#451 |
Re: 67 SWB First Build
I spent a lot of evenings over the past two weeks chipping away at my engine to-do list. It was mainly prepping for starting the engine. I double checked my timing and made some small adjustments to my distributor. I verified i had good oil pressure while the distributor was out. It had great pressure (once i plugged the hole that I missed).
Next, I dumped two gallons of fuel in the tank and hooked up a gauge to my fuel regulator to make sure i had the correct pressure. During that check, I found a couple of small leaks that I had to fix. Same thing happened when I filled the radiator with distilled water. There were a couple of small leaks in the hose ends , but nothing crazy. Took a few minutes to fix it. Installed my oil dipstick. I forgot I had a larger capacity oil pan so i had to add a couple of quarts. It’s all loaded up with some break in oil. I went for my first start and found out my starter was too tight to the flex plate. It was catching and not retracting. I used a couple shims that i kept from the box. Attempt #2 went much better. After a couple of cranks, the engine started. It only ran for a few seconds, and oh boy was I grinning ear to ear. I’m hoping to do the break in at some point this week. I’m about done fabbing up some exhaust pieces to connect to the ram manifolds. I figured I don’t want to be throwing flames in the engine bay
#452 |
![]() Join Date: Jun 2002
Always exciting (and a bit nerve racking) doing a first start! Nice job, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
| Bookmarks |
