#451 |
![]() Join Date: Aug 2010
Re: Project...praise the lowered
Nice man. You're sooo close!
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
#452 |
as always thanks for the complements and for still following the build.and i promise to have some show/burnout pics this summer.so im still wide open.since my last update i did a bunch of odds and ends,masked and sprayed the truck,installed outer mirrors,outer door handles,inner door panels,window winder and inner door handles with new bushings,installed the grill,mocked up the front bumper,removed painted and detailed various engine parts plus more stuff i cant think of.and heres some pics to prove it haha.i included my fan shroud i mentioned before.....
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 |
#453 |
![]() Join Date: Mar 2011
Looking gooood....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#454 |
67cheby
![]() Join Date: Sep 2008
Great progress !
Posted via Mobile Device |
#455 |
more updates from today.i didnt have alot of time to work at it but still made some headway.so i started by fabing a couple bumper brackets that i will weld to my custom rad support mount,tires showed up at work and they look great,and i figured out my headlight issue.the problem was i ran my sierra headlight harness to the front,because i was going to use the stock 67 headlights i bought new plug in`s like the org 67 had.then i decided to go with the newer conversion 5 3/4 headlights that took a newer style bulb.the sierra one wouldnt fit up.so before i went in search for the right bulbs and harness to splice in i took out the plastic plugs for the new headlights and modified them to accept the style bulb from the sierra.they fit in place perfect.check out the pics to see what i mean.
#456 |
67cheby
nice work and good thinking !
#457 |
Looking nice Joey, lots of good ideas. Congrats on the future little man!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#458 |
a quick update.....since last week i got my bumper brackets stitched in place.a little adjustment then i will have them fully welded,i got the carpet glued in place and the seats mounted for the last time,polished and installed my valve cover`s with the coil packs for the last time,spent hours and hours cleaning up and lengthening the headlight wiring harness,wired and installed my new front blinkers,installed the complete front head light assembly and some other small stuff.and have a cool story..on saturday i went to an open house/car show at the biggest hotrod shop on the east coast of canada.the place is amazing.nothing but top notch super high quality work.its called Untamed - Rods & Customs if you wanted to look them up.it was well worth the 3 hour drive to get there.anyways..me and the wife were looking around when she thought she heard some one call my name.i didnt recognize the person so i kept looking at one of the rods.he and his buddy ended up coming over asking if my name was joey.it turns out hes a member on the forum and has been following my build from when i first started.it also turns out hes starting a c10 project of his own and only lives about 20 mins away.kind of funny after driving past his house dozens of times we meet up 3 hours away from home.....so anyways heres some pics.(i only have a few.most stuff i did wasnt that exciting)
#459 |
That is looking awesome! Great job.
#460 |
67cheby
Cool story !
#461 |
You're getting closer and closer.....Jim
#462 |
Registered Mail
sweet!, you've been making some serious progress. are those signal light led?
'67 chev 496, lwb to swb, bagged - pro street project |
#463 |
![]() Join Date: May 2012
cab looks great!!!!...it must have been hell with all that rust
#464 |
thanks guys.i picked away at it more this week.bumper brackets welded and painted,wiring ect.i hope to get a lot done this weekend.possibly get some wood for the bed.the turn signals are just a regular peanut bulb.7 bucks for the pair at a local over stock store.and the cab was hell at times.but fixing it saved me a ton of cash.
#465 |
hey joey you truck is kick ass and being from the east coast my self i feel your pain on the rust here it sucks but im loving your buld shame your not in the old shop down the road anymore but i can sure see your all your dad as he builds *****en cars to his ia also looking good your dad is the reason i want to be a autobody tech looken at your truck makes me wanna work on my old chevy but i bought a dodge and im not much likeing it keep up the good work dude from gordie
#466 | |
#467 |
well i have been WFO the last couple days.and its paying off.im just going to list what i have done and follow up with pics...installed fan relay with heat sensor,polished fan shroud and installed fan with wiring for the final time,traced a ton of wires,got the rear tail light wires ready to hook up,installed the tail gate for the final time,cut and re welded a bed cross member that had an issue,cleaned and installed the rear end cover,installed the gas tank vent tube,installed the battery ground cable,did body work to the front bumper then primed/painted and installed it,lengthened and installed low coolant sensor wires,welded gussets on the pan hard bar brackets,cleaned up wires that were no longer needed under the hood,bought my bed wood then cut it to fit the main floor of the box.then stained it with stain i made my self,then brushed on 2 coats of clear,i couldnt find a wheel adapter for the newer style steering column so i went ahead with modifying mine with out the air bag.so i foamed it,shaped and sanded it when it was hardened,wrapped it in foil and laid some fiber glass.once it was hard i shaped it and im undecided which rout to go but i think i may leather wrap it.stay tuned to see.
i know i did more but im exhausted and cant think lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#468 |
You've been a busy guy, bumper and bed wood look great, nice job.....Jim
#469 |
67cheby
Holy smokes you are kicking it !
#470 |
Kvn1011
Wow!! I like what you have done!!!
![]() ![]() (Project Slow Motion) |
#471 |
busy day again fellas.today i painted my cowl,the hood again (had water issues last time i sprayed)....then it burnt in one spot so i sprayed it one more time.
#472 |
good looking truck, these trucks have alot of potential
#473 |
#474 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Just so ya know your taillight lenses are upside down or im a dumb ass your choice..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#475 |
lol.i will go for they are upside down.only reason is where i installed the new blinker bulb and socket at the bottom part of the light it lined up close to perfect with the circle design of the lens.looks good when flashing.good eye
