#26 |
Re: Clutch linkage picture 66 GMC V6 w/ SM420
Any chance to get that picture Jimmy?
#27 |
Thanks for the Deer Valley Auto plug. I have been looking all week for a yard with some 60-66 GMCs/Chevys and cant find one in Mesa, Az. I found a guy in Apache Junction that only has a cab, with no doors. Do you know if they have several of these trucks there, or at least a complete one. Also, i googled Deer Valley and only found Glendale Auto Parts. Is that the same yard?
#28 | |
The 60-66 GMC/Pontiac guy....
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() Last edited by 66-PMD-GMC; 06-28-2011 at 09:33 PM. |
#29 |
so in a GMC would the v6 and the I6 use the same bell crank or would they be different from one another?
ron |
#30 |
I did a V6 to L6 conversion.
Had to change the frame bracket, frame bracket location, bell crank, all the rods AND the clutch peddle. The V6 bell crank is pushed by the clutch peddle rod coming through the fire wall and the L6 is pulled. To convert, you have to "flip" the little arm on the end of the peddle shaft but it is "clocked" requiring the whole peddle to be swapped out. I can take photos if necessary.
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#31 |
thanks for the clarification. one learns something everyday. sometimes it is difficult to rationalize the differences
ron |
#32 |
The differences make complete sense to me now that I have explored the different motor transmission combinations.
![]() I started all of this by installing a Pontiac engine in my 66 ![]() ![]() Then I changed out the Pontiac to a straight 6 for gas milage, again everything in the clutch department is different. ![]() Then I find a 63 short bed with a V8 that was originally a straight 6 and the PO tells me he cut out the rear cross member and went automatic because he couldn't get a clutch to work. I check out the parts he throws in with the deal and see yet another clutch setup. Thats when I started to seriously research the clutch setups in Chevy and GMC trucks... ![]() One size doesn't fit all in these bad boys thats for sure. I am still looking for an original V8 bell crank frame bracket and would like to compare that with the V6 as I am convinced it will be different. ![]()
#33 | |
I just pulled the clutch linkage out of my 66 gmc with a 250 6 cylinder (i installed a 700r4 and a 350) the clutch linkage looks just like the dirty lower one in the above picture (it has a grease fitting on it, and it is bent like the one shown.) Kieth ![]() Last edited by kieth; 06-29-2011 at 10:12 AM. |
#34 | |
I have photos of over a dozen bone stock original setups and I am seeking out more. I think it is good information to collect and share.
#35 |
what we need to see if someone can show us is a zbar that comes out of a v6 eng equipped truck as this is the the only one that seems to be in question
ron |
#36 |
Do you have a picture of the clutch pedal set-up for the V6 that you can post?
#37 |
Zero Albedo
1964 GMC 1/2 ton 305 V6- hope this helps.
Baz "Deserve's got nothin' to do with it." 66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467 65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432 65 Chevy Panel (former U.S.Navy truck) 64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348 64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now) 68 Dodge Charger |
#38 |
i can see what is happening now. it is located further back as it attaches to the bellhousing. it is also a little shorter. so there are 2 different zbars; 1 for the v6 and another one for all of the rest of the engines. the v8 ballstuds differ from the I6 ones
ron |
#39 |
Zero Albedo
1964 Chevy K14 Suburban, V8
#40 | |
This makes the peddle different too.
#41 |
sorry, the 4X4 and 2X4 are different and in different locations on the frame and block
#42 | |
ron |
#43 |
#44 | |
GMC state side did not offer a V8 in their trucks. I have seen a total of 3 different bell cranks on different applications in Chevy but one looks exactly like the V6 GMC bell crank mounted in the rear position.
#45 |
Here is the V6 bell crank from my 66 GMC.
#46 |
