Closed Thread
Old 04-02-2012, 02:06 AM   #4926
markeb01
Senior Enthusiast
markeb01's Avatar
Re: What did you do to your truck today?
Can't wait to see it on the truck.
Originally Posted by Alan's Classic View Post
What I got done today
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 04-02-2012, 07:41 AM   #4927
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Now that looks nice!!
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline
Old 04-02-2012, 07:47 AM   #4928
Camaro_nut2001
Originally Posted by SRVBLUES64 View Post
I had plans to do the wood bed floor but I ended up fitting the left front fender and working on that most ogf the day, Im still having isues with my new 600 cfm holley avenger carb it seems to idle okay but once I put it in gear and it stalls or I can lunge forward has if I was taking of it just stops HELP!!!!!!!!!!!!
On your carb problems if it were me i'd check the float levels first then adjust the idle air screws to your motor. It sounds to me like your gettin enough air but not enough fuel. Is this a new Holley?
Old 04-03-2012, 08:48 PM   #4929
derail
derail's Avatar
Originally Posted by boat View Post
cut and fabricated metal for the radiator support
boat, Those look awesome. You seriously could make and sell them. They all rust in the same spots. Right?
derail is offline
Old 04-03-2012, 09:20 PM   #4930
chainsaw
chainsaw's Avatar
Sanded the front bumper, ready to prime. Left the truck in the garage to miss the hail and tornadoes.
chainsaw is offline
Old 04-03-2012, 10:24 PM   #4931
MisterC
MisterC's Avatar
Riveted a patch in place of the breather hole in the dual snorkel air cleaner; sanded and primed the 1 1/4" sway bar, ordered some new door panel screws on Ebay and mocked up the side trim that I received from GMCNUT.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline
Old 04-03-2012, 10:35 PM   #4932
mud.man.rj
mud.man.rj's Avatar
No truck action today because bought Momma some new couches and rearranged the living room so if she is happy my truck gets happier with more parts. Got one door installed so tomorrow start on the other.
mud.man.rj is offline
Old 04-03-2012, 11:05 PM   #4933
boat
boat's Avatar
more surgery on sheet metal
STEVES 63 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=412554 GIBSON63 YouTube channel https://www.youtube.com/user/1gibsonl4
boat is offline
Old 04-03-2012, 11:08 PM   #4934
boat
boat's Avatar
pic
boat is offline
Old 04-03-2012, 11:09 PM   #4935
boat
boat's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1333508954
boat is offline
Old 04-04-2012, 07:27 AM   #4936
tincan1966
tincan1966's Avatar
Finished the last of the "mock up" stages. Pulled the body off-out to blasters for clean up,while I finish the chassis. Hopefully, the body will be back in a few days and I'll have the frame ready to be prepped and painted, so will just switch out.
tincan1966 is offline
Old 04-04-2012, 09:26 AM   #4937
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Walked by it going to work.
She looks lonely just sitting there with her motor broke....
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 04-04-2012, 10:17 AM   #4938
MalibuKasey
Artist
MalibuKasey's Avatar
I ordered parts finally! A Monster rebuild kit for the 700R4, TV Cable bracket, lowered Sway bar mount brackets, CPP tranny crossmember, and right after lunch.... Capt. Fabs Powersteering adapter kit.
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline
Old 04-04-2012, 05:05 PM   #4939
fasteddie1964
fasteddie1964's Avatar
Drove her to work today.
Friends don't let friends drive Fords
fasteddie1964 is offline
Old 04-04-2012, 05:13 PM   #4940
198plus
198plus's Avatar
I installed my 373 gear and Eaton posi carrier today
198plus is offline
Old 04-04-2012, 05:13 PM   #4941
suzq044
Resident Photoshop Nerd
suzq044's Avatar
Nothing to the truck itself. But we got the master-engine kit from Northern via brown-truck today
PJ - 1966 C10 Panel --
Max² - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline
Old 04-04-2012, 08:09 PM   #4942
XtechX
XtechX's Avatar
What I did today....I drove my truck!!!!!!!!....The first time legally, I took it down for a front end alignment and probably put 30 miles on it or so without any real problems. Except for some awful speedometer cable noise, I unhooked it from the cluster and the noise stopped. What a good day...It was the moment I've been waiting for, for the past 1 1/2 years.
Opportunity usually comes disguised....As hard work!!!
XtechX is offline
Old 04-04-2012, 08:30 PM   #4943
Breadstick
Put the bed in. None of the cross sills were in the right place, so I kind of had to make it work. I drilled new holes in the bed strips and the cross sills and put the hardware in upside down, but it worked and it's ready to haul stuff. It's not the prettiest but it'll do what I need it to.
Also, this is all in my "project Charlotte" build thread.
Breadstick is offline
Old 04-04-2012, 08:40 PM   #4944
markeb01
Senior Enthusiast
markeb01's Avatar
Good for you. It’s a great feeling finally achieving that milestone.
markeb01 is offline
Old 04-04-2012, 09:46 PM   #4945
cb1965
cb1965's Avatar
finally started installing the AAW kit. waiting on wheels to get back from powder coat so i can install my white walls ... im getting closer to droping it completely and adding disk brakes. after the wiring install its on to the dreaded clean up of the donor crossmember.
heres a pic
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline
Old 04-04-2012, 11:54 PM   #4946
66ChevyMax
66ChevyMax's Avatar
Test fit the bed.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline
Old 04-05-2012, 02:02 AM   #4947
RAYDAY
RAYDAY's Avatar
sorry for dark pics. welll today i relized ther was a few guys at the shop so i got them to help dig the cab out of the coner and flip it on its back and 3 hrs later of tourch and putty knife wire wheeling and a stripper disc i got this far
96 s10 static drop smooth and blue
99 silverado nothing stock layed out on 24s
65 c10 bagged patina driver
http://www.myrideisme.com/Garage/az480
half-assed build thread
http://67-72chevytrucks.com/vboard/s...=1#post5206828
RAYDAY is offline
Old 04-05-2012, 06:33 AM   #4948
BillyDeluxe
BillyDeluxe's Avatar
Originally Posted by banno View Post
I tested the wiring of my new tow-bar. My East-Germany micro mobile home fits perfect to the C10, isn't it?
Nice to see you here. I am the guy who visited you from Nuremberg, remember? How is the truck running?
Andy
BillyDeluxe is offline
Old 04-05-2012, 10:13 PM   #4949
_1966ChevyPU
_1966ChevyPU's Avatar
Cool Re: What did you do to your truck today?
Man, I can not wait for the day I get to enjoy that moment.
Bryan (Redneck)
'66 Chevy Longbed Fleetside
'12 Dodge Ram 3500
'08 BigDog Pitbull
'11 Cargomate Trailer (Toy Hauler)
_1966ChevyPU is offline
Old 04-05-2012, 10:15 PM   #4950
_1966ChevyPU
I got more parts in today and was able to find the hardest part there probably is to track down for the truck just a couple hours from the house.
Bryan (Redneck)
'12 Dodge Ram 3500
'08 BigDog Pitbull
Closed Thread
