Old 07-26-2015, 08:31 AM   #26
racerop
racerop's Avatar
Re: Heater core shutoff valve…revisited
Originally Posted by LuckyLightning View Post
I just drove the truck today for a few hours in the hottest part of the day. I think what I saw was the temp rising before the thermostat opened up. I saw it happen again today - the temp would rise until the thermostat opened up, then go back down to normal. Interesting thing was it happened every time I turned off the truck for more than a few minutes (such as when pumping gas). I assume this is normal operation, but I never noticed it before.
I had a car have the same symptoms as what you are describing. I would flush/refill with new coolant and replace the thermostat. The thermostat is probably sticking while opening.
racerop is offline   Reply With Quote
Old 07-26-2015, 02:12 PM   #27
tucsonjwt
After running at operating temperature, then shutting off the vehicle, it will normally increase in engine temperature because the fan is not running and the coolant is not circulating. After sitting for awhile, the engine will normalize to ambient temperature. With a big block this effect is magnified because they have less air space around the engine/exhaust manifold to dissipate the heat.
My experience and $.02,.
tucsonjwt is offline   Reply With Quote
Old 07-28-2015, 09:35 AM   #28
LuckyLightning
LuckyLightning's Avatar
Thanks tucsonjwt, I kinda figured that might be what was going on. Appreciate the confirmation.
Michael
- 1962 C20 LB stepside (project thread) - sold
- 1963 Chevy C10 LB stepside (donor)
- 1963 Chevy C10 LB Custom flatbed (project thread) - sold
- 1979 K20 LB fleetside (project thread)
Favorite exchange on the board so far:
ol_Curt: "Jason, do you have power steering?"
jason65: "No, but I lift weights."
LuckyLightning is offline   Reply With Quote
Old 07-28-2015, 03:48 PM   #29
Bigstevex4
Bigstevex4's Avatar
That's normal the heat is rising to the thermostat. I have a Manuel temp gauge at the stat it will rise 20 degrees when shut it off.
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 08-03-2015, 03:03 PM   #30
roger97338
roger97338's Avatar
Being able to see the gauge fluctuate like that often means that there are still air bubbles (or one large air pocket?) in the cooling system.
roger97338 is offline   Reply With Quote
Old 08-04-2015, 05:22 PM   #31
LuckyLightning
I believe it roger97338. How do I get rid of the air pocket(s)?
Michael
Old 08-06-2015, 07:51 AM   #32
Liberty
Liberty's Avatar
Run it a bit without the rad cap on, should see it burp and drop fluid level. Driving it around can also help. (with the cap on of course!)
Liberty is offline   Reply With Quote
Old 08-06-2015, 08:41 PM   #33
LuckyLightning
Great, thanks Liberty for the advice.
Michael
