Old 02-22-2017, 12:27 PM   #451
hemi43
hemi43's Avatar
Re: What did you do to your Blazer/Jimmy today?
Originally Posted by grillzy View Post
Faded carpet looks better than my no carpet
I ordered new front carpets from Bill's Trucks. Shoul'd get them in a few weeks. You can have the old carpets if you want because they are actually not that bad.
hemi43 is offline   Reply With Quote
Old 02-22-2017, 02:12 PM   #452
grillzy
For sure. That would be awesome. Thanks
grillzy is offline   Reply With Quote
Old 03-20-2017, 08:26 PM   #453
OldBalls
OldBalls's Avatar
Installed 4" lift over the weekend, I think I just need some bigger tires and Ill be good to go.
OldBalls is offline   Reply With Quote
Old 03-21-2017, 12:12 AM   #454
Mick54615
Finally got the engine back in.
Mick54615 is offline   Reply With Quote
Old 03-21-2017, 04:00 AM   #455
mcmlxix
Collector of Projects
mcmlxix's Avatar
Need some rally rims for a classic original look....
Rich
1972 K5 Blazer CST Click HERE
Old 03-21-2017, 01:15 PM   #456
OldBalls
OldBalls's Avatar
Ya I haven't decided which direction I'm going on the rims yet. I do like the rally rim look. I'm thinking I might go 17" rims not sure if rally's come that big...or what it'd look like. Still kicking it around.
Old 03-23-2017, 12:31 PM   #457
Chulisohombre
Chulisohombre's Avatar
There is a place that makes custom size rally tims In whatever size you want. I wish I could remember the name. Even a 80s style 15 inch tall would look nice if you can get some. I went with a classic wagon wheel on mine from keystone. I've just always loked that look.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 03-25-2017, 05:02 PM   #458
hemi43
hemi43's Avatar
Carpets came in finally. I know it`s not rocket science to install them, but here`s a few tips I've learned over the years to make an easy install.
I lay the carpet in and let it sit for a day so it can flatten out, then locate all the places that need holes and push nails in their location. If you get one wrong, it`s easy to move without damaging the carpet. Once all the nails are in their location, I put the holes in using a soldering iron. Not only does this give you a nice round hole, but it also prevents any loose fibers which may get caught in the bolt threads when putting the seats in. I`m sure we have all done this where one thread gets wrapped around the bolt and tears a line about 6 inches long into the new carpet.
Old 03-25-2017, 08:47 PM   #459
colgad
colgad's Avatar
I have used the nail idea too, it works great. I heat up a 7\16-1\2" socket with a propane torch and make the holes with the socket over the nail head. Perfect holes in the perfect place.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 03-26-2017, 05:57 AM   #460
Big Block
Big Block
Big Block's Avatar
Great tips. Never would have thought of that.
Big Block is offline   Reply With Quote
Old 03-26-2017, 10:03 PM   #461
stangtjk
Blasted and primed the undercarriage.... I was trying to get a guy that does the mobile dustless blasting come out and strip the body and frame but he flaked on me. Instead I went out and got one of the small pressure pots from HF and started at it myself... Still would've rather him come out to do it but can't wait around doing nothing.
stangtjk is offline   Reply With Quote
Old 03-27-2017, 12:31 AM   #462
lks dcvn
lks dcvn's Avatar
Nice work cleaning up that tub!
lks dcvn is offline   Reply With Quote
Old 03-27-2017, 09:59 AM   #463
ochre1971
ochre1971's Avatar
stangtjk, what are you thoughts on the HF pressure pot?
ochre1971 is offline   Reply With Quote
Old 03-27-2017, 11:10 AM   #464
hemi43
hemi43's Avatar
How many bags of sand did you go through?
Old 03-27-2017, 12:32 PM   #465
stangtjk
The HF pressure pot blaster worked surprisingly well, it takes some getting used to but once you figure out how to get the valves set to get a good flow it does a decent job... I didn't have any issues with it getting clogged up, happened once at the tip but that was due to a piece of trash that made it past my sceen when I recycled the media.
I tried to get the 110lb unit but they didn't have it in stock so I just got the 40 lb one. I'm not sure why they decided to call it 40lb as it holds a 50lb bag of "sand" just fine. The smaller size wasn't that bad a compromise... Blasting kinda sucks so an extra break now and then to fill up was welcomed.
I only used 2 50lb bags of black diamond coal slag I got from northern tool and recycled it through 3 or 4 times. I also got 2 bags of crushed glass media to try on the inside of the tub to see what works best.
Old 04-02-2017, 04:28 PM   #466
stangtjk
Some more work with the HF blaster...... Should have bought one a lot sooner.
Old 04-02-2017, 05:58 PM   #467
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Parts look great. Can you post a link to the one you picked up? I could really use one.
Old 04-02-2017, 06:10 PM   #468
stangtjk
This is the one I got... 40-lb
Would rather have picked up this one 110- lb but they didn't have it at the store when I went and I wanted to get to work.
Old 04-03-2017, 10:00 AM   #469
DaHos
DaHos's Avatar
This one followed me home Saturday. 72 CST with a few goodies added
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 04-03-2017, 10:11 AM   #470
Big Block
Big Block
Big Block's Avatar
GM panels no less. Single wall top. Nice.
Old 04-03-2017, 10:23 AM   #471
DaHos
DaHos's Avatar
Had.....lol.
1967 C10 SWB
Old 04-03-2017, 10:31 AM   #472
Chulisohombre
That was quick. Good find. Tore down nicely. Tub looks decent.
Old 04-03-2017, 10:38 AM   #473
BLT-NT-BOT
Sprayed my very first paint job today! Almost ready to put it back on the frame.
BLT-NT-BOT is offline   Reply With Quote
Old 04-03-2017, 07:17 PM   #474
grillzy
Wow! nice first paint.
Old 04-03-2017, 08:09 PM   #475
dirish
dirish's Avatar
Looks great!
dirish is offline   Reply With Quote
