05-08-2013, 09:18 AM | #26 |
67-72 parts collector,…
Re: lowering question
Just have to say,... THIS is a beautiful truck!
05-08-2013, 09:28 AM | #27 |
I couldnt agree more.
John 82 Chevy Silverado 350ci/TH350 |
05-08-2013, 09:48 AM | #28 |
spindles & springs up front flip kit on rear. cut half of bump stop off and is fine.
Posted via Mobile Device |
05-08-2013, 10:04 AM | #29 |
Bvant1, beautiful truck. Love the color combo. What size tires are you running on the truck in the pic with the stock wheels and hub caps? Thanks.
05-08-2013, 10:33 AM | #30 | |
05-08-2013, 10:51 AM | #31 | |
Happy to be here
Yes it is...
05-08-2013, 01:11 PM | #32 |
You could always leave the front alone and lower the rear a bit to level it out. Rearrange your leaf springs to where the overload spring sits on top. That'll give you 2-3" in the rear
05-09-2013, 06:12 PM | #33 |
im sitting on about a 6 inch drop all the way around with absolutely no body mods straight suspension. i dont bottom out my rear end at all. i have rubbed my front inner fenders liek twice on a road i was unfamiliar with but other than that its not too bad
Jeremy '86 GMC 1500 dropped 6" in the front and 6" in the rear 2003 Land Rover Discovery Low Life |
05-09-2013, 09:40 PM | #34 |
this is mine...4.5/6 drop...cut springs in front and flip brackets in rear with Gabriel adjustable air shocks. front sits a little lower now since I took these pics...installed smaller tires in front so it has a slight rake to it..looks pretty kool
05-09-2013, 10:10 PM | #35 |
My truck has currently has a 2.5" spindles up front and shackle and hangers out back for 4". I would like to lower the rear 1" more. What would be the least expensive way? And if I were to would I have to lower the front more?
My truck is an 82 GMC swb. |
05-10-2013, 09:19 AM | #36 |
mines lowered now. I used Keiths way ( which I still need to do a write up on). Its got a coil and a half off the stock springs up front, and a hanger relocation in the back. Total cost was around 10 bucks for the new grade 8 bolts for the rear, a soda, and candy bar at the hardware store. I did put on new shocks all the way around.That was about 130 bucks. Im working on all new bushings, and Im not sure what that total cost would be. The extras to complete a job add up too, but if your looking for just the drop on the cheap, mines about as simple as it gets. ps; even if it was simple, it still took alot of help from the guys around here lol Also that pic is in my gallery if you want a larger version of it.
1978 Scottsdale - celebrating 10 years of teaching me profanity 1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold 1987 k5 blazer - sold... :\ seed money for the 81 1981 k20 4x4 - 5.3 swap in progress Events attended: Spring GOG 2011 Dale JR car show Summer 2012 Gathering at Tommys pickup parts |
05-10-2013, 10:51 AM | #37 |
xs-style's drop (above) is exactly what I would do for a budget drop that would still ride OK.
If you have a couple hundred then get the drop spindles for sure. I would caution you though about using drop spindles AND drop (or cut) springs over 2 inch drop. (springs that is) I found out the hard way with my 3" drop spindles and DJM 3" drop springs running a 15 inch tire my lower control arms made contact with one of those 1 inch thick iron plates they put over trenching on the highway. When I saw the bump I instinctively hit my brakes causing the front to dive....well it wasn't pretty. Bent frame, totalled truck. Broke that habit now I hit the gas over bumps. My point is that combo lowers control arms very close to ground. I know most all you guys know this already. This is ment for the new guy xs-style's drop does not need any body mods either
