Old 08-21-2015, 03:03 PM   #1
F.A.A.benny
Some A/C and heater Parts (Restored)
I have an ac and heater box. They both were completely gone through with new and rebuilt parts. They are ready to be bolted back on the truck and used. These are show quality. The ac housing was bead blasted and clear coated. The back metal panel was removed, repainted and reinstalled with new rivets. The door was painted black and the rod was replated. New evaporator and blower motor installed( a $300 value). The poa valve was rebuilt and replated. It can be calibrated to 134A or R12. The expansion valve was also rebuilt and replated. Vacuum canister was bench tested and reconditioned. The squirrel cage was reconditioned. The ground cable, Harrison sticker and red dot included. New o-rings were installed as well as new screws, cork tape and gum cord to help seal the unit. All the hold-down clips and clamps were also replated. $600
The heater The housing was bead blasted and clear coated. The metal panel was bead blasted and painted. The resistor was replated. New heater core and relay installed as well as new screws, rivets, and gum cord to help seal the unit. All other small parts were also replated. $200
If you need more detailed pics, lmk.
$750 If purchased together.
Im in the DFW, TX for a local pick up. Ill do a slightly better deal on the ac box if picked up locally but can ship on your dime, through fedex.
F.A.A.benny is offline
