Closed Thread
Old 01-28-2017, 04:40 PM   #4901
Dave K.
Dave K.'s Avatar
Re: What did you do to your truck today? Chapter II
Not a darn thing done on the truck today, busy in Matera, Italy working on another classic piece of iron..... it is a 72 however.... good patina as well! Lower roller shafts are worn so it's got a drop kit I guess you would say...
Dave K. is offline
Old 01-28-2017, 06:14 PM   #4902
ole dollor
ole dollor's Avatar
Originally Posted by Andy4639 View Post
Took the old seat out and replaced with a 90 model seat. Put the drivers side harness in have to make a LQ yard run to pick up some more belts. Installed the new strob light also.
Took the hump out and sealed it up good and put more screws in it.
Got to get a rubber mat for it and the inside should be done.
www.youtube.com/watch?v=TvCBRtrigDE
Andy4639 i dont see anything wrong with that ....looks good to me ....Don
ole dollor is offline
Old 01-28-2017, 06:24 PM   #4903
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Thank you sir. I'm pleased with how it's looking so far. I just need a rubber floor mat. I have the tilt and steering wheel + the dash pad to install yet but that maybe awhile until I can get the tilt rebuilt.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 01-28-2017, 07:49 PM   #4904
Newguy71
Question Re: What did you do to your truck today? Chapter II
Oil change, coolant flush. Replaced my temp sending unit to no avail. .. oh and then grounded the 12 volt peg of my temperature gauge.... Now when I ground the temp wire it wont peg out to hot... Did I fry her? Did I just burn out the ceramic resistor? Blow a fuse that I don't know about? I've been through the manual and these threads a little. Anyone have any thoughts as to the damage I did? Know of any other threads discussing this business? Btw, first time posting! This forum is great and I am very thankful!
Newguy71 is offline
Old 01-29-2017, 05:21 PM   #4905
ole dollor
ole dollor's Avatar
i have a bunch of tilt steering parts if you need them , just let me know .i can box them up and send them your way ....Don
Old 01-29-2017, 06:01 PM   #4906
Possmguts
Possmguts's Avatar
Originally Posted by 74baggedbug View Post
Installed these aluminum header gaskets.. I've heard mixed reviews but worth a shot
Whats with the bolts on the fillers pieces at the latch assembly? Can I get some info on what you used there?
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 01-29-2017, 06:09 PM   #4907
Possmguts
Possmguts's Avatar
Originally Posted by BugzC10 View Post
Installed No-Limit shock relocators and U-Bolts while I was at it. ...Still have to test drive it.
I have the same kit... let me know how it works since Im still so far away from any driving...
Old 01-29-2017, 06:11 PM   #4908
1968aj
got these door panels on ebay for $20. added woodgrain and some chrome trim. then I thought I would add the woodgrain and chrome to ashtray.
1968aj is offline
Old 01-29-2017, 06:17 PM   #4909
1968aj
wrong picture
1968aj is offline
Old 01-29-2017, 06:20 PM   #4910
Metaldoc
Metaldoc's Avatar
Started my day off with a board meeting, it went well. Got most of the cutting done and shaped. New tunes for summer.
Metaldoc is offline
Old 01-29-2017, 11:58 PM   #4911
NoStopN
NoStopN's Avatar
I'm a day late, but I got a bed to replace the farm boy special on my truck when I bought it.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 01-30-2017, 12:57 AM   #4912
74baggedbug
https://allamericanbilletstore.com
That's where I got mine from... I'm very happy with them
74baggedbug is offline
Old 01-30-2017, 09:27 PM   #4913
CST10
CST10's Avatar
Changed the tranny fluid, rear gear fluid, repacked the front bearing, checked all the brakes then a good cleaning for both Holdie and Samson. Been a great day.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 01-30-2017, 09:29 PM   #4914
CST10
CST10's Avatar
Another
MyToys:
CST10 is offline
Old 01-30-2017, 09:33 PM   #4915
CST10
CST10's Avatar
Goldie
MyToys:
CST10 is offline
Old 01-30-2017, 09:34 PM   #4916
CST10
CST10's Avatar
Wish I could figure out how to post more than one at a time.
MyToys:
CST10 is offline
Old 01-30-2017, 10:52 PM   #4917
paul blair
CST10-Two nice trucks you have! You should be able to post 5 pics but upload one at a time. go ADVANCED scroll down to Manage Attachments then brose your pics and upload each one add a short note and 5 at a time will attach. Hope this helps.
paul blair is offline
Old 01-30-2017, 11:47 PM   #4918
Boog
laying low
Boog's Avatar
I'm a stepside man but I got to tell you that white fleet just looks absolutely classy. Solid white and all trimmed out is hard to top.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 01-30-2017, 11:48 PM   #4919
paul blair
Changed exhaust manifold "donuts" in my 69 k/10 and took a test run to the beach--good place to clear my mind what ever is left of it! Lots of water out there-3,700 miles or so to Europe.
Old 01-31-2017, 01:37 AM   #4920
toolboxchev
Halfway done under the dash, new wiper motor, Man that was a PITA. I was not made to bend that way. New bolts for the heater fan switch assembly and put in a Never Pop control upgrade for it.
Will post a pic soon! Its nice to have wipers again
toolboxchev is offline
Old 01-31-2017, 08:54 AM   #4921
BugzC10
BugzC10's Avatar
X2 with the drop...
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 01-31-2017, 09:23 AM   #4922
SoCoC10
SoCoC10's Avatar
Originally Posted by berch 69GMC View Post
Paint looks great SOCO.
Thanks! Got the new windshield put in today.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 01-31-2017, 12:35 PM   #4923
chefk85
chefk85's Avatar
Replaced radiator. Had to drill the spot welds on the saddles and emove them thus only using the actual bracket and rubber to hold the new rad in. It was too big. Guess ill order some 4 core saddles. Also installed new heater core. That was fun. The rubber stuff that seals it up held it there REALLY well. Thought I might break the case trying to pry it off the firewall. That was yesterday. Today will be filling with coolant and checking for leaks and hoping I finally have heat and a sealed cooling system!
http://67-72chevytrucks.com/vboard/s...25#post7532025
71 Cheyenne K10. 283/Th350/NP205. 3.07s non posi. 31x10.5 Bighorns.L31 350 Vortec swap in progress.
79 Suburban K20. 350/350. 6" lift. 35x12.5 Toyos.
93 Burb K1500. 350/4l60e Parting out.
2001 Tahoe LT, 5.3, autoride, 265/75s, leather, loaded, family hauler, 243k miles!
chefk85 is offline
Old 01-31-2017, 08:47 PM   #4924
NoStopN
NoStopN's Avatar
I let mine stretch its legs by driving it to work. I'm just waiting for the weekend to continue tearing down the bed I bought last weekend.
NoStopN is offline
Old 01-31-2017, 10:18 PM   #4925
custom10nut
custom10nut's Avatar
Minor improvement.
I got tired of looking at my grungy looking alternator, so I pulled it out, and cleaned it up.
Gave it a light coat of bright silver, along with repainting the pulley and fan blak.
Didn't take long or cost much, and looks 100% better than before.
Sorry, no pic. It was dark when I finished
custom10nut is offline
Closed Thread
