06-27-2021, 10:43 PM | #4951 |
Re: What did you do with your truck today, Part 3
I started filling the holes in my donor frame. I made these little buttons so I could TIG it for the most part without filler rod. It significantly reduced my tip dipping. I also don't like the idea of just piling MIG wire in there. I don't like grinding. Probably not how it's supposed to be done but it made it easy peasy. They took me about a minute to a minute and a half to make each. The bigger ones take longer because of the parting. There is going to be a lot of work done on these and I wanted uniformity in the steel. Thank you for your time.
06-29-2021, 05:59 PM | #4952 |
Got my Roadster Shop chassis today!
06-30-2021, 09:14 AM | #4953 |
Wow, nice!!
06-30-2021, 10:25 AM | #4954 |
mick53,
I am continually impressed by your skills and drive to get it right. Looking at the site sure sometimes helps me to put in some extra effort when I have a decision to do something one way or the best way! sick57, That is a beautiful sight! Got to be the biggest Christmas present in June you ever opened Posted via Mobile Device |
06-30-2021, 11:36 AM | #4955 |
that's a nice jump ahead on your project, i swear it took me over a year on my frame itself
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
06-30-2021, 10:43 PM | #4956 |
i got my turn signals working again. turns out that part was just me being an idiot. replaced the brake switch and didnt help. i followed ididits testing directions. im not getting power tot he "power" wire for the brakes. next step is to pull the fuse paneloff the firewall and make sure it hasnt come loose from the back. annoying.
07-02-2021, 07:48 PM | #4957 |
Test fit the eng/trans and gas tank into Roadster Shop chassis.
07-02-2021, 07:55 PM | #4958 |
07-02-2021, 09:43 PM | #4959 |
That's a tough act to follow. It finally quit raining here and it's back in the 90's but at least it's humid. I finished filling the 123 holes in my first frame donor rail, 123 to go. I still have 2 or 3 hours of grinding and sanding to do on this one but it's close.
07-03-2021, 05:28 PM | #4960 |
Scaled my truck. I posted it in "truck weight".
07-03-2021, 06:13 PM | #4961 |
Well the corners are rusted but still not bad at all. Trying to find a decent quote here in Northern Cali to blast and epoxy the cab then I can attempt to do the corners. Little patience and time right?
Here are the pics of the corners. I know blasting and epoxy will preserve it so I won’t have to worry about it 15 years from now. Just need to find a good shop. Anybody in Northern Cali know of a dependable shop? Last edited by Rickysnickers; 07-03-2021 at 06:29 PM. |
07-04-2021, 06:31 PM | #4962 |
I have nearly 1000 miles on my truck now (took two years) so time for its first oil change. I won't be changing the oil every thousand miles, just the first time to purge all the shop dust and build residue from the motor. Probably will change it every 5000 miles henceforth. Nonetheless I was surprised how dirty and black the oil was.
1951 Chevy Panel Truck |
07-04-2021, 06:37 PM | #4963 |
Are you using Synthetic?
07-05-2021, 10:52 AM | #4964 |
Really over the past week, installed a T5 in my ‘59. It all went smoothly, bolted up easily, needed the driveshaft shortened, a great improvement though, a lot more fun to drive.
2018 BMW R1200RT 2013 Aprilia Tuono 2012 Ford Flex 2011 Ducati Hypermotard 1959 Chevy 3100 |
07-05-2021, 10:58 AM | #4965 |
Nice job! I'd like to do this to my truck, but being 6'-3", and not having much room now, I wonder if it would be a good idea for me or not. How about some pictures of you clutch pedal/master cylinder setup now
07-05-2021, 07:28 PM | #4966 |
My setup is stock, as far as clutch and brake pedals go, master cylinder under the floor as original. I’m 5’-10”, a 32” inseam. These pics are with the seat all the way back, seat against the gas tank. As far as the trans itself, I’m really happy with how it works. I have a more detailed post over on Stovebolt, FWIW.
07-05-2021, 08:43 PM | #4967 |
I feel the pain I’m 6’4. Not to excited about the comforts of the truck. so pictures, measurements, ideas would be great thanks
07-06-2021, 08:14 AM | #4968 |
Picked up two wheels today, should be perfect!
07-06-2021, 09:58 AM | #4969 | |
07-06-2021, 05:20 PM | #4970 |
Valvoline 20-50 Race Oil. I need the zinc for my flat-tappet SBC.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 07-07-2021 at 03:30 AM. |
07-07-2021, 01:01 AM | #4971 |
What I did with Blue Cloud.......... been running like a champ.
Been collecting certain rocks, for my yard. This load would be 5 walks through a nearby field. I could use a positrac rear end.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
07-07-2021, 01:31 AM | #4972 |
One good thing about getting really old is you shrink and cab gets bigger all the time
07-18-2021, 08:08 PM | #4973 |
Went to the Adna Car Show had 157 cars and trucks registered and I won a trophy for Best Modified Truck All Years!
07-18-2021, 10:23 PM | #4974 |
I can see that happening! Well deserved!!!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
07-19-2021, 01:23 PM | #4975 |
Got my truck back from the local hotrod shop. Had new leaf springs installed (lowered 3") and improved the ride immensely. Plus, the main work done we changed out the fan (electric, and no shroud) system with new fan (with control module) and shroud. Changes to cooling were amazing. To give you an idea of the changes we'll use the following. Outside temp in the high 90's (97 degrees this Saturday).
Old system would run 195 degrees at 70mph, then in traffic would climb to 205-210 degrees (making me very nervous). With the AC running (which we would have to turn off, making my wife uncomfortable). New setup, with the same outside temp, now runs at 185 degrees at 70mph, then in traffic drops to 170 degrees all with the AC running. AC actually is colder as well. New fan blows like a hurricane pulling so much more air through the radiator. Last edited by bosco; 07-19-2021 at 02:11 PM. |
