01-06-2011, 04:18 PM | #26 |
But Found Her 25yrs Later!
Re: Another Power Steering Conversion Thread
Thanks to Chevy_Mike, we now have this discrepancy resolved, and will be updated on the template.
The 1-3/4 is the exact difference to the 'rag joint', but this (as mike points out) would be a butt weld, with nothing to spare. And allows for no mis-measurement in the slightest. 1/8 short, and you have a 1/8 gap. However; if you measure from the flange 1-3/4" it allows the shaft to slip into the flange by that amount. Honestly though, to leave it slightly long makes sense, one could always cut it again. Cut it too short, and you have to run up to the tool store and buy a shaft stretcher
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-06-2011, 06:34 PM | #27 | |
There's too much technical words I don't understand why are people having problem installing this. This is the Way I would do it: Install the steering column, Then Align the steering box with the steering Rod. Mark the steering box's holes. Cut the Rod if necessary. That's It!!! I am right? |
01-07-2011, 01:55 AM | #28 |
fan of "Butters" Stotch
subscribed!
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again Last edited by tapeworm; 01-09-2011 at 06:39 PM. |
01-07-2011, 02:14 AM | #29 | |
60-66 Nut
The template that LostMy65 has helped me create, is a better way of locating the adapter plate. The template will be just a piece of 8 1/2" x 11" paper, that you place on the frame, once the original steering box is removed. It will show you where to locate the new mounting holes in relation to the holes for the original steering box.
The original method was using measurements from reference points, but this proved to be inaccurate. I'll have to look into the steering column shaft length issue again. Quote:
01-07-2011, 09:48 AM | #30 |
GMC's n H.D.'s too!
Captainfab has sent me the template. It was easy to print out to scale. I had just gotten the bracket from him before Christmas. I haven't used it yet, (work and kids take alot of time) but will be getting to that point hopefully in the next couple of weeks.
01-07-2011, 11:33 AM | #31 | |
Never Ending Projects
Definitely had I measured from the end of the flange, it would have wokred out fine but like you said, easier to leave the shaft a little long and cut extra off then having to stretch it. Just glad my local metal supply shop had the right size DOM tubing.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-07-2011, 02:44 PM | #32 |
Captainfab, please forgive me for this attempt to influence your design. Rather than a paper template, would it not be simpler to drill two more holes in your bracket as locators, to bolt the bracket to the frame through two of the manual box mounts? then drill the new mount holes using the bracket as a template, remove the locator bolts, and bolt the new box in. Your bracket does cover a couple of the original holes, right?
I appreciate your presence here on this board, and the products you've designed for us. I don't mean to step on any toes. Ralph |
01-07-2011, 04:30 PM | #33 | |
01-07-2011, 04:43 PM | #34 |
GMC's n H.D.'s too!
After reading these, I looked at the template that Captainfab sent me. According to the template, it covers up (3) existing holes. The problem would be that (2) of them are right next to the new holes, and one is right on the edge. The (2) by the new holes would be right under the spacers on his bracket.
01-07-2011, 04:59 PM | #35 |
Thanks ChevyMan. That explains why my idea isn't already being used. Should have known if CFab could have doe it, he would have.
Ralph |
01-07-2011, 05:10 PM | #36 | |
60-66 Nut
Yes that would be easier. In fact that is how the 'other guys' have theirs. But with my design that would only be possible for one of the original holes. The other two as chevy-man5 said, are covered by the spacers. Using only one hole to locate the adapter plate still allows for a mistake in positioning. At this point, I want to eliminate any more mistakes in locating the adapter plate. So the paper template would seem to be the best solution right now.
01-07-2011, 05:15 PM | #37 |
Yep, you're right. So much for my attempt at being the "armchair quarterback"!
Ralph |
01-09-2011, 05:12 PM | #38 |
Oh boy after reading this post I may be in trouble. When I was plucking parts off a 77 burb I didn't grab the pitman and the steering shaft spun around in different direction. How do I know if I will have equal turns right to left?
01-10-2011, 02:04 AM | #39 |
60-66 Nut
You'll just need to turn the input shaft all the way to the left until it stops. Then turn it all the way to the right, while counting how many turns until it stops. Then go back half way.
01-10-2011, 06:28 PM | #40 |
Of course! Thanks Cap!
02-12-2011, 11:21 PM | #41 |
I'm interested in hearing how things have been going for those who have used the Template CaptainFab has been including with his Power Steering Adapter Plate.
02-15-2011, 08:48 PM | #42 |
i got the plate from captainfab and the install went very well with the new drawing.
02-16-2011, 01:01 AM | #43 |
60-66 Nut
That's good to hear. Thanks for the feedback
08-28-2011, 07:52 PM | #44 |
I'm going to revive this write-up for a second.
Today dad and I were walking around my 65 and kicking around ideas. We talked about adding power steering,so I got on here and did some reading. Looked in the FAQ section first and came to this thread. Ive studied it and CaptainFabs "bracket page" and this looks pretty dang simple from the added drawing that now comes with it. My questions are these. 1. What years of steering box will work? I see a lot of 70's models used. I have access to a complete setup off an 89 chevy, would that work? If not, I could purchase a new or rebuilt unit from the parts house that would work. I just need to know what years would work. 2. I think I read that the pittman arms are different lengths (meaning the existing 65 I have and one of a different year)? 3.Can I use my factory steering column, obviously after cutting it down? 4. Once I bought Fab's plate, bolted in the steering box, made the necessary cuts and welds to the steering column, i would just need hoses to run from the box to the power steering pump and voila? Thanks for any advice, I'd really like to do this. Assuming captain fab's plate is still available |
08-29-2011, 02:16 AM | #45 | ||||
60-66 Nut
Yes, all of my parts are still available. Send me a PM when you're ready.
08-29-2011, 09:09 AM | #46 | |
Posted via Mobile Device |
01-03-2012, 04:11 PM | #47 |
Bump.
Let's review the idler arm- are you guys using original year idler arm to the chassis/linkage, or updating to a different year? ? or changing spacers on it?? I am installing on a '63, have an '86 PS box mounted, and a new '86 pitman arm. I don't have everything tightened down, but just mocking it up it looks like: a) the center drag link is extremely close to the crossmember b) the idler arm needs to be flipped and mounted without the spacer block to get it aligned "neutral". Here is a picture of the '63 idler arm, no spacer, but "flipped". I put a piece of blue tape on it to make it show a little better. This looks correct to my eye. Disregard the tie rod angle, it is just laying there.
292 + TKO500 |
01-03-2012, 05:26 PM | #48 | ||
01-03-2012, 06:05 PM | #49 |
[I didn't mess with the idler arm. Haven't had any issues with the drag link bar rubbing the cross member.[/QUOTE]
dracko, thanks for the info. So you used the old idler arm? Could you do me a favor? and post a picture of your idler arm that shows if it is centered or off center when the steering box is centered.
292 + TKO500 |
01-03-2012, 07:05 PM | #50 |
Yeah I left the old one on there. All my steering components need to be replaced, I just need to decide if I'm gonna go to disk brakes before ordering all the parts up.
I will get a pic tomorrow. Have you tried bolting it up and working the steering back and forth? I haven't heard much about folks needing to modify it when switching to power steering. |
