11-28-2012, 01:06 AM | #26 | |
Re: Anybody running lower then 12s QM?
Car craft changed a cam and a big turbo and cranked that thing just about stock to 1200hp Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
11-28-2012, 10:51 AM | #27 | |
Oh, and a rollbar too. |
11-28-2012, 11:24 PM | #28 |
Hate to break it to you guys but that '70 chevrolet "farm truck" sports a 502 base engine with serious upgrades and as of the last time I saw it, a huge twin stage plate system. I've heard that he has since upgraded to a 400+ hp fogger. It has a fully built 9" with a spool and a reverse manual valvebody. As far as the chassis it is relatively stock, just look at the way it leaves, kind of sloppy. If it had extensive chassis work done it would leave a helluva lot straighter. That man, although he has a cage under that camper shell, is completely INSANE. That truck has a 1/4 turn of play in the factory steering box. In no way shape or form is that truck remotely close to being a daily driver, it drinks race fuel and the only thing it ever gets used for is the occasional cruise night or messing with some kids on the street. It is a track truck and it gets trailered there. Oh by the way if you ever see him in person do not let him trick you into listening for a noise right under the drivers cab area, there is a 150 psi real train horn mounted right underneath the cab and he will air it out for anyone dumb enough to fall for it, I've seen him do that to alot of people.
Rally 'round the family....with a pocket full of shells. |
11-28-2012, 11:41 PM | #29 |
I don't doubt it. I'm sure with a good chassis setup slicks and a well built 505hp engine getting to 11s is possible but making that street able is going to be hard
11-29-2012, 12:41 AM | #30 |
dang were talking now. how good does she handle the street?
Her name is Quicksilver 1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER gotta pay $$ if you wanna play |
11-29-2012, 12:51 AM | #31 | |
i like the plymouth btw
11-29-2012, 01:01 AM | #32 |
dang 6000 aint bad! that must be the kicker. just like a brand spanking new crate motor big block. im not gonna spoil your fun, lets see the turbo charged 6.0 liter LS3 is a 6.0 right? im very much against boosting cause it makes me angry to think we really need to add so much money to an engine to make it do what we want american engines should have been alot more advanced by the 80s. just for once i wanna see a sbc running on the street, with good gas milege, naturally aspirated good amount of power, good throttle, and reliabilty. and can push a 4000 pound vehicle to low 11s or lower
11-29-2012, 01:11 AM | #33 |
Boosting doesnt cost much at all. It's the only way to make high hp and get good mpg at the same time
11-29-2012, 01:20 AM | #34 | |
11-29-2012, 01:28 AM | #35 |
Speed costs money, how fast do you wanna go?
1977 GMC Sierra Grande |
11-29-2012, 01:35 AM | #36 |
i have to agree there is no denying it..... but i guess for back yard hot rodders, ill never boost an engine except a briggs and stratton 8 horse with a smog pump. not that im against it all the way, hate to admit it, but i my self cannot see myself affording a nice turbo.
11-29-2012, 01:39 AM | #37 |
i wanna go fast, 150 mph, N/A streetable Quarter Mile. i want the best of both worlds. yet i cant afford it! but if i keep my head up and find some sort of way, new discovery, ill let you guys know.
11-29-2012, 01:42 AM | #38 |
Yea all them skulls on the intake are nitro foggers.
11-29-2012, 02:23 AM | #39 | |
11-29-2012, 02:45 AM | #40 |
At the body shop.
Dig thru some older hot rods.
Built a 383 with 200cc heads a fairly mild hyd roller cam dual plane air gap and a 750 or 850 dp holley. Made right at 500 hp and tq. I copied it except for a 400sb and its a riot to drive. Has ran 12:20s at 110 mph. And stone reliable did 25 passes in one day at private track rental Posted via Mobile Device Found it. http://www.hotrod.com/techarticles/e...e/viewall.html
" That didnt make it any newer " " Dont antique the equipment " |
11-29-2012, 02:54 AM | #41 |
I have been 7.2 in a quarter with an alcohol injected 14-71 littlefield blower on a 496 in a car that the only thing stock on was the roof, also been 11.1 in a 79 shorty and that took just a tick over 625 hp to do and I wouldn't have driven that one daily. It all comes down to this: You can have cheap, You can have fast, and you can have reliable, but you can only have 2.
11-29-2012, 03:02 AM | #42 | |
11-29-2012, 08:52 AM | #43 | |
Given the same motor, a 1000 pound weight reduction is good for about 1 second in the 1/4. This easily gets your 11 second goal. Our trucks are more expensive to make fast because the weight and aero must be overcome and that takes horsepower and money. There's no way around it, unless you can somehow bend the laws of physics. GM, Ford, Dodge, and other truck makes still face this problem today, but more in the sense of fuel economy.
11-29-2012, 10:06 AM | #44 | |
I could have probably gotten nearly the same performance from a less radical cam, dual plane intake, vac secondary carb and tighter converter to make it more streetable but I'm kinda old school and wanted a (semi) nasty lope for the weekend cruises. Plus I'm gonna get it out to the track one of these days. |
11-29-2012, 08:06 PM | #45 | |
11-30-2012, 01:50 AM | #46 | |
Always a work in progress
Any turbo will work as long as it sized properly to the motor. Why do you need a line hone and they make iron block LS based engines. A stock LS6 cam is great for boost. Dual Walbro 255s in a stock tank will supply plenty of fuel and you can run the stock TB, intake, and fuel rails with 60-80lb injectors.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
11-30-2012, 02:02 AM | #47 | |
11-30-2012, 02:16 AM | #48 | |
I'm converting to hydroboost on mine and some good heads and get a real cam lol I think with a lockup converter streetabliity becomes way easier since you can run a 3000 stall and an overdrive trans and drive around a more radical engine topped with today's heads and roller cam tech and carburator a have advanced dramatically yesterday's radical 400hp small block is today's Daily driver. And a 500hp daily just takes some time and a good combo Turbos are a great way to make a small engine like say even a 305 destroy a built 572bbc and run down the street getting 25+mpg The theory for displacement is bigger engine = easier power a mild built 454 shows 450 hp almost stock. And built more can have 500hp with an exhaust not of a Vespa still Posted via Mobile Device
11-30-2012, 02:20 AM | #49 | |
Or look up the wrenchrat. Here's food for thought. Atmospheric pressure is about 14.7psi I belive An engine at 15psi of boost usually doubles hp And 1/2lb fuel=1hp/hr Posted via Mobile Device
11-30-2012, 02:21 AM | #50 |
I am not sure but with the HP #s that everyone is throwing out there that combo should get you in the HP range required to run under 12 secs. Keep in mind that you still have to get the power to the ground.
I am going to build that exact combo I listed above but it won't be done until I return from Okinawa(my next duty station). I wouldn't trust any 700r4 or 4l60e behind any motor with some power. 4l80e is the way to go.
