Old 06-25-2024, 12:04 PM   #26
chappys4life
Re: Adding relays
Originally Posted by pjmoreland View Post
When I added electric fans to my truck, I mounted the two relays underneath the core support triangle brace that's over by the battery. I secured the relays with the triangle brace mounting bolts. The relays are well hidden under there. I installed a little fuse panel next to the relays. That painless fuse panel with the built in relay looks like a cleaner solution than what I did.
I also ran a 6 gauge wire from the alternator to the battery and connected the other main system feed wires to it with a large crimp terminal in the stock junction location over behind the driver side headlight.
THOMAS & BETTS C Tap: 6 AWG For Max Run Wire Size, 29 Die
Model 54715
https://www.grainger.com/product/3LM..._WillCall&rfe=
Harbor Freight Hydraulic Crimping Tool
https://www.harborfreight.com/hydrau...ool-64044.html
Really like your setup! Was thinking of doing something similar. Also I want to upgrade my alternator to a 12si then wire 6 gauge to the battery just like you did. I typically do that in my ford just learning the chevy ways.
chappys4life is offline   Reply With Quote
Old 06-25-2024, 12:09 PM   #27
chappys4life
Re: Adding relays
The more I am getting into this truck the more I am wanting to buy a new harness. A additional question. Both of these circuit breakers(?) are unhooked. Do I need to do anything about them? Someone has really been in here with a lot of taps and added cruft.
Old 06-25-2024, 04:45 PM   #28
pjmoreland
pjmoreland's Avatar
Re: Adding relays
That relay near your fuse panel is you horn relay. I'm not sure what the other relay is.
pjmoreland is offline   Reply With Quote
Old 06-27-2024, 12:25 AM   #29
Accelo
Accelo's Avatar
Re: Adding relays
The other one on the firewall is for a spark delay. No need for this any more. It's useless you are going totally stock.
I added my fan relay between the battery box and the core support. Almost invisible there at least no one seems to find it unless I point it out.
Accelo is offline   Reply With Quote
