Old 11-02-2003, 06:47 PM   #26
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
as was said the cracks are where the knurled part of the bolt goes into the block.. not where the threads where..
Id bet dollars to donut holes that what happened was your starter kicked back HARD once or twice and tried bending that bolt in the block.. IF you had the OEM starter strap on the other end of the block installed, this would have never happened. Its not that bad, get some new starter bolts, a new starter, (high quality) and that strap which should be available at the dealer, and RUN it! Fix it when you rebuild the engine, not now..
Heres one of those starter braces. I run one and recommend you do too.. it bolts to that long peice of all thread thats on the back of that starter motor, and goes up to the engine block where there is a threaded hole..
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2440257188
mike
mike reeh is offline   Reply With Quote
Old 11-03-2003, 01:11 PM   #27
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I don't have a brace like that. Was it not used on our trucks, or did they all just get thrown away like so many other parts?
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-04-2003, 01:19 AM   #28
Nvbowtie
Nvbowtie's Avatar
new thread, just like a new chapter !!
http://67-72chevytrucks.com/vboard/s...threadid=75708
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 11-04-2003, 02:07 AM   #29
jimfulco
I'd braze it.
jimfulco is offline   Reply With Quote
Old 11-26-2003, 01:49 AM   #30
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Never underestimate the uses for JB weld!
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
Old 11-26-2003, 06:21 PM   #31
rocky2
rocky2's Avatar
easiest maybe not the cheapest fix is to go with an aftermarket high torque starter they bolt in the straight across so use the other hole and go have done this before
is this a hobby or an addiction?
rocky2 is offline   Reply With Quote
Old 11-26-2003, 11:55 PM   #32
Nvbowtie
Nvbowtie's Avatar
the outer hole is used for both staggered and straight
Old 11-27-2003, 12:17 AM   #33
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I talked to a guy today who owns aenginerring fabrication shop. He does alot of work for shops and weld tranny cases and blocks quite frequently. He says that he has never had one crack again once welded that he knows of.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 11-27-2003, 01:05 AM   #34
Frank-id
Starter bolt hole
First decide how the bolt hole is affected by crack. Get some 3/8 X 16 grade 5 all thread. Test hole for good threads. Make a long stud from all thread and lock tite in place. Use a few good hard washers with a nylock nut. This will give many years of service...... Frank
Chevy stepper 400sb 350 turbo
Frank-id is offline   Reply With Quote
