Old 06-17-2013, 06:39 PM   #26
tincan1966
tincan1966's Avatar
Re: |Lower Control arm shaft problem.
Originally Posted by Hotrod1979 View Post
It is all clear now. Thanks for all the pointers. I will look out for some later control arms and sell along my old (new) ones..
One more question. Do you know if 1973 control arms (a friend has a set laying around) are they same as control arms from later c10 trucks?
To the best of my knowledge they are the same from '73-87 on C10 pickups(late '87,88 was new body style.) However they are the same up to 1990 for 2WD 1/2T suburban, 3/4T and 1T 2WD trucks will also interchange from '67-'90 or maybe even 1991. I know somewhere before the '64 to 66 model, the lower control arms are different on the 3/4t and 1 ton than the '67 and up.
tincan1966 is offline   Reply With Quote
Old 06-17-2013, 06:44 PM   #27
Hotrod1979
I forgot to mention it is a 1973 2wd blazer, but I guess from your answer they are all the same.
Hotrod1979 is offline   Reply With Quote
Old 06-17-2013, 06:49 PM   #28
tincan1966
tincan1966's Avatar
Sounds like you have what you need.
What I would do:
New Bushings for the '73 blazer arms(upper and lower)
New upper and lower Ball joints for the truck you have
Install new ball joints and bushings in donor control arms, install spindle/disc brake kit with a tandem master cylinder/proportioning valve and split the front brake lines.
You'll be happy with the results.
Old 06-17-2013, 06:54 PM   #29
Hotrod1979
That is excactly what I am gonna do! Thanks for the advice!
Old 06-17-2013, 06:58 PM   #30
tincan1966
tincan1966's Avatar
You're welcome, glad I could help out a little. Feel free to PM me if you have questions, will do my best to help.
