Old 07-12-2012, 02:25 PM   #451
Bennett68C10
Bennett68C10's Avatar
Re: Project Grande Slam: Coley's Hot Rod Shop
That would be interesting let me know what you find out Chad
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-12-2012, 02:32 PM   #452
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by CC69Rat View Post
Form what I understand, the rotors are basically C5 Corvette, drilled and 5x5 pattern added.
So, .. maybe C5 calipers would work? I'm going to check it out.
You might contact member way2lo2.
He is the corvette caliper king here on the board.
http://67-72chevytrucks.com/vboard/s...d.php?t=465140
Keith
Convert to disc brakes.
Old 07-12-2012, 03:08 PM   #453
gringoloco
A guy with a truck
gringoloco's Avatar
The bolt spacing on the caliper brackets is different, even though they're both PBR calipers. With the larger piston bore of the truck caliper, clamping force is probably negligible between the two designs, but the 'vette piece is undeniably lighter and 'cooler'...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-12-2012, 03:19 PM   #454
CC69Rat
CC69Rat's Avatar
Should I do the Centerline Bolevards and hide my brakes?
I'm not going for 'ALL looks' .. but the rotors and 4w disc would have a certain eye appeal to it if you could see it through the wheels. If I do the Centerlines, it could be kind of an 'all business' thing. I just hate to cover them up.
Ugh ..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 07-17-2012, 02:53 PM   #455
CC69Rat
CC69Rat's Avatar
Talked to Dad today, we worked with Mike Hudlow (Hudlow Axle) and had my Mosers turned a little to make the rear discs work. They were turned on a lathe and just barely shaved to fit the hole in the rotor over the axle flange. Not a problem
I'll post pics shortly. We have also swapped out the carpet, and dad has a new windshield going in it on Thursday. I just might take Friday off !
Chad
Old 07-17-2012, 03:03 PM   #456
67cheby
67cheby
67cheby's Avatar
boy....i would sure hate to hide them !
67cheby is offline   Reply With Quote
Old 07-17-2012, 03:18 PM   #457
shawno72
C/10 junkie
shawno72's Avatar
I agree show them babies off!!
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 07-17-2012, 03:32 PM   #458
VA72C10
VA72C10
VA72C10's Avatar
show those discs off!!!
On the carpet, are you going to be driving it before you get the buckets? I ask because the holes for the bucket seat mounts are different than the bench mounts of course so I wouldn't want you to have extra holes in brand new carpet....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-17-2012, 03:35 PM   #459
VA72C10
VA72C10
VA72C10's Avatar
My thought is if you really want to drive it right now....throw the black buckets in. Although make sure to drill/cut only for the passenger style fixed mounts on both sides. (can't remember now if you went with tilt forward or fixed on the passenger side though...did you get the tilt ones?)
Another option I just thought of are 73-87 brackets. With you being tall, they sit an inch and a half taller...the disadvantage is they will sit up a hair into the rear window. the advantage is it will be a more comfortable ride since you plan to carve corners in it and drive it And...I can give you a set of those mounts for the same price as the fixed mounts and they'd be adjustable on the driver's side and tilt forward on the passenger (I can ship those now so you could temporarily mount them to the black buckets if you want to drive it now)
Old 07-17-2012, 03:59 PM   #460
CC69Rat
CC69Rat's Avatar
I was just planning to put the carpet in and not mark or drill the holes until I got the buckets. Yeah, it has to sit for a few weeks, but the wheels / suspension would be out from under it anyway.. It's not going to hurt for it to sit without seats in it for a bit.
I'd really like t ogo a little lower actually with the seat position. Not just for the pimpin look from the side .. but just overall leg room. the 3OTT gets a little uncomfortable in 3rd sometimes. the gear shift is right on my knee.
I had actually considered building / modifying a set of mounts to make them about 1-1.5" lower than factory buckets. Plus, I look like I'm 8ft tall when I drive it when it had the bench in it.
ALSO* the bench will be for sale soon. I can't really ship it, but if anyone is interested. (?) Not sure what to ask for it.
Chad
Old 07-17-2012, 04:02 PM   #461
VA72C10
VA72C10
VA72C10's Avatar
I'd say go for it on making some mounts. It's just some c-channel....
there are some subtle bends but you wouldn't have to have them...or you can cut it at the bend areas to make bending easier then re-weld (what early classic does on theirs)
Old 07-17-2012, 04:15 PM   #462
CC69Rat
CC69Rat's Avatar
Out of curiosity, what kind of holes am I going to need to drill / change to make the change from bench to buckets?
Just looking around for a write-up on it .. Does anyone have pictures of the differences and what I need to change? thanks.
VA- we're good on those 69-70 cores, make it happen O' Picasso of the buckets. just let me know on the $. You've seen the truck, you know what I want... same color, just a bucket version. (or as close as you can get, I think Sandalwood is the ticket)
Chad
Old 07-17-2012, 04:25 PM   #463
VA72C10
VA72C10
VA72C10's Avatar
I will look as well for the threads with info on the holes...there's a few on here. Look up bucket seat mounting I believe.
I have a set of aftermarket mounts that go under the cab to reinforce them and have been trying to find a local fabricator to recreate them. If you have any contacts let me know and maybe I can send the set to you to have them copied. I owe jocko a pair as soon as I get another set made...
Old 07-17-2012, 04:33 PM   #464
CC69Rat
CC69Rat's Avatar
Yep -- My brother in law is ridiculous with the CNC machine. He can make just about anything. Honestly, he would be the one to make my lowered seat brackets too.
If you want to send me the set I can put them in his hands and help you get them copied .. maybe we can help some others with similar ideas. One off custom mounts, etc. I can get it done.
Chad
Old 07-17-2012, 08:48 PM   #465
CC69Rat
CC69Rat's Avatar
Ok .. What if I went with Torq Thrusts? I know everyone has them and has for a while, but there's a reason for that. I have them on Dad's S10 and I still love the wheel. You can't go wrong with them for sure ..
No fit issues
Wont hide my brakes
Maybe I could do holowpoint caps on them, or even the flat caps and make them look a little more vintage road race'ish ? Run the safety wires through the caps like they did in the SCCA days?
I'm not afraid to paint them either. .. More expensive than Coys, but not as bad as the Centerlines.
I'm about tired of tossing around options, and just going to go with something. I'm so freakin indecisive.
Chad
Old 07-17-2012, 09:22 PM   #466
Bennett68C10
Chad if you go with the torq thrusts you can get them with the gray centers. I love torq thrusts, I know everybody has them but like you said there is a reason for it. They are just awesome.
Keith
66 Suburban
IG: bennett68c10
Old 07-17-2012, 09:32 PM   #467
CC69Rat
CC69Rat's Avatar
They look pretty awesome with the flat brushed caps on them too.. crap, I don't know. I just don't want to make a $2k mistake.
Chad
Old 07-18-2012, 04:10 PM   #468
7dee2
7dee2's Avatar
Here is a thread that is helpful for mounting bucket seats..
http://67-72chevytrucks.com/vboard/s...d.php?t=516328
I would be very interested to see what you guys come up with. I need 2 sets of cab floor mounts myself and would love to get some dimensions off some originals or these aftermarket mounts you have Jonathan.
Thanks,
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 07-18-2012, 04:44 PM   #469
7dee2
7dee2's Avatar
No fit issues
Wont hide my brakes
Go with the Torque Thrusts they just look right on our trucks!
Brett
Old 07-18-2012, 04:50 PM   #470
big_al_71
big_al_71's Avatar
One of the hardest descisions that I had to make when building my truck was picking a wheel. God knows i went thru four sets of wheels and finally I am satisfied to a point with my current set up. In fact I made a poll and let the board members decide on my last three choices. Make sure that you really think carefully about your choice as you mentioned dont make a huge $$$ mistake...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 07-18-2012, 05:03 PM   #471
CC69Rat
CC69Rat's Avatar
7dee2 -- How far is your truck dropped? Do you have any more pics with the wheels in your Avatar pic? What size and backspacing are you running?
Thanks.
Chad
Old 07-18-2012, 08:26 PM   #472
7dee2
7dee2's Avatar
Chad, go to my Hub Garage and you can see lots of pics of this GMC (click pic for large images). http://www.hubgarage.com/mygarage/6dee7
GMC is sold but I kept the wheels for my current 72 Cheyenne Super clone project.
GMC was dropped 5"/7" it's bagged in the front w/dropped spindles and dropped leafs w/shackles & helper bags in the rear. Truck had c-notch and a shortened 9" in the rear.
TT2's are;
Front 17" x 9" (9.5" outside lip to lip width) w/4" bs
Rear 20" x 10.5" (11" outside lip to lip width) w/4" bs
Tires in the pics are Falken GRB FX-451 255/40ZR17 & 285/30ZR20.
Replaced later with BFG KDW (flame gruve pattern looks kool) 255/40ZR-17 & 295/45R-20 is what I am running now. Gave it more of a biggy & little raked look. Hated the rubber band look on the rear with the Falkens.
FYI-My stock 72 12 bolt is too wide to tuck these wheels with that bs. I picked up an earlier, narrower 12 bolt from a 67-68 that will put me closer (.75 per side) but before I buy axel’s I need to mock it up to see if it needs to be shortened.
Brett
Old 07-19-2012, 11:02 AM   #473
CC69Rat
CC69Rat's Avatar
No more gray 20" Torqs. they have been discontinued per Summit. (They called AR) They still have a few 4.75 BP, but not anything I could use.
Dad Gum it..
Chad
Old 07-19-2012, 11:17 AM   #474
7dee2
7dee2's Avatar
Make them from a polished set or look for a used set of wheels. Could you steel the Coy's from your other build for now?
Brett
Old 07-19-2012, 11:22 AM   #475
CC69Rat
CC69Rat's Avatar
Those are Billet Specialties, but prob not. The backspacing is setup for the stepper bed and will look goofy on the fleet. Narrow rear vs. wide, 73+ Kmember up front. the wheels would sit way inside on the fleet.
How difficult is it to paint the polished wheels? Just 320 scuff / red scotchbrite then etching primer and paint? (of course mask off the lip)
Chad
