#451 | |
Re: 72 k20 project
already in the works my friend. i am going to make an adapter that will lower the turbo slightly from the forward location and make it real easy/clean install of the primary. should also give me a place to locate the external gate if i feel like going that route. i already drew the T3 flange, so hopefully i can get those waterjetted this week. by the looks of it i'll be able to hog a 5 incher through the tangle too. i also have a sweet plan for my BHAF |
#452 |
Re: 72 k20 project
Well sounds like you are in your way to figuring it out!
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
#453 | |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 72 k20 project
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#454 |
Re: 72 k20 project
We can hope not!
got a special box from the man in brown ![]() ![]() |
#455 |
Re: 72 k20 project
Oh boy, there won't be much room when air fills those boys.
#456 |
Re: 72 k20 project
the one on the right has some air in it. just enough to lift the bag up to the frame.
#457 |
![]() Join Date: Aug 2008
Re: 72 k20 project
Wow
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#458 |
Re: 72 k20 project
Thats what i thought too!
#459 |
Re: 72 k20 project
Looking good man!
#460 |
Re: 72 k20 project
Wow, this project is looking awesome! Can't wait to see more.
#461 |
Re: 72 k20 project
Thanks Guys.
it is supporting itself again! the bags are huge, it should ride well, when the truck finished and heavier than it is now, it will be carrying little pressure in the bags. also means it will carry WAY more than the axle/truck is rated for... now i need to measure/design the panhard stuff. ill order the rod ends sometime and probably some bilsteins as well. i still have to fab up the upper shock mounts. anyhow ![]() ![]() ![]() Ryan |
#462 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: 72 k20 project
WTF! That's awesome! You can start a business towing mobile homes with that rig. I know nothing about bags - can you control the ride height from inside the cab?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#463 | |
Enjoying left field
Re: 72 k20 project
![]() How much are those bags rated for? |
#464 |
Re: 72 k20 project
Looking good man!
#465 | |
Re: 72 k20 project
the "normal" bag set ups that the lowered crowd use usually have in cab controlers. they are basically pressure settings that will adjust the height of the bags and therefore the truck based on the pressure in the bag. i will set mine up to maintain my chosen ride height automatically. it is pretty much a self contained system that requires only the initial setting and is totally mechanical. i will have a dump switch in the cab that will allow me to dump the bags for easy trailer hookups, and i will probably have a bag pressure gauge and a tank pressure gauge just to know. after you have hauled some loads, you can use the bag pressure required to maintain ride height as a decent gauge of load weight. Hahaha, you guys crack me up ![]() i think the bags are rated somewhere close to 8k per bag. its like 7830 @90psi with a max pressure of 100psi operational. i think the dodge rating for the axle is 8k and the dana rating for 80s is like 11k. it will handle well over the axle capabilities with the suspension for sure. Thanks my friend |
#466 |
Junk Yartist
Re: 72 k20 project
Can't wait to see what you come up with for the panhard, because the rest looks killer!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#467 |
Re: 72 k20 project
had to measure for the panhard but had to figure out what would be where for when the bags where dumped and make sure my panhard wouldnt hit everything. i was also positive the diff would hit the gas tank as well.
here it is "aired out" ![]() wheel stays centered! ![]() cleared the tank. id like to say i had it all planned out, but i was mostly guessing ![]() ![]() where the panhard has to live ![]() Last edited by ryanroo; 03-24-2013 at 07:11 PM. |
#468 |
Re: 72 k20 project
and, the links while its all wadded up
#470 |
Re: 72 k20 project
Sweet! That's awesome buddy. That's going to be bad ass!
#471 |
Re: 72 k20 project
Looks awesome! Do you have plans to set up the pan hard bar low to allow exhaust pass through? Your fuel tank worked out perfect too! Great work!
#472 |
Re: 72 k20 project
Thanks guys
I have no plans for exhaust right now. i think a hood stack.... really i have no idea. there is a giant wall when you get to the fuel tank, and no real good way to get through it. i have a decent chance of getting over the rail for an in front of the rear tire exit. that or the pointed at the ground ahead of the rear axle and make sure everything is washed and coated in WD40 every third day. i could also bail on the rear tank and go back to incab, but F that. the bar will be low, but that is more for the RC than anything. i am pretty much bent over no matter how i roll for exhuast Ryan |
#473 |
Re: 72 k20 project
Did a little fiddling with my panhard brackets today.
in effort to maximize the length of the panhard, it is really close to the drivers side link mount. i may have to untack it and slide it slightly to the inside if the rod end and the link bolt make sweet sweet love. i will find out when the ends get here ![]() ![]() also got a trans mount fabbed up a while ago ![]() mig weld ![]() i have ordered all of my rod ends and bushings. hope to see them next week, but im not gonna hold my breath on the stuff from balistic. i imagine the parts from ruffstuff will be here by the end of the week. |
#475 |
Re: 72 k20 project
Not at all. Im jealous too.
