07-31-2004, 06:43 PM | #26 |
Epoxy Primer Friendly
tub
any updates/pics ?? thanks
08-01-2004, 12:10 AM | #27 |
Saving 1 truck at a time!
Swwweeeeeeet! Your detail work is beautiful and I love the concept of the truck.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
08-01-2004, 12:22 AM | #28 | |
Señor Member
08-01-2004, 01:44 AM | #29 |
He's still there. I've known Monty & his brother for many, many years....
08-01-2004, 10:10 AM | #30 |
PROJECT 7DEUCE
Should be a share looking truck when it's done..
08-01-2004, 10:29 AM | #31 | |
Señor Member
08-01-2004, 10:34 AM | #32 |
The LuvShack Garage
SWEET TUB JOB.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
08-01-2004, 11:00 AM | #33 |
here you go
08-16-2007, 07:05 AM | #34 |
A guy with a truck
Re: Requested Tubbing Pics
Wakin' the dead. What's the status on this truck Scoti?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-16-2007, 07:56 AM | #35 |
Village Idiot....
08-16-2007, 11:55 AM | #36 |
That's just wrong man . . .....
Progress? Not sure if this counts but I managed to accumulate another inch of dust. Work has been on the Beater & it's taking too long as well (it's getting mini-tubbed too).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-16-2007 at 12:05 PM. |
08-16-2007, 12:10 PM | #37 | |
A guy with a truck
The real reason I dug up this thread is 'cause I was looking at info on tubs and your name came up. I can't get the thought of some 20x15 minimum backspace wheels out of my head. I have basically planned an entire build around a set of rear wheels I've got a few questions for you regarding some of the things you've done here if you don't mind... - What method did you use to raise the entire floor? I've studied the pics and it appears to be 'floating'. I know that's not possible, so where'd you get the 3"? - What is your total height in the center above the (stock)frame rail? My measurements put it at about 7". - How did you form the stepped flange on the inside edge of the tubs? I get the sectioning part, just can't figure how you did the stepped portion so cleanly. Thanks in advance, what I see so far looks great. I hope you can find the time to finish it. -Chris
08-16-2007, 09:57 PM | #38 | |||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-16-2007 at 09:58 PM. |
08-16-2007, 11:29 PM | #39 |
A guy with a truck
Sweet. That's pretty much what I was thinking, but I always like to get a few ideas before I commit to something. Thanks and keep us updated -Chris
08-17-2007, 12:51 AM | #40 |
Looks nice! I minitubbed my 70' lwb, lowered the back 5" took two wheel welds out of 72' truck and cut and peiced the two together so it looked stock but wider. I cut the bed floor to the frame. The rear wheels are weld rodlites 15x12 with 7.5bs with MT sportsman 29-15.5tires. will post pics when i get done painting.
08-17-2007, 12:51 AM | #41 |
