look awsome under there. awsome job
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf.
butch86 is offline   Reply With Quote
Old 05-13-2012, 01:11 AM   #464
Gordonr1973
Home Built '87
I am going to paint the cover...just not sure how to go about it. Was thinking about using touch-up paint to paint the lettering and getting some pinstriping tape from the autobody supply shop to mark the stripes. I'm just scared that my hand is too shakey to do it freehanded.
Gordon
Old 05-13-2012, 11:39 AM   #465
grayharville
The gas filler looks tits. Very slick job gordon
East Tx Squares
Old 05-14-2012, 02:56 PM   #466
rs72z
rs72z's Avatar
Truck is looking awsome.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 05-14-2012, 04:36 PM   #467
Jonboy
Slots go on anything!
The gas caps look great. How did you end up running the filler hoses?
1974 Jimmy- 5.3/4L80e/NP241
Old 05-14-2012, 04:39 PM   #468
96twodoor
96twodoor's Avatar
looks killer ! love the color you went with
96twodoor is offline   Reply With Quote
Old 05-14-2012, 10:59 PM   #469
Gordonr1973
Home Built '87
Thanks! I hope I don't regret putting them on the top
Thank you sir!
I haven't yet...but going to pick up the new hose pieces tomorrow. I want to keep the vent hose so will need to figure it all out. Am thinking about coming through the box floor with the hoses.
Thanks! Diamond white is a pain to spray, but I wanted something unique and I haven't seen another square painted DW anywhere.
Gordon
Old 05-18-2012, 06:55 AM   #470
73gmc454
73gmc454's Avatar
Looks great , Very clean !
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 05-18-2012, 07:28 AM   #471
cletis
cletis's Avatar
This is really coming together, and looks great.
I think I can, I think I can,
http://67-72chevytrucks.com/vboard/s...d.php?t=452601
cletis is offline   Reply With Quote
Old 05-19-2012, 11:17 PM   #472
Gordonr1973
Home Built '87
Thanks guys!
Not much to show although I've been working alot on it....swapped in the new column that I painted last week & had to do some mods on it as it was out of a '90. Will need to modify the shift linkage once again as it is on the otherside of the column but I'm going to sleep on that b/c I'm tired now.
Did some more wiring, drilled in the billit pedals, bled the brake lines & master cylinder, figured out how to bolt on the hood supports, and ran longer vent hoses for the gas tanks so they vent further back under the bed instead of under the cab = less gas fumes to smell!
To do's this week: fininsh some more wiring, work on the shift linkage, look at a tranny pan leak (needs a better gasket), fix the right signal flasher as it works but doesn't flash on the cluster, put the windshield in, put in the carpet and dash and rear speakers and tire jack tool holder....but progress is coming slowly.
I booked it in for the exhaust on June 15th so I have a definite deadline now to work towards.
Gordon
Old 05-21-2012, 10:46 PM   #473
Gordonr1973
Home Built '87
The muffler fell off while I was taking pics...will put it back on later!
Gordon
Old 05-21-2012, 11:07 PM   #474
hick
Who is doing your exhaust work?
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims.
hick is offline   Reply With Quote
Old 05-21-2012, 11:15 PM   #475
Greenlee
Greenlee's Avatar
Nice work Gordon! I used to be a little further along than you on my truck, but now you are passing me up. I like those billet peddles. Are those from NAPA also?
Greenlee is offline   Reply With Quote
