10-06-2021, 12:34 PM | #26 |
Re: Elderbrock AVS carb
apparently the first three digits are the julian day and the last is the last digit of the year. (guess it's up to you to know the decade).
https://static.summitracing.com/glob...rantyguide.pdf
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights |
10-06-2021, 12:59 PM | #27 |
I run an AVS2 on the 366 in my big truck, I'd recommend it for sure, the annular boosters really do help throttle response under normal driving conditions, even in such a heavy truck. Definitely get the insulating gasket, I have one and occasionally still have the boiled dry fuel bowl issue, a lot less when I run better gas though.
10-06-2021, 11:12 PM | #28 |
I have a used, rebuilt 1406 on my crate ZZ4 and for the past 15K it has never failed me. Stock fuel pump no reg and never had a heat spacer. And in my 65 mustang that runs hot under the hood with my fresh 289 built radical I have a new 1405 box stock without the heat spacer and again a stock fuel pump. Never hard to start. In fact I never have run the heat spacer on any of my cars and always run a stock pump, guess I am missing something here for the past 50 years
10-07-2021, 01:12 PM | #29 | |
As for the pump, it's always been the same for me. Stock with around 5 psi, I assume.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
10-07-2021, 01:32 PM | #30 | |
10-07-2021, 05:39 PM | #31 |
I needed a regulator for my 1406
Pump was putting out over 9psi I might be mistaken, but q-jets only need like 4 psi.
350/th350 Sportsman2 heads Performer Intake 1406 carb 3.42 Eaton Posi |
10-07-2021, 06:10 PM | #32 |
I stuck a guage fitting inline just before my carb, the stock pump on my truck pushes 4.5-5 psi consistently.
