![]() Join Date: Feb 2014
Re: 64 C10 Stepside "Jaybird"
Truck is looking great and awesome job on the wiring! That's one job I'm not looking forward to!! LOL
Thanks Mike.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
So I am on vacation as of today and have a long list of stuff I want to get done. I put in 9 hours today this is what I got done.
Ran rear body harness Ran gas gauge and courtesy light Hooked electric choke into engine harness Hooked up all the wiring for MSD box Ran horn and front harness to core support Installed firewall pad and inside heater duct Hooked up heater hoses. Need to buy a new 5/8" one Bumped engine over to tdc and installed dist and plug wires(my wiring is good so far) Cleaned ash tray handle Got all the parts rounded up for sandblasting I need to blast. Firewall pad installed. Bought this from Carandtruckshop. Its made in USA. I was very impressed with how well it fit. I bought the tool for installing the fasteners and had no problem. It was kind of tricky to get the very center above the hump to fit right but finally got it in there. For anyone buying one from them it comes with fasteners. It doesn't say it does so I bought them separately as well. And it comes with 11 pcs but I only used 7. I installed the inside heater duct after the firewall pad. ![]() ![]() ![]() I ran all the wiring in convoluted tubing and secured with rubber clamps or electrical tape. ![]() I'm not crazy about how the firewall pad fasteners poke thru but what can you do. For anyone who buys the AAW harness I did it came with this grommet for the rear body harness. I bought the 6pc firewall grommet set from Carandtruckshop and it didn't include this one. ![]() Installed the temp sender and ran the wire to it. ![]() Ran front harness and hooked up horn. Only thing left to plug in under hood is the heater blower wire and the park lamps harness. This tubing is just sitting there. Will get it all straight when I get clamps for it. ![]() Courtesy light and gas gauge wire. I left some extra just in case. I ran a wire fish to get this installed. Ran the fish up to the hole and the pulled the wire through from top. Got it the first time. ![]() ![]() MSD Distributor and plug wires installed. (I'm a little scared the distributor dropped right in on the first try and even lined up with the oil pump drive shaft. That never happens to me). I robbed all this from my Caprice. I painted the cap black to disguise it as a points distributor but the wires kinda of give it away. I need to adjust some of the wire holders the headers on the truck are different than the ones on the Caprice. So I need to take some slack out of the wires. Still need to tidy up the batter cables maybe buy some longer ones so I can tuck and hide them better and secure them with rubber clamps. ![]() ![]() ![]()
Post Whore
![]() Join Date: Mar 2013
Looks sweet BJ! Awesome work!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
![]() Join Date: Oct 2009
wow Bret... you had a great day. everything looks fantastic. you should take more vacations.
Very nice work!! Looks great.
Ryan. |
Super Clean...
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
Looking great
Starting to come together real nice. Looks great!!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#10 | |
Thanks TJ.
Thanks Ryan Thanks Don Thanks Jeff
Thanks J.
Yesterday finished repairing the steering wheel. It is ready for some High build primer coats. Want to get it as smooth as possible. I didn't have any high build primer so I decided to strip the grille of all its parts and paint. I didn't strip the paint from the mesh part because I am going to cut this out to make it look like a C60 grille. ![]() ![]() ![]() ![]() I saw a truck with one of these Corvair van grille inserts in it. Looked pretty slick but it was a chrome grill. If I were to get one and strip it of chrome an paint it white wonder how it would look. Either that or get the bowtie from a C60 grille. Or a whole C60 grille would be cool. ![]() Worked in the woodshop last night and got 4 drawers installed. Only 12 more to go! ![]()
Diggin' the woodworking...
![]() I also saw the corsair van grille insert and really liked that too... ![]()
#13 |
Looking good Bret! I like the Corvair insert Idea on the grill.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#14 |
The steering wheels coming out nice. Like I mentioned on FB, I've done 3 so I know the tedious work involved, but it'll look great once painted.
And like everyone above.....nice score on the grill insert.
#15 |
I like the grille insert idea. I think it would look good.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
#16 | |||
Hope to find out soon.
#17 |
Here is where the steering wheel is at. Two coats of high build and still needs a few places feathered around the hub. That area is real tricky to get smooth.
![]() Cut the center mesh out of my grille. Wanted to mock it up to see how it looked but I took the buckets off can't mount it. DOH!! ![]() Grille is in really good shape. Has a couple of small dings across bottom part that I was able to knock most of out. Will finish with a little filler ![]() Sanded and CLR'D the back of the grille and grille support and sprayed all the rust left with Loctite Rust neutralizer. ![]() They will be ready for some primer and paint in the next few days! By the way does anybody know what color the headlight cups are suppose to be painted? They look like they might have been anodized. Probably will paint them aluminum. ![]()
#18 |
Post Whore
Looks good!
#19 |
Solid cabinets...
#20 |
Looks great bret! I have a vanity project in the future I will be calling for advice.
#21 |
Impressive as always Bret.
You really are a bit of very good you know.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#22 |
Some really nice woodwork
#23 |
Thanks guys. Got them suckers installed. Now I just need to fill them up and clean the shop up.
![]() ![]() ![]() Got to clean this mess up! ![]()
#24 |
Your shop is looking good! Are you planning on running them the along the whole wall?
#25 |
Post Whore
Hay your shop is Almost as messy as mine!
