Closed Thread
Old 03-04-2012, 12:15 PM   #4726
64shortbox
64shortbox's Avatar
Re: What did you do to your truck today?
Originally Posted by 66farmer View Post
I have to install a conduit hose in mine for the power windows. It looks like your using a pretty big. The hose that came in the New Relics kit is around 1".
How are you going to route yor wires after in the hinge post.
Thanks for your post
66farmer,
I went with the big conduits because I like my stuff to "look" factory even though Chevy never offered power windows & locks in a 64 C10. The factory conduits in my 62 Pontiac, 71 Caddy & 72 Cutlass were about the same size.
As far as running the wires down the hinge post I haven't 100% decided on that yet. There is a cross brace in the hinge post located about 2" below the dash, so for easy access the hole to run the wires would have to be below that - but then the wires would show and I don't want that. When I ran my wires in the door jambs for the dome light switches I found there is enough gap in this brace to feed the wire down for the switch but I don't know if I can get 4 more wires (window & door lock) in this gap. I hope so. I hope I'm making myself clear here.
I also found out the hard way that there is a strengthening brace in the doors for the hinge area. Since you're only using a 1" conduit, if you drill your hole a little more to the outside edge of the door you shouldn't have any problems. I taped the door edge in case I slipped with the drill motor I wouldn't gouge the paint. I slipped and hence the blood shed, but the door was fine!
I'm attaching a couple of pictures of how I ran my courtesy light door jamb switch wire. The pics are taken on the passenger side looking up. The bottom of the dash can be seen in the lower right of the pic. The wiring and grommets came from a 73 Chevy C10. The diameter of the grommets required a 1-1/8" hole. Again, I wanted it to look factory. I know-stupid but it's a hang up I have.
Of the last 2 pics, the top one is the drivers door and the bottom one was taken of the passenger door so it looks flip flopped but you can see where the extra bracing runs.
64shortbox is offline
Old 03-04-2012, 07:00 PM   #4727
rendus
rendus's Avatar
Finally getting prepped for the top coat. Removed the hood, both front fenders and the front bumper. Found some rust-through spots in the Grille support panel, so that'll have to be patched. Bumper came off really well, only twisted off one bolt.
'66 C10 250 3-on-the-tree
'68 Galaxie 460/C6
'74 914 2.0
rendus is offline
Old 03-04-2012, 10:10 PM   #4728
fasteddie1964
fasteddie1964's Avatar
Put one set of rear brake shoes and new wheel cylinder on today. The brake line fitting that screws into wheel cylinder was seased up on line, so I had to get a new line. I went to bleed it after I got everything installed and couldn't get any fluid to come out. The rubber hose that screws to T on the rearend sprung a small leak. I didn't seem to get any fluid leaking from T when I took the old line off, so I must have a clog in it.
Friends don't let friends drive Fords
fasteddie1964 is offline
Old 03-05-2012, 10:34 AM   #4729
66farmer
66farmer's Avatar
Originally Posted by 64shortbox View Post
66farmer,
Thanks for your info. The truck is coming home from the painter today.
66farmer is offline
Old 03-05-2012, 11:27 AM   #4730
markeb01
Senior Enthusiast
markeb01's Avatar
Rubber brakes hoses are one of those little items that just don't get much consideration. My experience is they can break down from the inside with no signs of visible aging. The internal deterioration can generate debris in the lines, swell them nearly shut, or cause them to buldge or balloon under pressure risking even bigger problems. After 30 or 40 years of service, new flex hoses are usually a good idea.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 03-05-2012, 11:54 AM   #4731
tincan1966
tincan1966's Avatar
Haven't gotten much done since installing the big block and making motor mounts. Been working on her "blue oval" truck and trying to get it ready for paint. Hope to get some serious work done on my 'Burb this week.
tincan1966 is offline
Old 03-05-2012, 11:54 AM   #4732
tincan1966
tincan1966's Avatar
sorry for the bad pic!
Old 03-05-2012, 11:59 AM   #4733
srziemkowski
srziemkowski's Avatar
Firewall painted along with most of the front frame.
MY ADDICTION
STAN THE MAN
srziemkowski is offline
Old 03-05-2012, 03:53 PM   #4734
chainsaw
chainsaw's Avatar
Resanded and reshot the stepside fenders where I ran the hell out of them on the first try.
chainsaw is offline
Old 03-08-2012, 01:52 PM   #4735
jbgroby
jbgroby's Avatar
test mounted the barbell............ooooohhhhh it be soooo pretty
jbgroby is offline
Old 03-08-2012, 08:00 PM   #4736
mud.man.rj
mud.man.rj's Avatar
I was all up on ordering new rims and tires but the doors being reskinned and not so straight made me rethink it, sooo I just ordered new doors/seals and armrests for my 71, now I feel way better, get it ready for paint first and painted then rims and tires. Work to do now, getting nothing but better.
mud.man.rj is offline
Old 03-09-2012, 01:22 AM   #4737
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
I got to keep it!!
The now "ex" didn't get it in the divorce.
Now on with the project!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline
Old 03-09-2012, 01:30 AM   #4738
losthope
losthope's Avatar
Originally Posted by chevy_man5 View Post
I got to keep it!!
HELL YA!!!! Thats some really great news, I read somewhere you talking about your divorce and the truck was up in the air and thought to myself that would be a bummer....But now im super stoked for you!!!
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 03-09-2012, 02:55 AM   #4739
MisterC
MisterC's Avatar
I got to keep it!!
Score one for the good guys! My first marriage cost me 2 classics. My new wife is super supportive of my truck obsession. Congratulations on keeping it and know that there's hope out there.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline
Old 03-09-2012, 09:08 AM   #4740
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Thanks Losthope, and MisterC!!
Step one will be getting it running and driving, step two will be getting it stopping (better), the rest will work itself out!
Jason
Old 03-09-2012, 09:49 AM   #4741
srziemkowski
Got my spindles off last night in prep to paint the lower arms and install my lowering springs and wait to get the money to order my disk spindles.
MY ADDICTION
STAN THE MAN
Old 03-09-2012, 09:04 PM   #4742
dugvera@gmail.com
dugvera@gmail.com's Avatar
Size:  27.4 KBPosted via Mobile Device
Stickered it.
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline
Old 03-09-2012, 10:27 PM   #4743
losthope
losthope's Avatar
Made my raised homemade wood bed:
Timmy D.
losthope is offline
Old 03-09-2012, 10:38 PM   #4744
Wolfinthesnow
Wolfinthesnow's Avatar
I built my engine mounts for the nailhead and actually got my "good engine" in the frame. Had to scratch build all my mounts, and used polyurethane bushings from energy suspension.
These here:http://www.energysuspensionparts.com...sp?prod=9.4101
Finished mounts:
Mocked engine and tranny
Name:  Nail Mock Up.jpg
Actual engine Ill be using. 401 punched out .030 over, 340hp, 455ftlbs torque
Also made a little gimick that goes on the boom of my engine hoist to lift my cab from the inside!
"Today I didnt even have to use my AK, I gotta say it was a good day."
I dont care how you did it in California!!!
Wolfinthesnow is offline
Old 03-09-2012, 10:40 PM   #4745
Wolfinthesnow
If anyone is interested, more detailed explanations of my nailhead gmc build here: http://67-72chevytrucks.com/vboard/s...=1#post5212525
Old 03-09-2012, 11:49 PM   #4746
E911manager
Drive it (kinda)!!! Backyard to the front yard anyway!!!
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 03-10-2012, 01:48 AM   #4747
firefighter736
firefighter736's Avatar
Got my bench back from the upholsterer. 3 fixed springs, new foam, a vinyl/houndstooth cover, and $250 later the interior becomes 95% complete!
"All anybody wants is a normal life and a cool car... most people settle for the car" - Christopher Titus
1966 Chevy C10 Pics
Rust to Riding - Pictures of my build
firefighter736 is offline
Old 03-10-2012, 02:03 AM   #4748
markeb01
Senior Enthusiast
markeb01's Avatar
I like it!
markeb01 is offline
Old 03-10-2012, 02:13 AM   #4749
markeb01
Senior Enthusiast
markeb01's Avatar
That is going to be so cool. I always liked Buick engines. I think my youngest son has either a 430 or 455 in his 69 Riviera. I'd love to have that engine in my truck.
markeb01 is offline
Old 03-10-2012, 02:39 PM   #4750
MisterC
MisterC's Avatar
That looks great! I love the progress that you've made on your truck. Very inspiring!
MisterC is offline
Closed Thread
