Old 07-20-2008, 11:51 PM   #26
bagged74
its just $$$$$
bagged74's Avatar
Re: z'd frame?
MacSic66....nice work
bagged74 is offline   Reply With Quote
Old 07-20-2008, 11:55 PM   #27
azfab
azfab's Avatar
Re: z'd frame?
cool. ill try that and c what happends. the 68 came out petty good i think it was a smallz but it gave me what i need to lay. it lays hard with no drop spindels, i dont have alot of money i have two kids yatayta but i can fab, so i dont mind working a little harder so save some money who wouldnt? lol those 22s are expensive lol. thanx guys your help is verey apricated!
lifes short fabricate as much as you can!
azfab is offline   Reply With Quote
Old 07-20-2008, 11:58 PM   #28
azfab
azfab's Avatar
Re: z'd frame?
[IMG][/IMG][IMG][/IMG]
Old 07-21-2008, 12:01 AM   #29
azfab
azfab's Avatar
Re: z'd frame?
here were she sits now
[IMG][/IMG]
Old 07-21-2008, 12:02 AM   #30
azfab
azfab's Avatar
Re: z'd frame?
[IMG][/IMG]
Old 07-21-2008, 12:03 AM   #31
azfab
azfab's Avatar
Re: z'd frame?
about four mor and shell lay
[IMG][/IMG]
Old 07-21-2008, 12:11 AM   #32
azfab
azfab's Avatar
Re: z'd frame?
i have som better pics ill post were the bed lines up lol
Old 07-21-2008, 12:47 AM   #33
MacSic66
Active Member
MacSic66's Avatar
Re: z'd frame?
thanks..i havent touched the project in a while.. been too busy, on other projects. i "Z"d it 3" (should have gone 4") 3"djm spindles, lowered the lower ball joints 1", narrowed the upper and lower a-arms 1.5" to drive really low on a 28"tall tire..
im loving the blazer!! sic man.. 67-72 is my dream year truck!! just happened to fall into a 66 for cheap..
http://s100.photobucket.com/albums/m...%20suspesnion/
http://s100.photobucket.com/albums/m...%20suspension/
http://s100.photobucket.com/albums/m...ermark/66/cab/
No vehicle is "too nice" or "too straight" to cut up.
MacSic66 is offline   Reply With Quote
Old 07-21-2008, 02:02 AM   #34
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
Re: z'd frame?
nice work!! got me convinced now to do a "z" on my 68 lwb truck.
i might try also the 1.5" of the crossmember just for fun
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts??
shaneo2112RUSH is offline   Reply With Quote
Old 07-21-2008, 01:17 PM   #35
MacSic66
Active Member
MacSic66's Avatar
Re: z'd frame?
thanks, cool! id honestly go farther on the "Z" than do the crossmember raise too, this only because when you have the frame cut for the "Z" just move it up another inch and you are there, where if you move the crossmember up you also need to realise you have just changed your front suspension geometry. if you do not raise the steering up the same distance.. you run the chance of bump steer, or unwanted toe in or toe out gains throught the range of motion.
with the "Z" everything stays factory geometry, just raised..
just my 2cents
Old 07-21-2008, 09:54 PM   #36
azfab
azfab's Avatar
Re: z'd frame?
ten four thanx guys for all your help i appreciate it
Old 07-22-2008, 02:44 PM   #37
87 dually burb
my short bus
87 dually burb's Avatar
Re: z'd frame?
hey azfab you got pic of the square body raised and dropped
wanted to know the lift you get with your set up
thanks
I'm with you on the fab work looks great
you make me want to tear my burb further apart for a "z"
and add another year to put back together
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 07-22-2008, 10:11 PM   #38
azfab
azfab's Avatar
Re: z'd frame?
sur ill get one one here asap
Old 07-22-2008, 11:25 PM   #39
scotts62
One day...
scotts62's Avatar
Re: z'd frame?
Ya man looks good! can't wait to see the raised pics also
Scott
93 crew cab build
Project 62
Old 07-24-2008, 12:50 AM   #40
shaneo2112RUSH
Junior Member
Re: z'd frame?
just my 2cents
cool, i will keep that in mind!!
Old 07-24-2008, 08:06 AM   #41
rotgg
Re: z'd frame?
my truck has a 4" z and 3" spindles and it lays pinch hard after i trimmed the bottom of the frame on 20"s i think it would still lay on 22s
rotgg is offline   Reply With Quote
Old 07-24-2008, 09:43 AM   #42
YOLO
Custom Truck Lover!
YOLO's Avatar
Re: z'd frame?
GMBowtie is correct. I did the pancake, shortened my stock a-arms 2 inch drop spindles, but I also did a 2 inch Z and SFBD. The frame is all custom but I used the stock front crossmember. That was all to lay on 26's. If you want to go with a smaller wheel, then you will not have to go that drastic. DO IT! Get an extra crossmember or at least know were to get one NOW if you mess up. Measure 10 times, cut once.
Squarebody guy
YOLO is offline   Reply With Quote
Old 07-27-2008, 10:36 PM   #43
shaneo2112RUSH
Junior Member
Re: z'd frame?
Old 07-27-2008, 10:38 PM   #44
shaneo2112RUSH
Junior Member
Re: z'd frame?
so the max height would be 4"! do the same for the radiator support??
Old 07-27-2008, 10:46 PM   #45
1low71
Re: z'd frame?
Heres how I did mine.
1low71 is offline   Reply With Quote
Old 08-04-2008, 10:45 AM   #46
Grunion
Grunion's Avatar
Re: z'd frame?
Yours is not pancaked.
Grunion is offline   Reply With Quote
Old 08-04-2008, 05:22 PM   #47
azfab
azfab's Avatar
Re: z'd frame?
all the way up[IMG][/IMG]
Old 08-04-2008, 05:23 PM   #48
azfab
azfab's Avatar
Re: z'd frame?
all the way down[IMG][/IMG]
Old 08-04-2008, 05:25 PM   #49
azfab
azfab's Avatar
Re: z'd frame?
here are some[IMG][/IMG] pics of the control arms i did
Old 08-04-2008, 05:26 PM   #50
azfab
azfab's Avatar
Re: z'd frame?
[IMG][/IMG]
