Closed Thread
Old 09-06-2012, 12:50 AM   #4801
Gonepostal
Gonepostal's Avatar
Re: What did you do to your truck today!
Had to replace a starter cause I thought it was bad only to find out it was a short in the positive cable that was on the headers wife said it was a shower of sparks as she was following me home then all went south both cables burned in half and no lights on a dark road is not a fun thing found a driveway and had to flatbed it home oh well time for a rewire the price we pay for our toys
Gonepostal is offline
Old 09-06-2012, 12:53 AM   #4802
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Glad you're safe.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 09-06-2012, 09:42 AM   #4803
DevilDog Aggie
DevilDog Aggie's Avatar
Originally Posted by Hubscrub View Post
painted driver side inner fender
I love your signature!!!! I used to get up every Sunday morning and watch Sunday Morning with him. Plus his "On The Road" specials were great!!!
Rob
'72 Chevy C-10 - 350-5.7/TH350/PS/PB/AC
Build Thread - http://67-72chevytrucks.com/vboard/s...87#post5503187
Semper Fi and Gig'em Aggies!
DevilDog Aggie is offline
Old 09-06-2012, 09:48 AM   #4804
DevilDog Aggie
Originally Posted by shopking72 View Post
Last thing I did was drive it to Black Top Nationals
She is awesome!!! I love that color and the wheels!!!
Rob
Old 09-06-2012, 09:56 AM   #4805
shopking72
shopking72's Avatar
Thanks! Color looked good in the lights inside I thought
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350
1966 Caprice
1968 Impala (Frame Off LSX Project)
2001 Tahoe LT
2013 Hyundai Elantra
2010 Kawasaki Z1000
shopking72 is offline
Old 09-06-2012, 11:05 AM   #4806
Dunenutt
Newbee
Dunenutt's Avatar
Clunk, Bang, Pop, Pop...
Had some ball joint issues, but they are gone now.
Installing crossover steering as soon as I get it buttoned up.
Dunenutt is offline
Old 09-06-2012, 11:21 AM   #4807
shawno72
C/10 junkie
shawno72's Avatar
Just used it as a truck
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 09-06-2012, 10:51 PM   #4808
prairewolf
by default last week the 67 inherited some 20's, ... baught Wife's Denali new 20'' Michelins and I ended up with the BF Goodies. ... the used tires have 50%tread left if I kid myself a little so they will work. ... now I get to use tire/rim thread search. .... leaning towards custom made 20'' steelies but financial reality might kabosh that....time will tell... thanks for listening, life is good,kent
eat,work,spend,sleep,repeat.
prairewolf is offline
Old 09-06-2012, 10:57 PM   #4809
prairewolf
oops. .. used tires are Bridgestones..... I type faster than I think sometimes.
Old 09-06-2012, 11:24 PM   #4810
Square_78
Square_78's Avatar
New plugs, cap, rotor, NGK wires, air filter... and its still missing and hesitating under load... hmm.. maybe fuel filters next. Gotta buy a timing light too i guess.
Took my old door panels off and threw them in the trash. New ones coming from LMC. Lubed up all the door lock linkages and the window regulator. Things are much smoother now.
Square_78 is offline
Old 09-06-2012, 11:31 PM   #4811
Harpie
Harpie's Avatar
Installed my cpp c notch kit was pretty easy but a complete pain in the (_|_).
And yes the frame is up side down made it much easier to install.
Harpie is offline
Old 09-07-2012, 10:49 PM   #4812
UNEASYRIDER
UNEASYRIDER's Avatar
A little gloss black to the frame.
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 09-08-2012, 01:16 AM   #4813
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
bought some more gauges and a shim kit to fix my pinion angle. was to pick up my new d-shaft...but somebody shut my door that I left open (for a reason) and I overslept to pick it up! the family has been avoiding me all night!
I bought new 5" electric speedo and 5" 8k rpm tach. I'm most anxious about this gauge....a 3 3/8" dual gauge (not into the quads) for fuel level and oil pressure...
along with the matching 2 1/16" voltage and water temp gauges takes care of the usual 6 in 5 holes, but also have a trans temp gauge and been thinking of getting fuel pressure to finish out the 7 holes...or will put an O2 gauge I had in when it was carb'd.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 09-08-2012, 07:47 PM   #4814
ryanroo
ryanroo's Avatar
bought one! its a 72 K20. probably use it for some parts for mine or who knows. it may turn into a shortbed project for my wife or i might just fix up some of the rust issues and sell it... i need a bed for mine and id like to use the front clip as well. who knows though
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline
Old 09-08-2012, 09:46 PM   #4815
chevy2tom
chevy2tom's Avatar
Replaced a leaking heater core, installed new hood hinges, adjusted my dash tach(was off by 1000 rpm) , dug out the old seam sealer in the gutters, cleaned the rest out with a wire wheel on a air powered die grinder( worked perfect) primed & resealed the gutters. Replaced the power steering remote 3/4 hose. Went over the truck with CLR & a Scotch brite pad ( surface rust areas) washed the rest. Now wait for tomorrow & do some more. Gotta love theese trucks! 71 C20 468 long bed
chevy2tom is offline
Old 09-09-2012, 01:17 AM   #4816
ItsRandy
ItsRandy's Avatar
Installed my new radio and speakers. The radio has the wrong "badge" (GMC instead of Chevrolet) on it's face but I don't care. The radio will control a CD changer, play MP3's from a flash drive and an ipod.
ItsRandy is offline
Old 09-09-2012, 01:30 AM   #4817
magwakeenercew2jh
Originally Posted by ItsRandy View Post
Installed my new radio and speakers. The radio has the wrong "badge" (GMC instead of Chevrolet) on it's face...snip...
Nice job. You have info on the set-up for the electronics. Seems I remember a thread....Hummmmm.....
They ever say "CHEVROLET"? I think my face-plate says "GM".
I'm still trying to figure out where to put speakers. I have a "dummy" stock radio in there now. But I have a good (working stocker) one ready for a "fix".
I pulled out the top speaker for about a hundred reasons. Mostly, my stupidity for jacking with all the mounts back there. Now, the hole is filled up with
carbon-fiber sheeting. I'd really like to go back behind the buckets on either side of the gas tank (Yeah, it's still in the cab).
Oooooh! I see you did that. Nice.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-09-2012, 07:29 PM   #4818
bsteele
I changed the carb and finally got to drive down the road and actually feel a little power. It goes tomorrow to a buddies shop to put on a set of double hump heads and work on the carb linkage.(it hung up on the way back to the house) Maybe a '71-'72 conversion on the pedal.
bsteele is offline
Old 09-09-2012, 09:34 PM   #4819
tommys72
tommys72's Avatar
painted my rallyes and put my new center caps on. they are take offs from a dealership in the mid 80s, damn near perfect...wheels look a lot better now...and i had help from my 9 month old daughter with the truck
tommys72 is offline
Old 09-09-2012, 09:51 PM   #4820
Expat_dude
Expat_dude's Avatar
Loaded up, heading to drop my truck off for the body work tomorrow
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline
Old 09-09-2012, 11:05 PM   #4821
Jimbabwe
Jimbabwe's Avatar
Brought it to it's first car show...umm...mostly done!
People were clamoring over it! Many questions regarding Nate's handiwork. Didn't get the inside of the fenders cut yet, so it was still 2 inches off the ground.
Jimbabwe is offline
Old 09-09-2012, 11:17 PM   #4822
HotRod C/10
HotRod C/10's Avatar
Thats awesome!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline
Old 09-09-2012, 11:20 PM   #4823
Jimbabwe
Jimbabwe's Avatar
Thanks!
Jimbabwe is offline
Old 09-09-2012, 11:57 PM   #4824
PAWS 72
PAWS 72's Avatar
Daddy's little helper huh
PAWS 72 is offline
Old 09-10-2012, 09:24 AM   #4825
tommys72
tommys72's Avatar
Yep, she mostly just wanted to bouce on the seat while standing up on it though
tommys72 is offline
Closed Thread
