02-05-2006, 11:28 PM | #26 |
18 Till I Die
Re: Exhaust Exit Location???
Dumped before the diff 3" into flowmasters with 6" Chrome tips
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
02-07-2006, 09:35 PM | #27 |
Rokcrln, That x-member is awesome!! You should consider making and selling those. How much could you make one for?
02-08-2006, 12:20 AM | #28 |
For those of you that dump it before the rear wheels or rear axle, how is the road noise? I do a lot of highway driving, along with a lot of local.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
02-10-2006, 01:36 AM | #29 |
mine are dumped right after the turbo mufflers, and right before the diff. sounds great. a little too loud, draws too much attention....especially the cops, had a sheriff call the house once asking who was driving the chevy, telling me to slow down...thing is i was never speeding- just opened the secondaries barely, im assuming to him loud=fast...oh well...enjoy
1970 Chevy C/10 |
02-10-2006, 12:16 PM | #30 |
Having th exhaust dumped in front of the axel is horrible after a week. The sound is much better if the exiting point is out side the body.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-10-2006, 12:22 PM | #31 |
I fishmouthed my rear chrome bumper and have 2 1/4" satinless tips straight out the back about frame width.
http://67-72chevytrucks.com/vboard/s...d.php?t=176774 |
02-10-2006, 12:27 PM | #32 |
67-72 Addict!
I agree with 72mario, plus if you dump the pipes toward the ground it kicks up dust around the truck.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
02-10-2006, 12:34 PM | #33 |
A.K.A- Crummy
Mine aren't straight out the side but angled to exit right before the rear bumper.
2003 Silverado Z71 Are fishermen all liars? |
02-10-2006, 01:25 PM | #34 |
I have 2 1/2 inch Rams with 2 1/2 exhaust tucked up inside the frame. Flows thru Magniflow mufflers and kicked out just in front of the tires. I want to redo the exit area and come thru the side panels of the short wide bed. Sound? Great and not so loud you can't hear your stereo but a nice rumble.
68 Chevy short wide air cab 4/6 on the drop 327 small block Front disc Frame "c" sectioned Gaylord bed cover |
02-10-2006, 01:46 PM | #35 |
Like this guys??
I did it to my 72 Longbed, just got it out of paint a few weeks ago, I havent started the exhaust yet. Just finished putting on headers. I got the idea from Stacy on Trucks, like a few guys were talking about. Cut out the body with a air nibbler. I have the steel plate/ring made to go around the opening to give it more flair, I will probably chrome it and put smooth SS hex bolts like he did on the Trucks show. Making the steel plate was an experience, I had finished up grinding the outside edge and was wire brushing it on a 1/3HP bench grinding wheel when the dang wire brush grabbed it and slung it back at me at about 100MPH and hit me right in the forehead above my eye. Cut me down to the skull and I had to have 5 stiches, looked just like Frankenstein. NOW i use a complete face shield. You live an learn. Sorry about the poor pictures, its in the garage and not much light, when I get it running I will take better ones. |
02-10-2006, 01:52 PM | #36 |
Formular: Where did you get the tips. I have been looking for a set like that and will be doing the same to my truck. So you are saying your truck drew first blood huh ?
02-10-2006, 02:05 PM | #37 |
Check them out at www.stainless-specialties.com. Mine is the rolled oval tip. You can get them in 2, 2 1/4, 2 1/2 or 3". They are 304 polished SS and are of great quality....they are $129.00 a pair. I think Stacy used some from Corsa, but I could never find them....I actually like mine better.
I am worried about the noise that an exhaust might make at this location. I put dynamat material on the inside & outside of the door and everywhere else to hopefully keep the noise down. I havent yet decided on a muffler, I want to tone it down but keep the flow. |
02-10-2006, 02:15 PM | #38 | |
02-10-2006, 04:32 PM | #39 |
I just put Dyno-max headers with bolt on flow-tech purple hornies glasspacs, and it is LOUD! Muff tips end about midway under my cab.
CoolRide |
02-10-2006, 06:50 PM | #40 |
WTB this ad
Here's a couple pics of mine. Everything is tucked inside the framerails. I used the ECE Xmember and had a H pipe installed. The truck has a 3.5 front and 6" rear drop. The tubing is 2.25" aluminumized pipe. Flowmasters are making the noise. |
02-10-2006, 08:58 PM | #41 |
GM ONLY BABY!!!
I don't like the dump before the rear diff. either. My 66 chevelle is currently like that, but will be changed soon. The dump before the diff. blows dust all over the trunk and rear bumper of my car. If you have a good clean paint job, especially black, it will make all of that dust staticly adhere to the bedsides and bumper and the rearend of your truck.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
02-12-2006, 02:37 PM | #42 |
I've been thinking it out some more, and I think I'm going to do it like an AAR cuda or Challenger TA had, where it comes outside the body just before the rear wheels at an angle. I'll have angle cut stainless tips there so it looks OK, and gets the dust and crud away from the paint a bit. Anyone ever used this setup and can tell me anything about getting dirty or road noise?
04-02-2006, 12:23 AM | #43 |
Anyone running Nascar Boom Tubes
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
04-02-2006, 12:49 AM | #44 |
Mine exits through several holes located throughout the length of pipe,then up through the rust holes in the floor.Just got home,I`m sleepy,good night.zzzz
04-02-2006, 01:47 AM | #45 |
I saw a '66 that routed the pipes like the AAR, but he used a twin tip like a '70's Trans Am that was turned down. You only saw the tips and it looked great. I am planning something like that.
04-02-2006, 02:55 AM | #46 |
Oil trash and damn proud of it
my exhaust comes out of headers, and in one side into a 15" glasspack, and the other a 12" glasspack, into about 18 more inches of pipe, and both pipes end just before the end of the cab. Illegal? Yes. Do I care? No. Can you remotely even hear yourself thinking when that thing is roaring at 4000+ RPM? NO! It is one loud truck, I'll guarantee you that. Oh yeah, and for your info, I didn't do the exhaust. That was a P.O. thing. You'd understand and find it perfectly normal if you ever met the guy, and looked over everything on this truck.
Mark 1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift 1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze 2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons Some of my pics http://s107.photobucket.com/albums/m294/69-350/ Last edited by 69-350; 04-02-2006 at 02:57 AM. |
04-10-2006, 08:55 PM | #47 |
Sounds Interesting(no pun intended) 69-350 got a sound clip
Thanks Shane
