Closed Thread
Old 03-26-2012, 07:43 PM   #4851
ChuckW
ChuckW's Avatar
Re: What did you do to your truck today?
Thanks. It's starting to come along much better. Bed sides are final primed. Couldn't grab a pic of them, but they came out real nice and straight.. Onward and upward!
ChuckW is offline
Old 03-27-2012, 12:33 PM   #4852
dantimdad
dantimdad's Avatar
I got my carb back after it had a leak. It ran fine for a bit, then started leaking again. I sat down with Dr. Google and, in 20 minutes, had it fixed!
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 03-27-2012, 01:19 PM   #4853
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Opened the door, looked in, shut the door.
Opened the hood, groaned in pain looking at the broken motor, shut the hood, walked away.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 03-27-2012, 02:22 PM   #4854
markeb01
Senior Enthusiast
markeb01's Avatar
Steven
Nice that it only took 20 minutes and not 20 hours or 20 days!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 03-27-2012, 06:41 PM   #4855
fasteddie1964
fasteddie1964's Avatar
I bought a new neutral safety switch and wired it in (splices in the purple wire from switch) and it works like it should. It will only start in park and neutral. My back-up lights also work great now with new switch. Old one was defective, a lot of the guts fell out of it when I removed it.
Friends don't let friends drive Fords
fasteddie1964 is offline
Old 03-27-2012, 06:59 PM   #4856
tincan1966
tincan1966's Avatar
Finally got to work on my Suburban again. Re worked the front air bag mounts, removed all of the old drum brake stuff(front and rear) Mocked up the rotors and cut the cardboard templates for the caliper brackets. Also mocked up the brake booster/master cyl mount under the floor. overall pretty productive day!
tincan1966 is offline
Old 03-27-2012, 07:31 PM   #4857
losthope
losthope's Avatar
Raining out side so i fired up my 90 amp piece of junk harbor freight flux core welder and sat in side my aluminum shed and started working on my rear grill for the truck still got to do a little more grinding, Thursday rains supposed to stop so maybe get it installed on the truck when it stops:
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 03-27-2012, 09:00 PM   #4858
chainsaw
chainsaw's Avatar
Painted the top,grill and trim around the grill white. Just have to cut and buff and Ill be done with the paint.
chainsaw is offline
Old 03-27-2012, 09:15 PM   #4859
1965zac
This rust is right above the windshield. Anybody know how to fix this?
1965zac is offline
Old 03-27-2012, 09:18 PM   #4860
ChuckW
ChuckW's Avatar
I didn't do anything today, but Fri. I'll (with any luck) be wet sanding the Cab and roof with a 500 grit final for paint..... It's all in the prep.... Right!?
ChuckW is offline
Old 03-27-2012, 09:23 PM   #4861
ChuckW
ChuckW's Avatar
65zac...... Don't wait! Get your windshield out quick. If the rust's not too terrible you "may" be able to sand (or grind) it off. Kinda hard from the pic to tell depth. But if you can get the rust stopped, you should be able to fill/bondo it up good a new......
IF the rust hasn't gone too far..... Fingers crossed for you!
ChuckW is offline
Old 03-27-2012, 10:09 PM   #4862
1965zac
Smile Re: What did you do to your truck today?
ChuckW I will get it out tomorrow and see what i can do to fix it. Really appreciate the help!!!!!
1965zac is offline
Old 03-27-2012, 11:05 PM   #4863
Rich 5150 69
Rich 5150 69's Avatar
Rust on the inside above the windshield means the rain gutter on the top of the cab in front is leaking.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 03-27-2012, 11:12 PM   #4864
1965zac
Th for the help you guys! This website is really making my project a lot easier!
1965zac is offline
Old 03-28-2012, 07:31 AM   #4865
K98AL
K98AL's Avatar
Drove it to work!!!! Taking it this afternoon to get rearend gears swapped for 3:38s.....
K98AL is offline
Old 03-28-2012, 03:09 PM   #4866
chad64chevy
chad64chevy's Avatar
well i started this sunday and i'm about done with it! i shortened my steering column by three inches the same way shrunken66stroker did, and anyways heres some pictures i'll finish it this weekend and grind down the welds, paint it, and put it back together!! the last pic is of shrunken66stroker's column and what mine will look like!!
chad64chevy is offline
Old 03-28-2012, 08:42 PM   #4867
fasteddie1964
I fixed the horn.
Old 03-28-2012, 09:52 PM   #4868
E911manager
Cut up a good set of inner fenders and then bolted on the front end to see if it fits...
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 03-28-2012, 11:20 PM   #4869
MisterC
MisterC's Avatar
I found the right master cylinder, with the shallow rod dimple, for power drum/drum and got it mounted up using CaptainFab's bracket. I ended up cutting and welding the original brake push rod and the booster rod; too cheap to buy the adjustable rod from Speedway. Now I just need to wait for my brake line kit to arrive. I'll eventually go disc up front, but I'm not ready for the drop spindles and wanted to go power now.
Thanks to CaptainFab, Jocko, Chief Rocka and everyone that's done this before me and given me the insight to take it on myself.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline
Old 03-29-2012, 12:49 AM   #4870
tc64
tc64's Avatar
started working on this mess!
tc64 is offline
Old 03-29-2012, 02:29 AM   #4871
markeb01
Senior Enthusiast
markeb01's Avatar
More progress on the 71-72 C10 cable gas pedal project. Details in my build thread.
markeb01 is offline
Old 03-29-2012, 07:36 PM   #4872
tincan1966
tincan1966's Avatar
First test run with new hood opening setup. Works as hoped,balance is good. New hinges are being made from aluminum for final, but for now,I am happy. Also got the Master cyl/booster mount DONE on the frame,waiting for rod ands to make the pushrod, then that is off the list. Ordered rotors for disc conversion, and having my brackets cut at the welding shop tomorrow. Hopefully will get the body off this weekend and start finishing the chassis,
Old 03-29-2012, 08:32 PM   #4873
ABX131
ABX131's Avatar
MisterC, what MC/booster application did you end up going with? Looks like my 68' Vette unit.
ABX131 is offline
Old 03-29-2012, 08:36 PM   #4874
MisterC
MisterC's Avatar
I grabbed a booster from a 91 Suburban from the local Pick n Pull. Master is for a 70 Buick Estate Wagon
MisterC is offline
Old 03-29-2012, 08:51 PM   #4875
ABX131
ABX131's Avatar
Ha ha, I learned to drive on a Buick Estate wagon...felt like Clark Griswold in Vacation with the queen sized family truckster. We even had the fake wood panels!
ABX131 is offline
Closed Thread
