#4876 |
![]() Join Date: Jan 2007
Re: What did you do to your truck today.The 3rd chapter
Look a bumper!! How sweet it is. Well done!!!!
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#4877 |
![]() Join Date: Jun 2022
Good looking seats ^^
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
#4878 |
I started her up and drove her to the gas station for the first time in a while. Turns out the gas gauge isn't faulted, she was just really close to empty
She backfired like a shotgun(yes she's tuned a little wonky) and I thought I might have caused the untimely demise of a woman next to me ;-)
#4879 |
In between working on the 72 I found this on the 85 . I’ve made 4 parts orders today .
#4880 |
On the 72 got the drivers side cab mounts out I found it’s easier to replace one side at a time . Resealed the transmission pan and test fit the new radiator . This is a Cold case I bought 5 years ago at the Syracuse nationals directly from the Cold case booth . I think with the shroud ,fans and harness I paid $225 . Fit was spot on.
#4881 |
Installed a 69 camaro front lower spoiler.
1972 C10 Step Side short bed |
#4882 |
#4883 | |
Went out to a cruise in Fri night and another today and everyone said it looked really good.
#4884 | |
![]() Join Date: Mar 2011
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#4885 |
New cab mounts in today . I really enjoy working on this truck everything unbolts real easy the bolts almost look new . I re used all the original bolts
#4886 | |
#4887 |
Appalachian Engineering for getting the car-whose-brand-shall-not-be-spoken into the garage solo
....after I moved the 70 onto the street(relevant content :-D ) When I get back to the Chevy, I have to start from the bottom with points-->dwell-->timing-->carb tuning and then see if I can fidget the choke into a happy place or rebuild the Quad, cuz she's a grumpy girl starting u and she's running on after I shut her off
#4888 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
After a lot of talk on Rufas' thread about cooling system woes, I went out to see if the fan clutch Stocker posted in his link would help with clearance between the fan clutch and the radiator. I used to have to take the fan off to replace the belt. That's the way I got the truck. During said inspection, I noticed that the radiator (aftermarket) could be moved forward about 3/8" in the top brackets. There is now at least 5/8" clearance between the radiator and the clutch, plenty of room to slip a belt by. The clutch Stocker posted would be a better fit at some point, in terms of fan to shroud in/out recommendations. But I'm going to wait until the severe duty clutch fails, which, given how much I drive this truck any more, may be never. I have yet to road test it, but nothing interferes, so why would I do that? Idunno.
#4889 | |
#4890 |
It was also a poor-man's rowing machine yesterday ;-)
#4891 |
Finally sealed the driver side kick panel vent. PO installed a speaker in it and that sealed all but the top 2 inches and so I had a constant stream of outside air coming in while running down the road. Passenger side is sealed. Very happy with the results as my A/C now has true recirculation. This is now allowing the thing to perform better and maybe not work as hard. For sure though, humid days will no longer freeze my evaporator! Ambient temp at photo time: 91F -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#4892 |
Coming along should be driving it tomorrow. I know putting all new cab and radiator bushings lift the body some but it’s really noticeable. Thinking maybe the aluminum heads took weight off the suspension ?
#4893 |
Are the radiator and AC condenser in? By the time you get them and the bumper back on it should look a lot better.
#4894 |
Former co-wirker and I. Drove my 67 truck to Hot Rod Power tour show in Hebron, Ohio.
US40 all the way. Yep... she has a deep gear. Followed, clocked speed, 40mph @2000 rpm. |
#4895 |
Former co-worker and I (both retired same day) Drove my 67 truck to Hot Rod Power tour show in Hebron, Ohio.
US40 all the way. Yep... she has a deep gear. Followed, clocked speed, 40mph @2000 rpm. Cool cars and trucks. Cooling system was consistent 100deg over ambient. 3 core stock system. Clutch fan with OEM Shroud. 402BBC. TH400 HD. Last edited by 1967GMCC20; 06-13-2024 at 09:03 PM. Reason: Added details |
#4896 |
Radiator and fluids are in but the radiator is aluminum too so it’s like half the weight of the original 4 row copper radiator. No A/C
#4897 |
I bet it'll settle some though, with a bit of driving. You rebuilt the front suspension on it too, right?
#4898 |
Double post
#4899 | |
Maybe the bumper will drop it a bit .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 06-14-2024 at 07:52 AM. |
#4900 |
All done drove about 50 miles today . Ran real nice and smooth seams to have some grunt can’t really know how much since I need to be easy on it for the first 500 miles . Think I’ll be changing out the mufflers to some old school glass packs they have a deeper tone that I like . These are Magnaflow no drone but it’s not a deep rumble
| Bookmarks |
