Closed Thread
Old 09-17-2012, 01:15 AM   #4876
PAWS 72
PAWS 72's Avatar
Re: What did you do to your truck today!
Originally Posted by magwakeenercew2jh View Post
I'd say you already won...Glad she's okay.
Thanks bud,I hope its going to be easy.
PAWS 72 is offline
Old 09-17-2012, 07:57 PM   #4877
VDOG
Grand PooBaa Member
VDOG's Avatar
Wire wheeled the front of the frame and brushed on some POR-15. Still got a ways to go.
VDOG is offline
Old 09-18-2012, 01:13 AM   #4878
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Came back (on the trailer) from the muffler shop. Everything goes up, I guess. Last time it was $200. This time, $350...and, like last time, I already had the Flowmasters.
http://youtu.be/zm_m8zGp6WU
Went 2.25" pipes this time for some sanity. I don't know how much difference it made sound-wise, but the pro wanted a little more back pressure, so he shrunk down from the
2.5"'s I have gone before. Milder motor on this build (less cam).
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 09-18-2012, 01:41 AM   #4879
HotRod C/10
HotRod C/10's Avatar
275/45/20 On 10" wide 338's. Because of the backspacing (not to re-start anything ),
I'm running 1" spacers...maybe 1.25" to clear the bed (width-wise). I can't really remember which width spacers.
To mud.man.rj....Thanks very much. I appreciate the thumbs-up. Three years solo and a little help with the heavy lifting
from a couple of good pals. Glad to be at the (sometimes frustrating) "de-bugging" stage.
I may go 1.25 with a 295/40 tire for good measure.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline
Old 09-18-2012, 11:21 AM   #4880
Bert W
Bert W's Avatar
I started fitting the serpentine belt system to the small block. I like it so far.
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline
Old 09-18-2012, 11:54 AM   #4881
big_al_71
big_al_71's Avatar
Instlled my billet hood hinges..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline
Old 09-18-2012, 05:10 PM   #4882
magwakeenercew2jh
Ordered a Street Demon 1901 (Polymer center), went to the auto parts store to try to sort out the gas cap issue. Removed a little fluid from the Master Cyl rez. while trying to sort out the cap/gasket leak. Climbed under and made a heat shield between the new pass side pipe and the fuel line under the cab. Sorta figured out that the trans fluid ooze was coming from the trans dip stick. I have another one that isn't as "fancy". Like fancy women (no offense, Ladies), most of the time the ones that are built more sturdily work better in the long run. I'll change out the filler "tube" next time I can deal with going under....
Installed the trim around that already installed home-made headliner. Plopped a center console in....I think [I] got his one ten years ago off the shelf at Pep Boys.
It's only 2:10 in the afternoon. I'm glad to have her home, but that's all I can do today. I'm old.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-18-2012, 05:12 PM   #4883
LEX
LEX's Avatar
I ordered a WHOLE BUNCH of parts from..*gulp* LMC. It's hard to resist their super user friendly website.
LEX is offline
Old 09-18-2012, 10:39 PM   #4884
ItsRandy
ItsRandy's Avatar
Those look great! How do you like 'em? Does your hood open as far as it did with the stock hinges? How hard was it to adjust the hood? What brand are they?
ItsRandy is offline
Old 09-19-2012, 03:43 AM   #4885
74baggedbug
Took my truck to my buddies shop and we are gonna start on building a towhitch for it and may install the cluster I bought a couple of months back ( I hate wiring!!!)
74baggedbug is offline
Old 09-19-2012, 05:02 AM   #4886
lolo33
lolo33's Avatar
ordered some parts :
new red carpet to change the old black (which is brown now)
red plug and chug cup older
custom autosound radio
some gifts/apparels we can't find in france : vintage chevy cap, long leaves t-shirt
waiting for receiving now !
'70 C10 shortbed - 350 Edelbrock equipped - 4/1 headers - 3" flowmaster exausts
'07 MUSTANG V8 convertible - CAI Spectre - Brembo's - 3" flowmaster exhausts
lolo33 is offline
Old 09-19-2012, 07:05 AM   #4887
GMC Canuck
listed it on kijiji. Not a good day.
GMC Canuck is offline
Old 09-19-2012, 08:06 AM   #4888
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Installed the Vintage Motor Minder gauge I scored recently and plumbed it in , it works great , now to find a bulb holder so it lights up @ night , in time it'll be part of my lockup TH350C's torque converter control system , I'm adding a green pilot lamp to the setup too so it'll let me know whenever it locks up .
Installed two rope hooks to the backup lamp bolts as I hate drilling holes .
Installed an under dash oscillating fan .
Swapped the tailgate hooks & chains left for right so underhooking the tailgate is easier , this is an old Farm trick that prevents the hooks from jumping out when you're bouncing down dirt roads .
I pulled the spark plugs as it's been missing at idle ~ WOW are they oily ! I wish I'da had my camera as it's hard to belive it ran like this , I guess the bubbas who
" rebuilt " this engine just before I bought the truck , screwed it up , I have a spare 292 and may have a line on a takeout 1969 numbers matching 250 , if so I'll overhaul it and stick it in , the work never stops .
I'm still not sure which engine I want , the 292's are great but thirsty .
In any case , I used my War Surplus Dental Pick to carefully scrape the plugs clean and re - installed them after opening up the gaps to .070" ~ this will drive the HEI to it's full output and maybe stop the plug fouling .
It figures I'd install the cab fan the same day the heat wave finally broke .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 09-20-2012, 10:39 PM   #4889
magwakeenercew2jh
It's about the DMV...California style.
The short version: After paying my tags late in July for the period of 9/30/12 to 9/30/13...and them cashing the check on 8/3/12, no tags came. More shortening:
At least eight calls later all over the state, with a number of folks hanging up on me (I was ALWAYS NICE...Every time, I had to tell the whole story over to someone new...
...and I thanked them for listening), I got thru to the boss of the boss of the manager at 2:00 today.
I usually don't go the "going over your head route". But I was really exasperated. She asked me, "HOW DID YOU GET MY PHONE NUMBER?" Which gave me the chance to
throw under the bus a particularly nasty person who said she was mailing my tags to me back on the 10th.
Ms. Boss said she'd call me back. I thanked her for any help she could offer. I told her I wasn't a celebrity, I wasn't rich, I wasn't anything but a citizen that already paid the
State for something that I'm still not getting, and one to whom promises have been made for way too long....Then I told my wife, "Sure, she'll call me back."
At 4:00 I got a call from a woman who said she worked for the Big Boss. She had "cleared" my tags and is mailing them out today.
There is some promise here, as she left me her name and phone number and told me she worked for Ms. Big....I think something's gonna happen this time.
On another front, I put on the new Street Demon carb. Still working out the linkage, as I had Mickey Moused the last one on the Edlebrock. Very slick install, otherwise.
Too hot to finish this afternoon. Can't finish tomorrow...gotta do family stuff. Pics of the finished product on Sat. evening.
Here's the notice that came three years ago...I went and got the plates way back then.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-21-2012, 12:38 AM   #4890
mud.man.rj
mud.man.rj's Avatar
Wow on the tags, take some pic's of them for proof that they are real, haha. Man like pullin teeth. Got my fingers crossed for you.
mud.man.rj is offline
Old 09-21-2012, 03:49 AM   #4891
Square_78
Square_78's Avatar
Lowered my truck a little bit today... Getting it ready for bags.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline
Old 09-21-2012, 03:50 AM   #4892
Square_78
Square_78's Avatar
Gotta c-notch the back next week. I like a little bit of rake, but not quite this much.
#teamlongbed
Old 09-21-2012, 11:03 AM   #4893
Dunenutt
Newbee
Dunenutt's Avatar
Installed crossover steering... man what a difference.
All new ball joints, tie rod ends, steering box. Went from a 4 turn 4x4 box to a 3 turn 2wd box. It steers like an indy car, without the annoying bump steer.
Dunenutt is offline
Old 09-21-2012, 11:26 PM   #4894
LEX
LEX's Avatar
I've been collecting parts, but finally taking action.
Mounted steelies today.
Installing as much as I can off this table in the morning.
LEX is offline
Old 09-22-2012, 08:55 AM   #4895
Katrina/10
Katrina/10's Avatar
That should take a while!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline
Old 09-22-2012, 09:08 AM   #4896
shawno72
C/10 junkie
shawno72's Avatar
Installed the 3.08 posi
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 09-22-2012, 10:01 AM   #4897
eagleuh1
eagleuh1's Avatar
Got my only leaking fitting on the new Boyde under bed tank to stop leaking last night when got home from work. Put tank in on my Thursday off, wired and plumbed it. Started right up. The electric pump in the tank for the LS 5.3 is a lot quieter than the under the driver seat on the frame pump. Waiting on a Blazer sender wire with firewall grommet from Wes to finish up the job. Should be here soon. Pics later.
eagleuh1 is offline
Old 09-22-2012, 12:13 PM   #4898
69GWC
Well I installed a new tach, new headlight switch, E-brake handle, acc plate over the key, door lock pulls, larger bulbs in the dash, painted the needles and polished the lens.
69GWC is offline
Old 09-22-2012, 03:30 PM   #4899
Trsmotrhed
Trsmotrhed's Avatar
Finished my motor mounts for my LT1 swap into a 63 c10. Raised the motor 5/8" to help clear the AC instead of spending money on brackets. Worked great with all the room under the hood.
Now to fit the headers and fuel lines. Waiting for my stand alone harness and ECM I got a killer deal on with VATS and smog deletes already done. I want to build a thread, but new to this site and have no idea where to start.
Trsmotrhed is offline
Old 09-22-2012, 03:36 PM   #4900
VDOG
Grand PooBaa Member
VDOG's Avatar
That should take you bout a half and hour tops.
VDOG is offline
Closed Thread
